Author Topic: Wind PC Compact Flash causes XP to install hard drive as E:  (Read 11878 times)
tec805Topic starter
  • CORPORAL
In the BIOS there is no option for disabling the CF reader. Changing the boot order does nothing. There are no jumpers in the manual or on the board that are related to the CF (the sole jumper on the board is for clearing the CMOS). How are people installing XP on the hard drive as C: instead of E:?  :huh:
Thanks
[changed icon to Thumb Up]
Stu
  • Birmingham, UK
    • StuOnline.co.uk
Re: Wind PC Compact Flash causes XP to install hard drive as E:
« Reply #1 on: 10-September-08, 03:42:19 »
Which one do you have? Sorry, I'd never even heard of these until now!
http://global.msi.eu/index.php?func=prodpage2&maincat_no=134&cat2_no=614
Wasn't XP already installed on the unit? If so, why do you need to reinstall XP?
Having never seen one of these units, the only thing I can possibly suggest is if you can open up the unit, and see if the CF reader connects to the mainboard via a USB header, and disconnect it while you install XP, then Windows will install to C:. Just make sure you reconnect it again afterwards! :laugh:
Otherwise, if the CF reader is somehow hard-wired to the mainboard, you may just have to live with Windows being on the E: drive... but thats only cosmetic, it won't make any difference to how it works, unless you get some really poorly programmed application that assumes Windows is installed on C: drive, but that is pretty rare.
You may get a better answer though if you contact MSI Support using the online form at http://ocss.msi.com.tw but please be sure to post back if you get a solution!
:biggthumbsup:
tec805Topic starter
  • CORPORAL
« Reply #2 on: 10-September-08, 11:50:58 »
Wind PC 120 (XP) http://global.msi.eu/index.php?func=proddesc&prod_no=1603&maincat_no=134
This is a barebones, no memory or hard drive. I've submitted a support request to MSI, I'll post if they can help.
tec805Topic starter
  • CORPORAL
« Reply #3 on: 10-September-08, 12:31:09 »
Submitted a support request to MSI, received a phone call from them in less then 10 minutes!
Having built computers for many years it never occurred to me to create a partition then restart the computer before continuing the Windows install. After restarting the computer it defaults the hard drive as C:, allowing you to format and install like normal.
Thanks
nightmare99
  • CAPTAIN
« Reply #4 on: 11-September-08, 05:41:21 »
Is there no option to disable the USB in the BIOS? That would stop it  ;D
P35 Platinum v1.1 BIOS v1.9
Core 2 Quad Q6600 G0 Step @ 3.0Ghz
4x 1GB Elixir PC-5300 DDR2 667Mhz
Gigabyte 8800GT 512MB PCI Express
Maxtor 320GB SATA 300 AHCI
Maxtor 200GB SATA 300 AHCI
LiteOn 16x DVDRW SATA
Silverstone TJ-06 Case
X-Pro 500W PSU
Vista Ultimate x64 SP1 (Running well!)
Stu
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #5 on: 11-September-08, 07:45:29 »
The Wind barebones don't have PS/2 ports for mouse/keyboard, so you can only use USB devices, which would be unusable if you disabled USB controller.
:hat tip:
tec805,
Glad to hear your problem is resolved, and thanks for posting back, this will be invaluable advice to anyone else who encounters same problem!
:biggthumbsup:
[Added to sticky topics list]
shawnee3
« Reply #6 on: 14-December-08, 19:22:26 »
I had same problem when installing XP. I used tec805's idea and restarted windows install after setting partition and voila drive C appeared. Thanks  :worship:
banger696
  • SECOND LIEUTENANT
  • Intel Core 2 Duo E8400
« Reply #7 on: 18-December-08, 21:29:13 »
MSI tech are indeed correct this quirk can be worked around by restarting after partitioning/formatting the drive.  :biggthumbsup:
Intel E8400 Core 2 Duo 3.0 Ghz Wolfdale
MSI P35 Neo F BIOS V1.A0
4x AENEON 1Gb DDR2
MSI Geforce 9500GT 1gb PCI-E
2x Seagate 80gb ATA100
Microsoft Windows XP Pro Edition SP3
Hiper 530W PSU 12v1 18A 12v2 18A 5v 34A 3v3 28A
Thermaltake Tsunami Case (Silver)
Stu
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #8 on: 19-December-08, 12:45:30 »
This useful advice is applicable to anyone with an internal card reader in their PC :hat tip:
