Author Topic: Hetis 965 and large-screen displays  (Read 3429 times)
VladorTopic starter
« on: 10-February-08, 02:29:30 »
Has anybody tried to use Hetis 965 barebone (or any MSI motherboards based on Intel 965G chipset) with 24" LCD monitors? I wonder whether the barebone provides native support for 1920x1200 resolution.
Stu
  • Birmingham, UK
    • StuOnline.co.uk
Re: Hetis 965 and large-screen displays
« Reply #1 on: 10-February-08, 06:15:41 »
From: http://www.intel.com/products/chipsets/gma950/index.htm
If you want to watch video on your PC, then utilize Intel GMA 950 graphics for smooth video playback, native 16:9 format support for wide screen flat panels, motion compensation for smooth DVD playback and support for popular HDTV display formats.
I guess the answer is yes then :biggthumbsup:
FYI, you can find the latest 965G graphics drivers here:
http://downloadcenter.intel.com/Product_Filter.aspx?ProductID=2576&lang=eng
VladorTopic starter
« Reply #2 on: 12-February-08, 07:13:25 »
Thanks! The more so that Intel had no other choice but to agree with you  :agrees: I just received a letter from it's technical support staff with the same answer.
Thank you once more!
Stu
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #3 on: 12-February-08, 13:24:32 »
:hat tip: You're welcome!
