Author Topic: 8800GTS OC crashing when running any 3d apps  (Read 3729 times)
JorntTopic starter
« on: 03-November-07, 20:37:34 »
I have just installed a 320 8800GTS HD OC, but everytime I run a 3d application, the system just shuts down after a while. While this may look like an overheating problem, the logs show that nothing is overheating at all (I'll just show the last 5 values before each crash), the temperature of the cpu remains at a steady 40 to 45 degrees through all this.
wow:
NVMonitor
Current TimeGpu core(3D)(MHz):GPU memory(MHz):GPU1:(ºC)CPU(%):Disk(%):Network(%):Memory(%):
2007/11/3 19:31:11576.0837.07760 %0 %0 %54 %
2007/11/3 19:31:13576.0  837.07761 %0 %0 %54 %
2007/11/3 19:31:15576.0837.07762 %1 %0 %54 %
2007/11/3 19:31:17 576.0837.07763 %0 %0 %54 %
2007/11/3 19:31:19 576.0837.07761 %0 %0 %54 %
Speedfan
Vcore1Vcore2+3.3V+5V+12V-12V-5V+5VVbat
1,341,93,385,0812,03-0,18-8,485,113,09
1,341,93,385,1112,03-0,18-8,485,083,09
Bioshock
NVMonitor
2007/11/3 19:46:21576.0837.07877 %0 %0 %53 %
2007/11/3 19:46:23576.0837.07984 %0 %0 %53 %
2007/11/3 19:46:25576.0837.07882 %0 %0 %53 %
2007/11/3 19:46:27576.0837.07981 %0 %0 %53 %
2007/11/3 19:46:29576.0837.07880 %0 %0 %53 %
Speedfan
1,361,93,385,1611,65-0,27-8,485,083,09
The system consists of:
mobo: Gigabyte GA-MA69G-S3H
cpu: AMD Athlon64 X2 6000+
gpu: MSI 320mb 8800 GTS HD OC
ram: 2gb
hdd: 3hdd's 1 sata, 2 ide
pci-slots: Belkin 802.11g Wireless Card
PSU: Thermaltake X silent purepower 480w  12v@18amp 5v@40amp 3,3v@30amp
all running a fresh install of winxp
does anyone have any idea what the problem might be?
  • 微星科技
« Reply #1 on: 03-November-07, 21:14:45 »
Yes: Thermaltake X silent purepower 480w 12v@18amp
A 8800GTs needs at least 26A on +12v, your oc'ed GTs needs even more power.
Better get a decent psu like Corsair VX450, VX550 or Tagan TG600 U33, TG400 U33.
MSI Radeon RX Vega 64 WAVE 8G
Seasonic G-750 • +12V: 62A • +3.3V: 20A • +5V: 20A
Windows 10 Pro
Cooler Master Masterbox 5 MSI Gaming Edition
  • T9246ED, Бивша комета
  • Administrator
« Reply #2 on: 03-November-07, 21:50:02 »
Typical PSU fault(or weak..), take care about your PSU like flobelix said.
JorntTopic starter
« Reply #3 on: 04-November-07, 13:45:10 »
I thought it might have something to do with the psu, seeing as that (apart from the harddisks) is the only part I didn't replace :) I'll look into getting a new one, thanks :)
  • Administrator
« Reply #4 on: 04-November-07, 14:54:37 »
if you need more good PSU suggestions look here:
https://forum-en.msi.com/index.php?topic=112039.msg836246#msg836246
JorntTopic starter
« Reply #5 on: 04-November-07, 22:45:10 »
I've decided I'd probably go with a Tagan TG700-U35 (http://www.tagan.com/pages/products/easyconXl/e_tg700_u35.html) do you think that's a good idea? (yeah, I know it's probably somewhat overpowered, but oh well :) )
  • 微星科技
« Reply #6 on: 04-November-07, 22:49:48 »
If Tagan better go for a U22 or U33 as they are single rail (in Turbo mode) while U35 is split rail.
In 700w class this would be Tagan 2-Force II 700W (TG700-U33). It is not listed on Tagan homepage as that is quite outdated in case of the single rail psus. TG700 U33 is really great and offering 56A on a single rail while being cheaper than TG700-U35.
Windows 10 Pro
JorntTopic starter
« Reply #7 on: 06-November-07, 10:37:25 »
in the end, after much deliberation I decided to not go for the Tagan, even though it was rather cheap, but for the Corsair TX750W, which is arriving as I type this.
thanks for al the advice :D
Jornt
  • 微星科技
« Reply #8 on: 06-November-07, 15:32:24 »
TX750 is a very good decision! Congrats on that, it means the end to any psu related problems you could come across in the near future. Bosskiller has the same and is very happy with it.
Not at all! I'm so glad I could help you!
Windows 10 Pro
JorntTopic starter
« Reply #9 on: 07-November-07, 21:11:05 »
Just wanted to tell you that it's working like a charm now... not a glitch since the new psu. Very happy :D
thanks again :)
  • Administrator
« Reply #10 on: 08-November-07, 00:20:13 »
thanks again :)
Nice :-)), Congrats for the PSU choice as well :-))
Mike
  • aka Frankenputer
  • Virginia, USA
« Reply #11 on: 08-November-07, 20:41:13 »
Chalk another one up for the PSU fixing an issue.
Glad to hear you have it working now.
#2:
MSI Wind U100
