Author Topic: MSI Bios rev. 1.20  (Read 3022 times)
JLC20thMaine
MSI Bios rev. 1.20
« on: 12-January-08, 10:22:51 »
Just flashed my bios with rev 1.20 and for my K9A2 platinum there was NO change in the DDR2 settings visible to me. As a result I went back to the settings that Quadrifoglio gave me in my previous post.  There is a noticeable change in the chipset features, now they are labeled as;
PCI_EX1 GEN2 HIGH SPEED MODE
PCI_EX3 GEN2 HIGH SPEED MODE
PCI_EX4 GEN2 HIGH SPEED MODE
PCI_EX5 GEN2 HIGH SPEED MODE
 Options are; auto, disabled, software initiated and advertised rc. My question is........what the heck are the options doing and what are they for? I'm guessing they are for the PCIE slot version/speeds?
Quadrifoglio Verde
  • MAJOR
  • The liver is evil...it deserves to be punished!
« Reply #1 on: 13-January-08, 21:25:40 »
  • Best Answer
  • They are PCI-E 1.1/2.0 settings to control PCI-E bandwidth. Depending on the graphic card(s) you use, you can run the PCI-E slots in 1.1 mode or in 2.0 mode...
    Desktop
    MSI 790FX-GD70 / AMD Phenom II X4 965 Black Edition / Scythe Ninja / 2 x 4 GB Patriot DDR3-1600 / HIS Radeon HD 5770 1 GB IceQ 5 / Lian Li V1000 Plus II / Seasonic M12 II 520 / Samsung SH-S182D / 2 x Intel X25-M Postville 160 GB / 2 x Seagate Momentus 7200.4 500 GB / Enermax Aurora Premium (black) / Logitech MX518 / Logitech Z-10 / Eizo S2431WH-BK (landscape) + Eizo S2201WH-BK (portrait)
    HTPC
    MSI 785GME65 / AMD Athlon II X4 600e / 2 x 2 GB OCZ DDR3-1333 / Antec NSK1380 / 2 x Seagate Barracuda 7200.11 1 TB / Intel X25-M Postville 80 GB / LG Blu-Ray
    derro_music
    « Reply #2 on: 14-June-09, 10:12:03 »
  • Best Answer
  • Just flashed my bios with rev 1.20 and for my K9A2 platinum there was NO change in the DDR2 settings visible to me. As a result I went back to the settings that Quadrifoglio gave me in my previous post.  There is a noticeable change in the chipset features, now they are labeled as;
    HI Everybody.... I have got a K9A2 Platinum mobo.
    Anyone knows if there exist any king of trouble or something wrong if I do install the only one VGA card that I have on the PCIE #4 (dark blue = 16x), because I have got an excellent case but I little bit old, and its makes me impossible to install the VGA on the PCIE #1. I believe what I doing is valid, however I realised that I will never be able to install a Crossfire configuration.
    I will wating for your response. Thank You so much!
    Ex Forum User 3
    « Reply #3 on: 14-June-09, 10:14:35 »
  • Best Answer
  • Please start your own topic instead of opening very old topic again.
