Author Topic: MSI P965 Neo (MS-7235) Problem Update Bios  (Read 15879 times)
FezRee
  • Neo
« on: 11-July-08, 19:56:06 »
I Cant  Update bios....
error 654 ?? http://global.msi.com.tw/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=265 < < Ma Letest Bios
This is Ma Mobo Spec:
Motherboard ID           :08/18/2006-Broadwater-6A79LM4CC-00
Motherboard Name   :MSI P965 Neo (MS-7235)
Front Side Bus Properties
Bus Type:           Intel AGTL+
Bus Width:           64-bit
Real Clock:           267 MHz (QDR)
Effective Clock:   1066 MHz
Bandwidth:           8532 MB/s
Memory Bus Properties
Bus Type:           DDR2 SDRAM
Bus Width:           64-bit
DRAM:               FSB Ratio   12:8
Real Clock:           400 MHz (DDR)
Effective Clock:   800 MHz
Bandwidth   6400 MB/s
Chipset Bus Properties
Bus Type:   Intel Direct Media Interface
Motherboard Physical Info
CPU Sockets/Slots:   1 LGA775
Expansion Slots:           3 PCI, 2 PCI-E x1, 1 PCI-E x16
RAM Slots:                   4 DDR2 DIMM
Integrated Devices:   Audio, Gigabit LAN
Form Factor:           ATX
Motherboard Size:   220 mm x 300 mm
Motherboard Chipset:   P965
Extra Features:           CoreCell, DigiCell, SATA-II, RAID
youeffsee
  • Platinum
Re: MSI P965 Neo (MS-7235) Problem Update Bios
« Reply #1 on: 11-July-08, 20:34:12 »
why do you want to flash the bios?
what problems are you having...there could be anotherway around it without flashing bios
If you are trying to update bios using MSI live update,PLEASE STOP NOW...flashing bios thro windows is never a good idea and carries an extremely high risk of ruining your board
bios flashing is always risky...this is used as a last resort in most cases
and finally if you do have to flash your bios make sure your system is stable....if it isn't than good chance you wont have a successful flash
2x Samsung Syncmaster 2253BW
Logitech Z-5500
Thermaltake Mozart Tx
MSI P45 Platinum
e8400 E0-4Ghz @ 1.2125v
Kingston HyperX KHX8500D2K2/2G
eVGA 9800GTX 512Mb
Corsair tx750 (+3.3v/30a..+5v/28a..+12v/60a)
Custom Coolit Freezone Elite
Details on my build: http://www.coolitsystems.com/index.php/community/forum/18-rig-mods/3288-the-evolution-of-mozart.html
FezRee
  • Neo
« Reply #2 on: 12-July-08, 06:36:51 »
thx....
 :shocking:
technics69
  • Neo
« Reply #3 on: 05-July-09, 16:23:02 »
I flashed my bois on this board but after 4 secs the system froze up.
is there anyway of fixing this with a floppy disk boot, something like amibios or something. If i cant then i guess i need a new board
Jack
  • Ex Forum moderator
  • Power Edition
« Reply #4 on: 05-July-09, 16:39:57 »
How did you flash your BIOS and why did you do that?
If you have a P965 Neo-F (MS-7235 v1.x), you board uses AWARD BIOS Releases.  The Recovery procedure for AWARD BIOS looks like this:
http://www.msicomputer.com/support/BIOS_Award_Recovery.asp
Ex Forum User 3
  • Hawk
« Reply #5 on: 06-July-09, 15:22:09 »
What exact BIOS was in there? Should be something like the photo's below:
