Author Topic: MSI Dual Core Center  (Read 5489 times)
HeidiTopic starter
  • STAFF SERGEANT
« on: 28-January-08, 22:48:11 »
MSI Dual Core Center version 2.0.1.5 dated as of 10th of the January 2008...is this is fixed finally or what? Doeas it work, and does anyone use this piece...for purpose of controlling various settings? Thanks in advance! :confused2:
Little Heidi
Intel i7 5960X
MSI X99A Xpower Gaming Titanium
32Gb HyperX 2800C14 (8x4Gb)
Sapphire Vega 64 LE (2x)
Samsung 960Pro 1Tb
OCZ 1000W Fatal1ty PSU
Nanoxia Silence 1
wonderwrench
  • SECOND LIEUTENANT
« Reply #1 on: 28-January-08, 23:31:12 »
It seems to me that most if not all manufacture specific hardware monitoring software is hit and miss. What fix are you looking for? Program crash, quad core support? If they fix one thing or add support for new hardware they seem to break support for older hardware in the process. I'm a firm believer in overclocking at the bios level and only use software to verify settings, temps, voltages etc. and to control fan speeds. Speedfan has worked for the most part on every motherboard I have owned that supports monitoring and fan speed control.
C2D E6400 @ 3 Ghz*MSI P35 Neo2-FR bios 1.8*2X 2 gig Corsair DDR2 800 XMS2 ram*Evga 8800GT SSC *Seagate 7200.10 320 gig SATA HD*LiteOn sohw-1693s*Plextor PX 716a*Teac Floppy*SB Audigy 1 Gamer*FSP AX450-PN PSU* Rosewill R6AR6-BK case*XP pro sp2 32 bit
Good judgment comes from experience, and often experience comes from bad judgment.
DaLoona
  • MAJOR
  • Certified nutcase since 1974
« Reply #2 on: 28-January-08, 23:36:06 »
I agree  8-))
MSI X470 Gaming Pro (still in pre-order in the Netherlands :cry: )//R7 2700X//Noctua NH-D15
GigaByte Windforce GTX 1060 OC, 6GB @ 1700 - 9208Mhz
16GB Corsair Vengeance 3000Mhz DDR4, C15
Adata Ultimate SU800, 256GB SSD, OS//Samsung EVO 850, 500GB, storage
Be Quiet Darkpower Pro 11, 850W//Be Quiet Dark Base 700
HP x23LED @1920x1080//Windows 10 x64
Razer Deathadder Chroma//CM Quickfire XTi
HeidiTopic starter
  • STAFF SERGEANT
« Reply #3 on: 29-January-08, 02:30:04 »
While OC from BIOS we can see as sort of permanent to semi permanent solution, and as it is is perfectly clear that only that sort of OC really gives bang for buck. There are something else I would like to point out...my MSI for example sitting doing nothing for ages, yet gobbling same amount of electricity as if it works full blast! Well, I would like to be able to set few profiles as I had been able on my old trusty Abit AN7, where for an example underclock of the CPU means work overnight, eventual DL or anything else, standard clock means everyday task, writing this post and browsing the net and of course OC means gaming, video encoding or tasks with extreme demand why I actually build this system! More than 95% of the time my CPU happily idling while clicking on 3GHz...well that's my point! Am I wrong in anything here? And besides all, CoreCell chip is built onto the board with exactly that function...to enable flexible under, standard and overclocking function of this board! What do you think!  ;-))
Little Heidi
Intel i7 5960X
Samsung 960Pro 1Tb
Nanoxia Silence 1
drachenfire
  • SERGEANT
« Reply #4 on: 29-January-08, 02:59:44 »
I'm about to do a fresh install on a new system (been having some RAID problems), and this time I don't plan to install Dual Core Center.  I was that impressed...  :)
Intel E6850 Conroe 3.0GHz
AMI BIOS V 1.3
COOLER MASTER Stacker 832 ATX Full Tower Case
PC Power & Cooling Silencer 750 Quad EPS12V 750W PSU
MSI P6N Diamond NVIDIA nForce 680i SLI
4GB Crucial Ballistix Tracer DDR2 800 (PC2 6400)
2 BFG Tech GeForce 8800GTS (G92) 512MB  (SLI)
ZEROtherm CF900 CPU Cooler
2 SAMSUNG SpinPoint T Series 500GB 16MB Cache SATA 3.0Gb/s Hard Drive
LITE-ON LH-20A1L-06 2MB Cache SATA DVD Burner
jason str
  • CAPTAIN
« Reply #5 on: 29-January-08, 03:12:00 »
Yeah i too liked this function when shopping for motherboards and tried overclocking with that but to no prevail couldnt get over 2.7 ghz with my E6600 maybe msi will fair better next time we all make mistakes.
wonderwrench
  • SECOND LIEUTENANT
« Reply #6 on: 29-January-08, 04:05:45 »
I see your point. It would be nice if it worked. I have successfully enabled SpeedStep on my P35 Neo2-FR while overclocked without problems. E6400 running at 3 ghz 1.325 volt slows to 2.25 ghz 1.15 volts at idle. I checked the wattage draw using a "Kill a watt" meter and found that I only saved about 10 -15 watts at best. I ended up disabling  SpeedStep as it was not a big enough savings, for me anyway. BTW CPU current draw is very dependent on CPU load. So running your system at 3 ghz without a load on it may not be as wasteful as you think.
wonderwrench
  • SECOND LIEUTENANT
« Reply #7 on: 02-February-08, 02:32:46 »
Heidi have you tried RightMark CPU clock utility? I have been playing with it on my P35 Neo2-FR and it's nice.
Overclock as you like and as long as your board supports EIST you can set it up a profile with a lower multi and VID as you like and or you can setup a performance on demand profile. If you buy the pro version you can set profiles that change by the application being run. It has quit a learning curve but it all makes sense in the end.
Free version, Scroll down for RightMark CPU Clock Utility (RMClock)
http://cpu.rightmark.org/download.shtml
djchristian
  • SERGEANT
« Reply #8 on: 02-February-08, 11:47:33 »
Do i need a MSN graphiccard to make the VGA function in this program to work?
charlescrawley
  • CORPORAL
« Reply #9 on: 02-February-08, 13:11:46 »
From my own experience, no... I have an EVGA 8800GT 512MB which works fine with Dual Core Center, both under- and over- clocking.
Main PC:
Antec P182 Case
Intel Core 2 Duo E6850 3GHz
Zalman CNPS9700-LED CPU Cooler
MSI P35 Platinum Motherboard BIOS v1.8
2x 1GB Crucial DDR2 XMS2-6400C4 TwinX RAM
EVGA GeForce 8800GT 512MB KO
Western Digital WD1600AAJS 160GB SATA Drive
Western Digital WD5000AAKS 500GB SATA Drive
Pioneer DVR-212DBK 18x DVD±RW SATA Dual Layer ReWriter
OCZ StealthXStream 500w Silent SLI Ready ATX2 Power Supply
Windows XP SP3 with all updates
nVidia ForceWare v175.16
Intel INF v8.3.0.1011
Media Center:
Shuttle SN45Gv2
Upgraded SilentX PSU (300W IIRC)
AMD Athlon XP 3200+
XFX GeForce 6800GS 256MB AGP
2x 512MB Crucial DDR RAM
1x 120GB IDE HDD
1x 300GB IDE HDD
Plextor DVD / CDRW
nVidia nForce v5.10
nVidia nForce Audio v4.
DaLoona
  • MAJOR
« Reply #10 on: 02-February-08, 21:42:40 »
@ above
your one of the lucky ones, Im still getting BSOD's from the friggin program  :angryfire:
Edit: Even with everything at stock,  :biggthumbsdown: program, in my point of view that is.
So i deleted it for the 3 time and use speedfan, coretemp everest en cpu-z and rivatuner no prob's with that  :agrees:
wyemarn
  • SERGEANT
« Reply #11 on: 05-February-08, 02:50:56 »
The latest version works for me. Sometimes it still crashes though.
C2D E6320
MSI P35 Neo2-FR
Team Elite DDR2-800 1GBX2
Sapphire X1950XT 256MB
2x Hitachi T7K500 320GB Matrix RAID
Seagate 7200.10 250GB
Creative Audigy 2ZS
Winfast TV2000 Expert
Scythe Kamariki2 550W PSU
Win XP Pro SP2
