Pages: 1 ... 54 55 [56]   Go Down
Author Topic: MSI Forum HQ USB flashing tool!!!  (Read 628263 times)
233419999
Re: MSI Forum HQ USB flashing tool!!!
« Reply #2750 on: 17-March-18, 02:04:44 »
oki
https://drive.google.com/file/d/1eIqKreUOfTN-gW5OXU_CxLwdqyADoS_7/view?usp=sharing
* Close any Windows app. that can be closed, especially Antivirus or any other resident scanners.
* Extract all files from proceed_B350_TOMAHAWK_190.rar to some folder
* Run proceed.exe, and confirm with "Y" when asked to update the BIOS
* Reboot computer when its done
Hi, Svet,
Could I get the same one to flash back to 7A37V16 on B350M MOTAR?
Thanks
Best regards
angelprcamilo2011
« Reply #2751 on: 24-March-18, 23:48:09 »
Hi, I'm trying to flash back my MSI B350M-BAZOOKA from version [font=DINPro-Regular, Arial, Verdana, Geneva, 微軟正黑體, sans-serif, sans-serif]7A38v1C to [/font][/color][font=DINPro-Regular, Arial, Verdana, Geneva, 微軟正黑體, sans-serif, sans-serif]7A38v17 but i can't can some please help?[/font][/color]
angelprcamilo2011
« Reply #2752 on: 25-March-18, 12:39:35 »
Hi, I'm trying to flash back my MSI B350M-BAZOOKA from version 7A38v1C to 7A38v17 but i can't. Can someone please help?
SvetTopic starter
  • T9246ED, Бивша комета
  • Administrator
« Reply #2753 on: 14-April-18, 17:39:18 »
for downgrade you can use this new tool:
https://forum-en.msi.com/index.php?topic=302638.0
white_h2o82
« Reply #2754 on: 06-July-18, 15:18:55 »
I was able to flash the BIOS and get all the way through everything but now nothing is showing up on my screen and I can't get to the BIOS or anything.  Has anyone run into this before?  MSI Z270 SLI Plus.  Updated from v1.4 to v1.9.
  • 微星科技
« Reply #2755 on: 06-July-18, 15:45:51 »
Open your own thread about it. This thread is about the forum flash tool and nothing else. >>Please read and comply with the Forum Rules.<<
Windows 10 Pro
MSI MAG BUNKER Case
alberto.zanot
« Reply #2756 on: 17-July-18, 13:37:02 »
I followed everything carefully, but my usbkey wont boot from uefi.
F11 boot menu does not show the usbkey.
i tried to fix it with the tool, reformatting with the hp tool.
nothing.
  • 微星科技
« Reply #2757 on: 17-July-18, 13:51:51 »
Try a different stick. Also note that you need to boot the stick in legacy mode.
Windows 10 Pro
MSI MAG BUNKER Case
alberto.zanot
« Reply #2758 on: 17-July-18, 14:42:37 »
It worked, my fault formatting in FAT. FAT32 worked. Thanks anyway!
fitzger20
« Reply #2759 on: 25-August-18, 23:33:50 »
I have a msi 970 gaming board try to update the bios with live update after a moment it restarted and the black screen is now I can not enter the bios and worse windows ... please pray a lot for a help .. Thank you
SvetTopic starter
  • Administrator
« Reply #2760 on: 27-August-18, 10:57:35 »
@fitzger20
if you have some issue,
please open a new topic to correct area
we can't help with live update's related issues/questions here.
mladenlibe
« Reply #2761 on: 14-October-18, 08:20:21 »
Hello. I need some help. I have MSI p67s c43-b3 motherboard and before i was able to hit even 5ghz back in 2011 and later on i lowered the clock to 4.5 ghz for better temps and so on and i left those settings for like a year or more.One day my friend flashed the new bios for me and that is the moment i remember i started having problems with OC. Right now i have 2500k@4.2Ghz with 1.35V and i cant pass those 4.2 ghz because everytime i will get BSOD and trust me i tried everything and that is insane considering i had it on 5ghz before and 4.5ghz(with lover voltage) before.I think my problem is bios that i have (version 5.4 ivy bridge support) that is lowered my OC becase that is when the problem started. I need help to downgrade bios to lastest verison before ivy bridge bios support update because i wana try hit 5ghz again so i can drive my gtx 1080 Ti as best as i can while waiting for my cpu upgrade. I also need to know will the latest bios before ivy bridge support update support my gtx 1080 ti ?
Rest of my spec:
- CPU: Intel i5-2500K @ 4.2 GHz
- GPU: ASUS ROG STRIX GTX 1080 Ti 11GB GDDR5X
- RAM: Corsair Vengeance Pro DDR3 16GB @ 2133 MHz
- PSU: EVGA SuperNOVA 850W G2
- SSD: Samsung 850 EVO 250GB
- MB: MSI P67 C43-B3
- Mouse: ZOWIE by BenQ EC2-A
- Mousepad: Razer Goliathus Speed
- Headset: Kingston HyperX Cloud
- Keyboard: Corsair K65 Rapidfire
- Monitor: Dell Ultrasharp U2414H
- Bungee: ZOWIE Camade
SvetTopic starter
  • Administrator
« Reply #2762 on: 14-October-18, 12:38:09 »
@mladenlibe
best open a new topic in the correct area,
your questions are not about bios flashing
mladenlibe
« Reply #2763 on: 14-October-18, 14:06:15 »
@mladenlibe
Well actually it is. I need help to flash(downgrade) bios before ivy bridge update and i dont know will that bios support gtx 1080 ti.
SvetTopic starter
  • Administrator
« Reply #2764 on: 15-October-18, 09:11:27 »
if you flash back to non ivy bridge bios,
your video card listed will not works in there.
vibarn
  • CORPORAL
« Reply #2765 on: 16-October-18, 05:47:42 »
hello
i need some help before i do something wrong
i m going from 2500k to 3770k on my msi p67 gd55 b3
so i need to flash the bios as mine is v1.9
just saw this tool and tried to use flobelix 8 steps advice he gave to someone in the same situation here :https://forum-en.msi.com/index.php?topic=292444.0
anyway after i point the tool at the compressed archive E7681ims 430.rar and confirm fat32 usd drive location it start working and then stop, saying something in app data isnt a valid internal comand
win7 64 usb is a sandisk 16g
note that avira poped out quarantine the process the first time i tried
have shut down real time protection avira do not pop anymore but the tool error still the same
sry for my english
SvetTopic starter
  • Administrator
« Reply #2766 on: 16-October-18, 12:21:54 »
try prepare the USB key in another computer
44fire44
« Reply #2767 on: 30-October-18, 14:26:07 »
Okay, i'm stuck here
I have a Z68A-GD65 (G3) motherboard running currently BIOS version N.70 (E7681IMS.N70)
Got the latest BIOS from here: http://download.msi.com/bos_exe/mb/7681vP8.zip
1: When I download and try to use E7681IMS.P80 inside the BIOS utility, I'm told that there ain't any files on the USB i've inserted
2: If I rename the file to E7681IMS.N70, the BIOS utility finds it but informs that the file is not for this motherboard and it's not recommended to upgrade - when i did it I had to reset motherboard to factory settings
3: When I use the BIOS UPDATE 1.10 tool from MSI, I'm told that it's unable to allocate memory and it reverting
4: When I use the EFI Flash tool 1.05, I'm informed that "Using the wrong AFU version. Please use Aptio 4 AFU"
5: When I use the USB designed from here, I'm informed that it's the wrong flashfile and it reverts
Can somebody help me out here? - is it the wrong file I'm trying to use? - I've tried with the .P10 as well, with same results...
  • 微星科技
« Reply #2768 on: 30-October-18, 17:08:37 »
Your post has been split off to a new thread for a purpose. No need to post here again. Go to your own thread: https://forum-en.msi.com/index.php?topic=310698.0
Windows 10 Pro
MSI MAG BUNKER Case
haesum
« Reply #2769 on: 27-November-18, 11:57:11 »
When I attempt to run the flashing tool, I get the following error in the app:
Furthermore windows asks me if I want to use a program to open a file.
How do I proceed from here?
EDIT: Running Windows in safe-mode does not make it work any different.
SvetTopic starter
  • Administrator
« Reply #2770 on: 27-November-18, 12:22:11 »
for Win10 1809 use this new beta instead:
http://www.mediafire.com/file/jd6tp9fmahzf4o1/INdeb.rar/file
haesum
« Reply #2771 on: 27-November-18, 18:15:39 »
Thank you so much, Svet! You are a god-sent genius! The tool worked like a charm!
Stellarspace
« Reply #2772 on: 24-December-18, 21:36:59 »
Is there any reason 9C would be displayed when booting with the USB Drive plugged into the computer? I am using a MSI 990FXA GAMING motherboard. Do I boot the USB Drive in UEFI or Legacy?
badboy2k
« Reply #2773 on: 24-December-18, 21:58:10 »
9C is a error with the USB device that is plugged in not being properly detected
what USB Device is causing the issue you can work it out by unplugging devices one by one?
Cooler: corsair H100 cooler
SvetTopic starter
  • Administrator
« Reply #2774 on: 26-December-18, 10:05:14 »
9C can be the issue only if its stuck there and didn't moves further
else its just a regular checkpoint code.
illustrious_hefe
« Reply #2775 on: 12-January-19, 14:35:54 »
Can anyone attach the flashing tool onto a post? I can't seem to download the tool from the link in the first post, no matter what I do. The media fire site gives me an error that the file can't be found, or the entire site gives me a "connection was reset" error. :bonk:
SvetTopic starter
  • Administrator
« Reply #2776 on: 14-January-19, 08:05:24 »
download link works fine
nope, its too big size to be attached in a forum post
forum post attach size is very limited mainly only for simple generic images
roberto.salvino
« Reply #2777 on: 13-February-19, 04:31:06 »
Good Morning Svet, one year ago i contact you for have the modded bios, i want to know if there is an updated version, Can we talk by private message?
Thanks for everything you do :).
EDIT Svet: Yes, we can. Check PM & emails.
hungh13
« Reply #2778 on: 17-February-19, 21:03:38 »
I need help flashing bios to 5.4 so I can use and Ivy Bridge Intel CPU but I tried everything and it doesn't seem to work.
Bios Link https://www.msi.com/Motherboard/support/P67SC43_B3#down-bios
So, what I have done so far.
1. I downloaded the bios 5.4 but it is in .exe format and stated that I put it on USB drive, execute it, then it will restarts comp. I did that and it restarted comp, even put it as bootup drive. It stated everything is completed but bios still shown E7673IMS V1.19 in the BIOS program.
2. I use the Forum HQ USB flashing tool, but there is no .ZIP/.RAR file of my bios. I tried searching a file in the USB Drive and it found a file, ran it, and told me to restart comp. I restarted comp, boot as USB, ran it, and then it said ROM file ROMID is not compatible with existing BIOS ROMID.
I really need help flashing the bios. Please help! Thank you.
Motherboard I use P67S-C43 (B3)
Current Bios E7673IMS V1.19
Win10 64bit
SvetTopic starter
  • Administrator
« Reply #2779 on: 18-February-19, 08:27:18 »
Win10 64bit
use this archive when preparing the USB key with Mode 1
https://www.mediafire.com/file/f5kkb0k32x95jms/E7673IMS.552_valcheck.rar/file
richard.fay
« Reply #2780 on: 28-February-19, 11:05:19 »
I just want to double check to make absolutely sure: on the OP, with the download, it says "Attached files are visible to logged-in users," but I am logged in and no new attachment has shown up. Below that is a mediafire link called INdeb. Should I be downloading the INdeb file, or is the file attached to the OP and I can't see it for some reason?
Stupid question I'm sure, but I'd appreciate any help!
SvetTopic starter
  • Administrator
« Reply #2781 on: 28-February-19, 11:09:20 »
yes the link is fine, its no longer attached after version update
because forum server don't provide enough space for file attachment anymore
rhettbohling
« Reply #2782 on: 19-March-19, 03:26:26 »
I am trying install ubuntu. I cannot install until I update BIOS firmware. I cannot seem to update BIOS.
How do I get around this?
Board: MSI A78M-E45 V2
VGA: MSI GEFORCE GT710
CPU: AMD Athlon(tm) X4 750k Quad Core
 MEM: 2x8GB, HyperX
 OS: None at this time
BIOS Version: E7721AMS V5.0
  • 微星科技
« Reply #2783 on: 20-March-19, 10:22:47 »
Please open your own thread in AMD motherboard section. Your question is not directly related to the forum tool.
Windows 10 Pro
MSI MAG BUNKER Case
asteroide404
« Reply #2784 on: 21-March-19, 18:17:49 »
Hi everyone !
I have an MSI Z77a GD65
I have succesfully find the last bios version from MSI HQ Forum and do the preparation of the USB key with success !
I can boot from the USB key
But when i launch the flash from the DOS menu of the USB key
this message in blue appears :
"You are not authorized to perform this action"
And then, the screen of the end of flashing (i suppose) appears...
How can i get the authorization to perform this action please ?
SvetTopic starter
  • Administrator
« Reply #2785 on: 21-March-19, 18:55:39 »
@asteroide404
I've updated the version,
re-download new one, and try again
andols91
« Reply #2786 on: 27-March-19, 07:53:10 »
Hi!
I've been trying to update my BIOS.
I have a msi Z87-G45 Gaming motherboard and have downloaded the 1.8 version (1.9's file seems broken) from:
https://www.msi.com/Motherboard/support/z87-g45-gaming
My current BIOS version is 1.2
I've set my BIOS to [Legacy + UEFI] (only have option for UEFI or both), fixed my USB with the tool, used the tool to get the files on it but it still boots normally after I choose to boot from the USB after I've pressed F11 (Tried both with the one named "UEFI:"at the start and the one without), only difference is that before the Windows logo there's a black screen with a blinking underscore and than after Windows loads it opens the USB to see the files.
SvetTopic starter
  • Administrator
« Reply #2787 on: 28-March-19, 09:17:29 »
Hi!
I see the flasher is missing for 1.9,
you can use Mode2 to flash it in such case
Have you done "Fix My USB key" tool's option 1st?
andols91
« Reply #2788 on: 28-March-19, 11:53:09 »
Okay, I'll add that instead of 1,8 then.
I have done the "Fix My USB Key" option before adding the file with 1,8 to the USB. Would it make any difference to use the "HP USB Boot Utility" instead?
SvetTopic starter
  • Administrator
« Reply #2789 on: 28-March-19, 14:07:58 »
use this then, pickup Rufus:
https://rufus.ie
and make it bootable with "FreeDOS"
then re-run the tool but skip fix my usb key
go directly with mode1 and rest of stuffs
hardi.hama12
« Reply #2790 on: 07-April-19, 07:19:43 »
Hi i Need a DS 200 mouse driver for windows 10 i would appreciate it if someone help
SvetTopic starter
  • Administrator
« Reply #2791 on: 08-April-19, 11:20:35 »
@hardi.hama12
open new own topic in correct area
Pages: 1 ... 54 55 [56]   Go Up
