Author Topic: MS-7093 BIOS / Raid Driver / Overclocking Utils  (Read 11522 times)
btutorTopic starter
I am upgrading my old Emachines T6212 which has the MS-7093 motherboard.
I was able to LiveUpdate the BIOS to 3.9 from the MSI site.
I have 2 new SATA drives I want to setup for RAID 0.  I was able to set the "Onboard Chip SATA" BIOS option to "RAID Controller".
Afterwards I was able to hit F4 during POST to get to the Silicon Image 3112A 4.2.5.0 RAID setup.
I setup the RAID 0 set from the 2 drives with no problem.
But.... I can not find a Vista 64-bit driver to install during my Vista install.
I have tried everything off the MSI site.  No Vista drivers on the Emachines site.  And the Silicon Image site says don't user their drivers on these motherboards.
QUESTION:  Is there a Vista 64 RAID 0 driver that will work here.
I also want to overlock this CPU (4000+) and RAM (OCZ Platinum 2GB (2 x 1GB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Dual Channel Kit Desktop Memory).  But I don't see the appropriate options in BIOS.  I have read others have had success with ClockGen but I can't find a version that runs under Vista 64.
QUESTION:  Is there anyway to overclock this board?  Either with a different BIOS or a windows utility under Vista 64.
Phoenix - Award BIOS v6.00PG
W7093AMS V3.9 021306
02/13/2006-RS480-SB400-6A666M4DC-00
AMD Athlon 64 4000+
This is the ATI200 board.
  • T9246ED, Бивша комета
  • Administrator
« Reply #1 on: 02-June-08, 02:17:26 »
You should contact to your mainboard OEM builder,
this forum support MSI retails products only, for more information read here:
 >>OEM boards manufactured by MSI<<
P.S: Topic locked since board is not retail MSI model
