Author Topic: Titan 700 and 16:9 resolutions?  (Read 5308 times)
kazsoTopic starter
  • SERGEANT
« on: 06-October-08, 11:58:07 »
Does the Titan 700 support any 16:9 resolutions under Windows XP?
I tried to install several S3 Unichrome Pro drivers (MSI, Via, Asus), but all i get is 800x600, 1024x768, 1280x800, 1280x1024 and 1600x1200.
I connected the Titan 700 to my LCD TV (LG 42FT75 , 42" 16:9), but the TV supports 4:3 and 16:9 resoulutions only. If i try to set 1280x800 (which is 16:10), a "No Signal" message appears on the TV.
Is it possible to "hack" the driver to support 16:9 resolutions, for example 1280x768? I tried Powerstrip, but i can't set any custom resolutions with it.
Also i tried Mandriva Linux 2008, which supports all possible resolutions from 640x480 up to 1920x1080. But i don't want to use Linux :undecided:
MSI 790FX-GD70 / Phenom II X3 720 (Zalman CNPS-9900) / 2x2GB Kingmax DDR3-1600 / Sapphire Vapor-X HD5870 / Enermax Modu82+ 625W / Cooler Master HAF-932 / Intel 160GB SSD / Intel 80GB SSD / 4xSamsung F1 750GB 32MB Raid5
kazsoTopic starter
  • SERGEANT
Re: Titan 700 and 16:9 resolutions?
« Reply #1 on: 08-October-08, 04:18:52 »
After i contacted the MSI technical support about this issue, they updated the Titan 700 bios and added widescreen resolutions (hopefully 16:9 resolutions).
Bios: http://www.msi.com/index.php?func=downloaddetail&type=bios&maincat_no=134&prod_no=1452
Gonna check it later today.
Edit: tried the new bios (3.10). It supports a lot more resolutions now: 800x600, 1024x768, 1280x768, 1280x800, 1280x1024, 1400x1050, 1440x900, 1680x1050, 1920x1080.
So my problem is solved with the new bios :biggthumbsup:
Stu
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #2 on: 08-October-08, 12:55:47 »
Glad to hear that MSI resolved the issue, and thanks for posting back! :hat tip:
Mike
  • aka Frankenputer
  • Virginia, USA
« Reply #3 on: 08-October-08, 13:31:45 »
Excellent  :biggthumbsup:
#2:
MSI Wind U100
csa3a
« Reply #4 on: 18-January-09, 04:45:26 »
How can i update bios?
It has no floppy, the HD and CD is SATA.
So how can i boot DOS to run bios flash.bat
PLEASE, help!
Stu
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #5 on: 18-January-09, 05:05:56 »
PLEASE, help!
>>Use the MSI HQ Forum USB flasher<< :hat tip:
