Pages: 1 2 [3]  All   Go Down
Author Topic: OCUBA - Overclocking Utilities and Benchmarking Applications  (Read 173790 times)
AaronTopic starter
  • GENERAL
  • BOOST!
UPDATE: *Fix +Addition -Removal /Modification
/ Updated RivaTuner to latest version.
Refrain from having to solve most of your problems by not creating them in the first place.
DDR3 Memory Standards: Blurry Lines
Integrated Memory Controllers (IMC)
Intel EIST and Processor C-states
Overclock Database 2.0
AaronTopic starter
  • GENERAL
  • BOOST!
SuperPrime v0.9.9
« Reply #101 on: 29-April-08, 21:37:41 »
+ Added new stability tester "SuperPrime v0.9.9".
SuperPrime
"A benchmark to reckon with!"
Download
AaronTopic starter
  • GENERAL
  • BOOST!
/ Changed GPU-Z to latest version (v0.2.1)
AaronTopic starter
  • GENERAL
  • BOOST!
CPU-Z v1.45 Released
« Reply #103 on: 10-May-08, 12:58:22 »
http://www.cpuid.com/cpuz.php
    *  Intel Atom Z500/Z510/Z520/Z530/Z540 processors.
    * Intel Core 2 Duo E7x00 processor.
    * AMD 45 nm Phenom (Dened & Shanghai) processors.
    * Intel P45 chipset.
Exe file properties
    * MD5 (cpuz.exe 1.45) : DD4E540C04297CF93DC721166C13446E
Download
  • T9246ED
  • Administrator
Core Temp 0.99 Final {18.05.2008}
« Reply #104 on: 19-May-08, 03:39:15 »
What's new?:
- Fix: Incorrect recognition of 45nm Mobile Intel CPUs.
- Fix: CPU temperature not displayed in Core Temp window on Phenom CPUs (0.98 and 0.98.1).
- Fix: CPU load would sometimes display -1% load.
- Fix: AMD K8 would sometimes spike to 206C, the false reading is now ignored.
- Fix: AMD K8 sometimes constantly reads -49C.
- Fix: Core Temp does not show up automatically on G15 LCD with 2.02 driver.
- Fix: Shared memory structure was not properly filled on multiprocessor systems.
- Fix: System tray setting "Show highest temperature of each CPU" only displays one temperature reading in a multi CPU system.
- Fix: Certain problems with font resizing should now be fixed.
- Fix: G15 LCD would not update after using soft buttons.
- Fix: On temperature display mode change, high and low records were not reset.
- Fix: Changing the reading interval in settings did not actually update, restart of Core Temp was needed to apply the change.
- Fix: Incorrect VID detection on 45nm desktop Intel parts.
- Add: Shared memory - developers now have access to Core Temp data.
- Add: Register dump to text file function.
- Add: Preliminary Atom (Silverthorne) support - Untested.
- Add: Support for Intel Core 2 Duo E7000 45nm series.
- Add: Option to show a single icon instead of temperature in the system tray.
- Add: Custom font and size for G15 LCD screen or simply use the built in compact font and layout. (via Settings.ini)
- Change: Improved detection of L2 cache on Intel chips for more accurate recognition.
- Change: Rewritten temperature calculation to fix problems with shared memory.
- Change: Default G15 LCD text layout and font changed.
- Change: Doesn't create a log file containing session start and end times if logging is disabled.
- Change: Settings.ini file is automatically created with default settings in case one doesn't already exist.
Download: http://www.alcpu.com/CoreTemp/CoreTemp.zip
russellmrgn
  • CAPTAIN
Real Temp - New temp program for Intel Core processors
http://www.xtremesystems.org/forums/showthread.php?t=179044
Russ
:biggthumbsup: Proud to be Folding for Team MSI :biggthumbsup:
PC Details :-
Case: Antec P160
Case Fan: Akasa Amber 120 x2
M/Board: MSI K8N  Platinum SLI (MS-7100)
BIOS: Award 3.9
CPU: AMD 64 4400 Dual Core
Heatsink: Thermalright Si-120 & Tt Silent Cat 120 Fan
Memory:  2GB Corsair 3500LL Pro (2x 1GB)
Graphics: AOpen Aeolus 7800 GTX x2
H/Drive: WD 74GB Raptor x2 Raid 0
            WD 250GB x2 Raid 0 (16mb Cache sata-2)
Sound: Creative X-Fi Extreme Music
PSU: Seasonic S12 600w
Drives: Pioneer 110 x2 & Sony Floppy
Monitor: DELL 2405FPW
OS: Win XP Pro SP2 / IE 6
  • T9246ED
  • Administrator
What Is MAXON CINEBENCH?
CINEBENCH is a real-world test suite that assesses your computer's performace capabilities. MAXON CINEBENCH is based on MAXON's award-winning animation software, CINEMA 4D, which is used extensively by studios and production houses worldwide for 3D content creation. MAXON software has been used in blockbuster movies such as Spider-Man, Star Wars, The Chronicles of Narnia and many more.
MAXON CINEBENCH runs several tests on your computer to measure the performance of the main processor and the graphics card under real world circumstances. The benchmark application makes use of up to 16 CPUs or CPU cores and is available for Windows (32-bit and 64-Bit) and Macintosh (PPC and Intel-based).
The resulting values among different operating systems are 100% comparable and therefore very useful with regard to purchasing decision-making. It can also be used as a marketing tool for hardware vendors or simply to compare hardware among colleagues or friends.
Details and download: http://www.maxon.net/pages/download/cinebench_e.html
AaronTopic starter
  • GENERAL
  • BOOST!
+ Added Real Temp v2.60 (Thanks to russellmrgn)
+ Added Cinebench R10 (Thanks to BOSSKILLER)
/ Updated AMD GPU Clock Tool to v0.9.8. (Thanks to AaronYuri  :-)) )
AaronTopic starter
  • GENERAL
  • BOOST!
Re: OCUBA - Overclocking Utilities and Benchmarking Applications
« Reply #108 on: 11-August-08, 19:05:08 »
+ IntelBurnTest:
IntelBurnTest
Simple command line based program to simplify the use of Intel's Linpack application.
Download
I found this application great, personally! Linpack is reported to be better than Prime95's tests.
  • T9246ED
  • Administrator
« Reply #109 on: 13-August-08, 10:27:24 »
CPUCalc 1.9.2
CPUCalc is an overclocking-calculator able to overclocking with many Intel and AMD processors.
You just need to set your wished clock and it calculates all other settings, for example. It automatically sets the correct CPU-RAM-ratio and Referenceclock:HTT-Ratio.
It´s also able to calculate the new TDP with the overclocked settings.
Download:
http://downloads.guru3d.com/CPUCalc-1.9.2-download-2017.html
GPU-Z 0.2.7
GPU-Z 0.2.7 is out and it supports catalyst 8.7 beta & latest forceware drivers.
Here is the list of changes :
    *  Added display for GPU release date.
    *  Added display for transistor count
    *  Added mouseover readings for sensors graph
    *  Correctly named the three on-die sensors of RV770 and RV730
    *  Added support for voltage regulator monitoring on HD 4870 and HD 4870 X2
    *  RV770 GPU on HD 4870 X2 now called R700
    *  Added support for reading HD 4870 X2 3D clocks
    *  Added display of CrossFire Sideport status on HD 4870 X2
    *  Added more RV730 device IDs
    *  Added support for GeForce 9800 GT, 9800M GT, 9600M GT, 9700M GS/GT, 9500M G
    *  Added detection for RS780D
    *  Fixed incorrectly read ATI OD5 clocks
    *  Fix for memory clock reading on RV730
    *  Fixed ROM reading on RV730
    *  Fixed crash when no supported card detected
    *  Sensor graph width adjusted when scrollbars visible
Download:
http://www.techpowerup.com/downloads/SysInfo/GPU-Z/
PhysX FluidMark v1.0.0
  PhysX FluidMark requires NVDIA PhysX drivers 8.08.01 or higher and the CUDA DLL (this DLL has to be copied in the benchmark folder if your Forceware drivers are < 177.79 or if you don't have a GeForce (Radeon, etc.)).
PhysX FluidMark is a physics benchmark based on NVIDIA PhysX engine. This benchmark performs a fluid simulation by imitating the renderering of lava. Real physics parameters such as viscosity are used. SPH (Smoothed Particle Hydrodynamics) algorithm is enabled to increase the realism of the simulation.
PhysX FluidMark can run in pure software mode (all calculations are done on the CPU), or in hardware mode. Hardware mode includes 2 kinds of hardware:
    * Ageia PhysX PPU
    * GeForce PhysX - GeForce 8/9/GTX200 graphics cards only
This benchmark exploits OpenGL for graphic acceleration and requires an OpenGL 2.0 compliant graphics card: NVIDIA GeForce 5/6/7/8/9/GTX200 (and higher), AMD/ATI Radeon 9600+, 1k/2k/3k/4k (and higher) or a S3 Graphics Chrome 400 series with the latest graphics drivers.
Download:
http://www.ozone3d.net/benchmarks/physx-fluidmark/
Score database:
http://www.ozone3d.net/benchmarks/physx_fluidmark_scores.php
Dwarden
  • SECOND LIEUTENANT
« Reply #110 on: 31-October-08, 12:00:40 »
just incase someone not posted this already
MotherBoard Monitor 5 with Intel Core CPU support including C2D/C2Q
http://www.thetechrepository.com/showthread.php?p=138
yeah the old school classic and father of all good hw monitoring programs :) is still alive and kicking
# Intel Core2Duo E8500 on # MSI P45 Platinum MS-7512 ver 1.1 , BIOS p0i with # 4x KINGMAX 1066+ DDR2 1024MB
# Sapphire ATI HD4670 512MB GDDR3, PCIe + # Creative Labs X-Fi Fatality PCI
# 3x WD RE2 WD3200YS 320GB SATA300, 3xSG500GB SATA300, 1x SG 320GB ATA100 + # DVD-RW Toshiba-Samsung SH-S183A +- some more drives
# Chieftec CFT-620A-12S 620W (30A@5V,33A@3.3V,25A@12V1/17A@12V2/16A@12V3)
# Microsoft Windows XP Pro Edition SP3 / WS2008 WorkStation ed.
  • T9246ED
  • Administrator
Download and details, RivaTuner 2.24b (MSI MOA Edition)
http://downloads.guru3d.com/RivaTuner-v2.24b-download-163.html
retiredat44
« Reply #112 on: 23-February-10, 10:02:02 »
That Calc util is old, and not updated..
their website forum doesn't work..
just a heads up..
CPUCalc 1.9.2
Download:
GPU-Z 0.2.7
Download:
    * Ageia PhysX PPU
Download:
Score database:
wol-va-rine
I'm surprised LinX isn't on here, though maybe it's been suggested...? I didn't read all the posts...
miklkit
  • SECOND LIEUTENANT
The MSI 990FXA GD80 can not be overclocked with the latest versions of Control Center and Click Bios II.  I have earlier versions that do allow overclocking.  Is it allowed for them to be posted here?
MSI 990FXA-GD80 V2  bios V13.6
Windows 10
 G Skill Ripjaws 16gb @ 1920mhz
 AMD FX8370 @ 4.96ghz
Silverstone HE01 cpu cooler
 AMD R9 290X 8gb video card
Creative Soundblaster Z
2-500gb hard drives
24" BenQ @ 1920 X 1080
Sennheiser headphones
  • 微星科技
This is far from being updated. Post it and I'll add it in the initial post.
Windows 10 Pro
MSI MAG BUNKER Case
miklkit
  • SECOND LIEUTENANT
Windows 10
2-500gb hard drives
  • 微星科技
It's added
Windows 10 Pro
MSI MAG BUNKER Case
miklkit
  • SECOND LIEUTENANT
I and my Dropbox thank you.
Windows 10
2-500gb hard drives
miklkit
  • SECOND LIEUTENANT
I just found out that you posted links to my Dropbox for CC and CBII.  Is there any way for you to download them and post them in the 1st post so when my Dropbox gets closed they will still be available?
Windows 10
2-500gb hard drives
  • 微星科技
No, these are not linked to your dropbox! These are dropbox links but not yours'. Delete the files in your dropbox and you'll see.
Windows 10 Pro
MSI MAG BUNKER Case
miklkit
  • SECOND LIEUTENANT
 X-(( :worship:
Windows 10
2-500gb hard drives
Pages: 1 2 [3]  All   Go Up
