Author Topic: Q: How to identify (if affected) defective AMD/ATI RX2400/RX2600 cards?  (Read 4910 times)
BlackTigerAP
AMD software let defective graphics cards slip into the channel
AMD reiterates no recall needed for defective graphics cards
I've recently bough new video for my system, MSI RX2600XT 512MB GDDR3 HEATPIPE.
I didn't install that card into system yet, but want to know does this (see article) affected my card?
How to identify? Can this issue be fixed (if found) only by BIOS update or I have to return card to my local reseller?
  • T9246ED, Бивша комета
  • Administrator
« Reply #1 on: 02-August-07, 13:33:07 »
  • Best Answer
  • best ask MSI here: http://support.msi.com.tw/
    neilshep
    « Reply #2 on: 08-August-07, 10:33:46 »
    I'd be interested to find out if you had better luck than me! See my thread today.
    BlackTigerAP
    « Reply #3 on: 08-August-07, 10:57:41 »
    I don't have any replies from MSI SUPPORT team (2nd week already).
    I will wait for the answer for the next couple of years (centuries?)...
    Hopefully, my card isn't affected by that issue.
    I've installed it into my system and it works perfectly.  :worship:
    neilshep
    « Reply #4 on: 08-August-07, 11:39:04 »
    Cool, glad it worked out for you. Have you tried running 3dmark or Cyberlink PowerDVDUltra?
    As a matter of interest do you know what Catalyst drivers your running? 7.7?
    Cheers,
    Neil
    BlackTigerAP
    « Reply #5 on: 08-August-07, 14:42:22 »
    I'll try to run 3dmark later.
    Yep, 7.7
    grimskull
    « Reply #6 on: 14-August-07, 11:46:12 »
    Hi
    There is no defective cards.
    http://forums.techpowerup.com/showthread.php?t=37230
    Hope this helps
    Grimskull
    BlackTigerAP
    « Reply #7 on: 14-August-07, 11:52:56 »
    Glad to hear it!
    Mike
    • aka Frankenputer
    • Virginia, USA
    « Reply #8 on: 14-August-07, 18:51:34 »
  • Best Answer
  • Quote from: Daily Tech
    One AMD engineer, also speaking on terms of anonymity, claim that there are no cards in the channel with a UVD problem and they are unaware of faulty products leaving the factory.  "Any report claiming that defective HD 2600 and 2400 [cards] are recalled in the channel is completely untrue."
    Perhaps a change in thread title is in order.
    #2:
    MSI Wind U100
    usamike
    « Reply #9 on: 15-August-07, 20:13:16 »
    hi !
    i have one of this defective card !
    the symptoms :
    - windows display a "bizarre" bios information (advanced display property ) with XXXX instead real number
    - in my case too, it displays 512 Mo for my HD2400 256Mo !!
    - and some resolution like 1680x1050 (for 22'' monitor) don't display correctly (hasardousat reboot)
    now, i just tried to flash the bios with the 6.10 release here :
    http://global.msi.com.tw/index.php?func=downloaddetail&type=bios&maincat_no=130&prod_no=1248
    but i had a error message "update failed".
    at the computer reboot, no signal and so no beep from the motherboard !!!
    doesn't anyone know how to build a floppy disk restore VGA bios ?
    help lpease, i sweep ;-(( ;-((
    Mike (from FRANCE)
    Aaron
    • GENERAL
    • BOOST!
    « Reply #10 on: 15-August-07, 20:17:46 »
  • Best Answer
  • usamike,
    According to AMD, there was no deffective cards.
    You should of opened a thread and tried to fix your problem before jumping to BIOS updates.
    All you can do is get a PCI VGA card, use that, then try and flash your 2400 again. Otherwise you will have to RMA it.
    Refrain from having to solve most of your problems by not creating them in the first place.
    DDR3 Memory Standards: Blurry Lines
    Integrated Memory Controllers (IMC)
    Intel EIST and Processor C-states
    Overclock Database 2.0
    BlackTigerAP
    « Reply #11 on: 16-August-07, 04:57:58 »
    Who knows... May be they are just lying because of "good merketingish face".
    But my MSI RX2600XT works well.
    Or probably you have "just a defective" card.
    usamike
    « Reply #12 on: 16-August-07, 07:52:09 »
    i don't know if the problem came from ATI manufacturing or MSI packaging structure but here (in france) there are many cases of msi 2400 HD 256 mo ddr2 defective. even, one shop had more ten card defective !
