Pages: 1 [2] 3 4 ... 19   Go Down
Author Topic: Overclock Database 2.0  (Read 550396 times)
AaronTopic starter
  • GENERAL
  • BOOST!
Re: The Highest CPU Clocks On the Forum
« Reply #50 on: 25-May-07, 19:25:59 »
Added, Quadrifoglio Verde. :)
Refrain from having to solve most of your problems by not creating them in the first place.
DDR3 Memory Standards: Blurry Lines
Integrated Memory Controllers (IMC)
Intel EIST and Processor C-states
DryHeat
  • FIRST LIEUTENANT
  • Phoenix, AZ - USA
« Reply #51 on: 26-May-07, 01:27:18 »
I've given it all she's got:
E6300 1860 MHz @ 2981 MHz = 60% OC
CPU-Z Validation
- Antec P180 Case
- Asus/Pegatron Benicia G33 Express Mobo (ripped from HP m9300t)
- Intel Core 2 Quad Q9450
- Arctic Freezer 7 Pro
- 3GB Corsair XMS2 (2x1GB) (2 x 512MB) CAS5 @ 5-5-5-18 (1:1 Ratio - 1.8V) 800 MHz
- EVGA 9600GT 512MB
- SATA DVD/CD Writer
- 2x Seagate 7200.10 320GB
- 1x WD 500GB SATA II
- Corsair 750W PSU (+3.3V@30A,+5V@28A,+12V@60A,12V@0.8A,+5VSB@3.0A)
- HP w2207 Monitor
ANewPrelusion
  • SERGEANT
« Reply #52 on: 06-June-07, 03:16:39 »
Yay! Here's my ridiculously unstable OC.
E6600 @ 3698.17 MHz
54% OC
http://valid.x86-secret.com/show_oc.php?id=205392
I'd rather not exceed 1.45V on air for any higher  :undecided:
Please add me to the list.
Thank You
Coolermaster Mystique RC-632
Core2 Duo E6600 w/ Thermalright Ultra 120 Extreme
MSI 975x Platinum Power Up Edition
4x  1Gb Corsair XMS2 DDR2 800 4-4-4-12
MSI 7900 GTX 512MB PCIE
1x 150 GB Western Digital Raptor X
1x 74 GB Western Digital Raptor
1x 320 GB Western Digital SATA
madmav
« Reply #53 on: 06-June-07, 04:36:08 »
Count me in too  :biggthumbsup: Core 2 Duo 6420 (Conroe) 3200Ghz - windows stable, even can run orthos for some time   ;-))
Hey Quadrifoglio you are running your Ram in single channel  :rolleyes: ? The CPU-Z Validation shows it is single.
Stick
  • LIEUTENANT COLONEL
« Reply #54 on: 06-June-07, 07:03:21 »
my OC is in the sig, but that is the regular operating speed. i have to redo the 2.7 GHz OC and get the CPU-Z validation for it.
so, CBBID0451 Winnie 3000+ (200 X 9) @ 2601 MHz, ~+44.5%. if i remember correctly, there was no winnie 3000+ that passed 2750 on stock cooling. the highest i hit on mine was 2710, but windows was locking up at loading. with some memory tweaking it would've booted at that speed.
A64 3000+ Winchester Sk939 CBBID 0451 (289.11x9 - 2601.95 MHz - stock cooling, 46C full load, using clockgen)
http://valid.x86-secret.com/show_oc.php?id=25523
MSI K8N SLI PLatinum
Asus Extreme N6600GT/TD/128M(@600/1300) - replaced with HIS ATI HD 4560
2x512 Geil Ultra (2-2-2-5)
2x160GB WD IDE
DVD-RW LG4160B
Philips 170S5 LCD, Liteon 19"CRT
Logitech X-530
SBLive 24bits 7.1 onboard
Thermaltake Purepower 480W
Fujitsu Siemens Amilo M3438G, Pentium M 760 (2.0 GHz), 2 x 1GB Kingston DDR2 533 MHz, 2 x 100 GB Fujitsu S-ATA 5400 rpm - RAID-0, GeForce Go 6800 - 3850 3dmark05, 17"
Acer Aspire 7730G, Core2Duo T9800 (2.8 Ghz), 2 x 2 GB Hynix DDR2 800 MHz, 2 x Seagate S-ATA 7200 rpm, GeForce 9600M GT, 17"
AaronTopic starter
  • GENERAL
  • BOOST!
« Reply #55 on: 06-June-07, 07:17:42 »
madmav,
You need a CPU-Z validation.
DazBoz
  • SERGEANT
« Reply #56 on: 07-June-07, 11:48:27 »
Hi, just broke 400fsb by replacing my Geil 6400 with some G.SKILL 6400
Vcore at 'auto' so sure there is more to come :)
http://valid.x86-secret.com/show_oc.php?id=205794
Core2duo 6400 @ 3.2GHZ,default vcore,Artic Freezer 7pro,
MSI 975x platinum PUE @400FSB,
2GB G.SKILL 6400cl4d-PK @800mhz,  4,4,4,12
Seagate 7200.10 320GB,
HIS ICEQ3 X1900XT 512MB,
X-FI Fatality,
Enermax Noisetaker 480W PSU.
madmav
« Reply #57 on: 07-June-07, 15:54:05 »
Here it is - the CPU-Z validation - i am sure it can boot even at 410 or more but i just don't wont to reset the bios at some point  ;-))
Edit: op i booted with 425 FSB :P enough stable to validate it :D ( i needed to reset the bios haha, it can run even more only if you don't let it do cold reboots  :biggthumbsup: )
http://valid.x86-secret.com/show_oc?id=205867
Quadrifoglio Verde
  • MAJOR
  • The liver is evil...it deserves to be punished!
« Reply #58 on: 07-June-07, 18:16:09 »
I know...
Desktop
MSI 790FX-GD70 / AMD Phenom II X4 965 Black Edition / Scythe Ninja / 2 x 4 GB Patriot DDR3-1600 / HIS Radeon HD 5770 1 GB IceQ 5 / Lian Li V1000 Plus II / Seasonic M12 II 520 / Samsung SH-S182D / 2 x Intel X25-M Postville 160 GB / 2 x Seagate Momentus 7200.4 500 GB / Enermax Aurora Premium (black) / Logitech MX518 / Logitech Z-10 / Eizo S2431WH-BK (landscape) + Eizo S2201WH-BK (portrait)
HTPC
MSI 785GME65 / AMD Athlon II X4 600e / 2 x 2 GB OCZ DDR3-1333 / Antec NSK1380 / 2 x Seagate Barracuda 7200.11 1 TB / Intel X25-M Postville 80 GB / LG Blu-Ray
Quadrifoglio Verde
  • MAJOR
« Reply #59 on: 10-June-07, 18:16:15 »
*bump*
New OC:
Core 2 Duo E4300 @ 3510 MHz (390 x 9) - 95% OC
CPU-Z validation:
click
 :yes:
*edit*
AaronYuri?  ;-))
Desktop
HTPC
Bio-Hazard
  • CORPORAL
« Reply #60 on: 13-June-07, 07:41:18 »
OK, can I play along too........... :shocked:
Here's my little E4300, not to bad I guess.......... :-P)
3712.45 MHz (412.49 * 9)
http://valid.x86-secret.com/show_oc.php?id=187008
Mountain Mods U2 UFO case
MSI P35 Platinum Combo
Q6600 @ 3.6
Kingston PC3-11000
BFG 8800GT
OCZ 700w
WD SE16 250
Lite-On SATA DVDRW
Dual loop Water Cooling (Swiftech)
Stick
« Reply #61 on: 13-June-07, 08:30:19 »
bio-hazard, was it stable? how's the temps under load with water cooling?
2x160GB WD IDE
DVD-RW LG4160B
Logitech X-530
Bio-Hazard
  • CORPORAL
« Reply #62 on: 13-June-07, 08:41:34 »
Nope, not stable, but stable enough to run some SuperPi and a few other benchmarks.
I have no idea what full load temps get up to .............it won't stay running long enough under full load to fully heat the thing up. But in Bios is reporting around 30c on a average morning idle.
Q6600 @ 3.6
Kingston PC3-11000
BFG 8800GT
OCZ 700w
WD SE16 250
Lite-On SATA DVDRW
AaronTopic starter
  • GENERAL
  • BOOST!
« Reply #63 on: 15-June-07, 19:42:04 »
And an update: I just had my E6600 @ 398xMHz, however I'm having posting trouble with the board @ 425+FSB. I managed to run SuperPI in 12 seconds though. I'll post a validation when I can get the board to boot @ 440FSB again. This board seems to decide when it wants to complete POST. It always freezes just before verifying DMI pool data.
I'll make all the changes now, I haven't been looking in on the thread. :bonk:
OK, all changes have been made. ;D
After two hours of tweaking:
Check this out!! http://valid.x86-secret.com/show_oc?id=208433
aicjofs
  • MAJOR
  • Pop the Top!!
« Reply #64 on: 15-June-07, 22:05:40 »
Now thats how to get it done Aaron.   :biggthumbsup: Good job, that's what a skilled clocker should be getting for a E6600 that board and the cooling.  Very nice...
Asus Maximus Formula(Rampage mod)
Q6600 (8x458) @ 3666Mhz 1.5V
2x2GB Gskill PC8000 5-5-3-13 @ 550Mhz (1100 DDR) 2.1V
EVGA 8800 GTs(700/1000)
2x640 GB Western Digital in RAID 0
NEC-3500 DVD, LiteOn LTD-163
X-FI extreme music
PC Power and Cooling 610W 3.3v - 24a 5v - 30a 12v - 49a
Dell e207FPW 20.1" Widescreen LCD
Watercooling: Dtek Fuzion, Iwaki MD-20, Thermochill PA120.3, 4 Yate Loon D12SM-12
AaronTopic starter
  • GENERAL
  • BOOST!
« Reply #65 on: 15-June-07, 22:15:28 »
Cheers for the complimant aicjofs. :)
I shall keep pushing the barrier, I'm gonna drop a 3400rpm fan on the Scythe and see if I can go any higher.
Stick
« Reply #66 on: 16-June-07, 03:21:05 »
that's excellent. congratulations on 4GHz  ;-))
2x160GB WD IDE
DVD-RW LG4160B
Logitech X-530
AaronTopic starter
  • GENERAL
  • BOOST!
« Reply #67 on: 16-June-07, 03:32:43 »
Thanks Stick. As soon as I can break this 455FSB barrier, I assure you, more shall be coming. :yes:
Exo
  • MAJOR
« Reply #68 on: 16-June-07, 05:29:11 »
Yes, that's the way... None of these silent fans that don't move any air.
Let it make noise, it needs to cool !!  :lol_anim:
AaronTopic starter
  • GENERAL
  • BOOST!
« Reply #69 on: 16-June-07, 05:35:59 »
A very lot!! It took 1.6v just to get it into Windows @ 4GHz. :shocked_anim:
Well @ 3.6GHz I'm on 56c on both cores load. Orthos for 2 hours. Passes any benches, can't run TAT, don't work on 64-bit, damn thing! :biggthumbsdown:
When I get around this 455FSB barrier I'll hopefully get 4.2GHz just to be top of the list. ;D
Bio-Hazard
  • CORPORAL
« Reply #70 on: 16-June-07, 09:02:28 »
You missed the Top 10 (%) listing.............. :shocked_anim: My little E4300 is over a 100% OC............... :idea:
Q6600 @ 3.6
Kingston PC3-11000
BFG 8800GT
OCZ 700w
WD SE16 250
Lite-On SATA DVDRW
AaronTopic starter
  • GENERAL
  • BOOST!
« Reply #71 on: 16-June-07, 10:52:19 »
Bio-Hazard,
I couldn't add it, you never said how much it was. I'll add it now.
Bio-Hazard
  • CORPORAL
« Reply #72 on: 16-June-07, 17:25:55 »
Opps, sorry, my bad........thanks.........:)
Q6600 @ 3.6
Kingston PC3-11000
BFG 8800GT
OCZ 700w
WD SE16 250
Lite-On SATA DVDRW
bishbosh
« Reply #73 on: 18-June-07, 02:52:02 »
Bio-Hazard,
In that case, could you add me to the Top 10 (%) listing as well?
This post https://forum-en.msi.com/index.php?topic=107990.msg801536#msg801536 shows more.
Cheers
bishbosh
frans2h
  • STAFF SERGEANT
« Reply #74 on: 27-June-07, 10:40:49 »
Hi All...just got my 975x PUE at 3367 Mhz ( 420 x 8 ) and stable after 24 hour prime95....but still looking to used lower vcore..i'm at 1.4v ( Bios Setting ) and idle 53c, load 56c...
http://valid.x86-secret.com/show_oc.php?id=212051
My Rig :MSI Big Bang XPower, Core i7 980X, Corsair DDR3 Domi GT 2000C8, Enermax Revo 1050, Danamix LMX Cooling, Corsair Nova 64GB, 1 x WD Velo 150GB , 1 x WD Black 1TB, MSI R5970 CFX and MSI GTX 465 as physix card,  Lian Li AF-71A Case, 24" LED Cinema Display
AaronTopic starter
  • GENERAL
  • BOOST!
« Reply #75 on: 27-June-07, 11:21:01 »
Added. :biggthumbsup:
BG84
« Reply #76 on: 13-August-07, 08:09:45 »
thanx Aaron for adding me
sorry Lt_JWS   :lol_anim:
  • 微星科技
« Reply #77 on: 13-August-07, 08:54:54 »
Aaron,
would you mind adding me to place 4 in AMD section just after BK who is 9 mhz ahead of me (see sig: opteron 165 @ 2871mhz, 60% oc) ? ;-))
Windows 10 Pro
MSI MAG BUNKER Case
AaronTopic starter
  • GENERAL
  • BOOST!
« Reply #78 on: 13-August-07, 10:26:32 »
Aaron,
Done. :biggthumbsup:
  • 微星科技
« Reply #79 on: 13-August-07, 11:08:44 »
 ;D Thanks a lot!
Windows 10 Pro
MSI MAG BUNKER Case
  • 微星科技
« Reply #80 on: 16-August-07, 14:24:12 »
Aaron, I hope you won't get mad at me but I tweaked a little for this suicide shot: http://valid.x86-secret.com/show_oc.php?id=230288
So ending up in 2952mhz, 64% oc with my opteron 165 "Denmark". 81mhz more than everyday clocking and stable enough for posting and cpuz ;-))
It would be very nice if you could change the ranking :hypocrite:
Windows 10 Pro
MSI MAG BUNKER Case
Quadrifoglio Verde
  • MAJOR
« Reply #81 on: 20-August-07, 07:42:51 »
New cpu and some new OC results:
E6600 running Orthos stable at 464 x 7 = 3248 MHz
Not that big of an OC, but the motherboard runs this amazing FSB still without changing any motherboard related voltages. It only required a DRAM voltage of 2.2v (which is the rated voltage for my memory) and a Vcore bump to 1.325v.
Northbridge core clock at an amazing QDR of 2388 MHz without breaking a sweat. Damn, this is easy... :yes:
Desktop
HTPC
4n70n
  • SERGEANT
« Reply #82 on: 20-August-07, 23:03:25 »
Just quick test MSI P35 Platinum Combo with E6850 G0
http://valid.x86-secret.com/show_oc.php?id=227210
ASUS Maximus V Gene
i7 3770K
8GB DDR3 Kingston HyperX 2133
MSI 560GTX Ti TF2
Pioneer 217
300GB Velociraptor + 80GB SSD Intel X25M + 2TB WDC Black +  2TB Hitachi
850W Corsair HX
19" LG 196WTQ
Pichu
« Reply #83 on: 26-August-07, 19:09:27 »
My Sandiego 3700+ at K8N SLI FI with moded platinum bios ( thx bosskiller ;) )
2905MHz
http://valid.x86-secret.com/show_oc.php?id=234934
  • 微星科技
« Reply #84 on: 27-August-07, 02:14:30 »
Congratz, nice work! K8N Sli Fi does really rock when modded.
Although a little ungrateful to claim Bosskillers rank 4 ....  ;-))
Windows 10 Pro
MSI MAG BUNKER Case
Pichu
« Reply #85 on: 27-August-07, 02:58:49 »
New Result:
2948MHz and if i want higher i must change cooling system because i have poor  :(
http://valid.x86-secret.com/show_oc.php?id=235019
  • T9246ED
  • Administrator
« Reply #86 on: 27-August-07, 06:04:28 »
New Result:
hmm very nice :biggthumbsup:
vcore used? underload temp?
Pichu
« Reply #87 on: 27-August-07, 06:36:41 »
Vcore 1.53 Temp in underload 47 (Core)
Not stable in prime95
  • 微星科技
« Reply #88 on: 27-August-07, 06:38:39 »
47'C under load? That is very good, very low load temp.
Windows 10 Pro
MSI MAG BUNKER Case
Pichu
« Reply #89 on: 27-August-07, 06:39:35 »
Temp is low but CPU is not stable :(
Cpu over 2750MHz cannot pass prime95 stress test ( More volts to cpu cannot change anything)
  • 微星科技
« Reply #90 on: 27-August-07, 06:41:48 »
Clock is too high, reduce htt in 5mhz steps. When stable try increasing in 1mhz steps 'til unstable then go back one mhz of htt
Windows 10 Pro
MSI MAG BUNKER Case
Pichu
« Reply #91 on: 27-August-07, 06:47:29 »
I'm bench my computer with old 3dmark2001se because i want to beat my own record, and over 2640MHz results are lower than in lower CPU speeds. Why??
  • 微星科技
« Reply #92 on: 27-August-07, 06:58:54 »
Are you setting a different (lower) mem divider to get higher cpu clocks? I saw you were running the sticks with just 173.4 MHz to reach 2942mhz
Windows 10 Pro
MSI MAG BUNKER Case
Pichu
« Reply #93 on: 27-August-07, 07:01:11 »
Yes i set memory divider to lower because my 4 kingston sticks don't tolerate higher mhz, this is only DDR400 :/
  • 微星科技
« Reply #94 on: 27-August-07, 07:05:29 »
Then you are getting lower results because of the lower mem clock
Windows 10 Pro
MSI MAG BUNKER Case
Pichu
« Reply #95 on: 27-August-07, 07:24:51 »
Then i must change my sticks and cpu cooler to other..... Big THX for advices flobelix ;)
  • T9246ED
  • Administrator
« Reply #96 on: 27-August-07, 07:26:15 »
also made a tests with 3dmark 06 which is sensitive to the CPU freq.
  • 微星科技
« Reply #97 on: 27-August-07, 07:28:14 »
 :biggthumbsup: Not at all, glad I could help
Windows 10 Pro
MSI MAG BUNKER Case
AaronTopic starter
  • GENERAL
  • BOOST!
« Reply #98 on: 27-August-07, 16:50:58 »
And NB clock, just going from 400 to 450 and dropping multi to 8, I get another 100 points on CPU bench. ;D
I'll add all the new additions now...
EDIT: I'm beaing beaten by 10MHz... Not for long! :hypocrite:
Update: Listed new people, added a stable section too.
  • 微星科技
« Reply #99 on: 27-August-07, 17:11:51 »
Good Idea with stable ranking
Well, then I'm offering my stable everyday setting of 2871mhz (see sig) for stable ranking. Although I think the Intel cpus will kick me out of the ranking as their stable default clocks are mostly higher. Maybe this should also be divided into an Intel and an AMD section.
Windows 10 Pro
MSI MAG BUNKER Case
Pages: 1 [2] 3 4 ... 19   Go Up
