Author Topic: MSI K9NGM (MS-7252)  (Read 23305 times)
DavidND
  • Winki
  • NeVeR 2 oLd 2 LeArN...
MSI K9NGM (MS-7252)
« on: 12-November-08, 19:18:51 »
I too have this problem with the non recognition of a dual core in XP. Would someone point me to the bios that resolves it please? Many thanks.
MoBo - K9NGM A7252NMS V3.1 08/15/06
cPu - Athlon 64 x2 Dual Core Pro 5600+
RaM - 2GB DUAL CHANNEL 533MHZ
DrIvEs -
MAXTOR 6B160P0
LG GH22LP20
MAXTOR 6L300S0 (SATA)
WD WD5000KS (SATA)
XP PRO (LATEST UPDATES)
  • T9246ED, Бивша комета
  • Administrator
    • MSI BIOS/EC-FW Mods
MSI K9NGM (MS-7252)
« Reply #1 on: 12-November-08, 19:21:40 »
Does in "Device Manager", under "Computer" says ""ACPI Multiprocessor PC"?
Have you "LOAD BIOS OPTMIZED DEFAULTS" in BIOS too?
What's current BIOS version onboard?
P.S:
Official 3.7 is out ==> ftp://duser:duser@66.232.110.239/MB%20BIOS/7252v3x/7252v37.rar
Which will solve the issue{has been confirmed by user} as the provisional/older 3.71{Beta} do.
DavidND
  • Winki
MSI K9NGM (MS-7252)
« Reply #2 on: 12-November-08, 19:58:39 »
Yes to ACPI
Yes to optimized defaults
3.1 is my current BIOS
I'm now running (trying to at least) 64 x 2 dual core Pro 5600+
It says 2.8Ghz count 2 with DRAM = 555Mhz Dual Channel
I'm getting a Unknown Processor Revision message so do I need to upgrade my BIOS?
Lastly, on a different note, can I run more than two SATA drives even though my MoBo doesn't have any more connections?
Thanks for your help. It really is appreciated.
DrIvEs -
MAXTOR 6B160P0
LG GH22LP20
WD WD5000KS (SATA)
  • Administrator
MSI K9NGM (MS-7252)
« Reply #3 on: 12-November-08, 20:00:35 »
"Yes to ACPI"
Which one ACPI?
"Lastly, on a different note, can I run more than two SATA drives even though my MoBo doesn't have any more connections?"
With extra SATA controller yes. Else not.
If you have more questions, open new own topic. Don't hi-jack this one.
P.S: Topic splited.
DavidND
  • Winki
Re: MSI K9NGM (MS-7252)
« Reply #4 on: 12-November-08, 20:07:15 »
Apologies over the split.
yes to ACPI Multiprocessor PC
DrIvEs -
MAXTOR 6B160P0
LG GH22LP20
WD WD5000KS (SATA)
  • Administrator
« Reply #5 on: 12-November-08, 20:08:10 »
Oki.
"I'm getting a Unknown Processor Revision message so do I need to upgrade my BIOS?
I too have this problem with the non recognition of a dual core in XP"
Yes, go for 3.7
DavidND
  • Winki
« Reply #6 on: 13-November-08, 00:49:44 »
Thanks Boss.
I made a bootable CD and it all installed perfectly.
Now my WD 500GB hard drive with 5000 pictures on it has died though - what a bummer!  :wall:
DrIvEs -
MAXTOR 6B160P0
LG GH22LP20
WD WD5000KS (SATA)
  • Administrator
« Reply #7 on: 13-November-08, 00:52:33 »
BIOS update can't harm your storages.
What's the problem with your drive?
clarkey250
  • Winki
« Reply #8 on: 23-November-08, 21:54:50 »
hi people i was wondering, I downloaded the link from prev post for BIOS v 3.7  k9ngm as i have the same problem as the other person, my processor is not accepted with current v 3.1 .
im not sure how to change to ISO or how many files to put onto bootable cd ??
the files are:
A7252NMS.360
A7252NMS.370
Afud408.exe
oh and my computer in device manager says acpi uniprocessor not acpi multiprocessor
does this matter??
 :bonk:
sorry for the stupidity but i have never done this before
thanks.
chris
« Last Edit: 24-November-08, 00:40:19 by clarkey250 »
  • Administrator
« Reply #9 on: 24-November-08, 08:21:47 »
the files are:
A7252NMS.360
A7252NMS.370
Afud408.exe
does this matter??
 :bonk:
thanks.
chris
"hi people i was wondering, I downloaded the link from prev post for BIOS v 3.7  k9ngm as i have the same problem as the other person, my processor is not accepted with current v 3.1 .
the files are:
A7252NMS.360
A7252NMS.370
Afud408.exe "
Get attached archive, then >>Use the MSI HQ Forum USB flasher<<
"oh and my computer in device manager says acpi uniprocessor not acpi multiprocessor
does this matter??"
Yes its the matter, when you install X2 CPU it should automatically change to acpi multiprocessor.
If that doesn't happend, enter in BIOS and "LOAD BIOS OPTIMIZED DEFAULT", followed by "SAVE AND EXIT".
Then manually update HAL to "ACPI Multiprocessor PC"
clarkey250
  • Winki
« Reply #10 on: 24-November-08, 13:18:56 »
cheers 4 the help
not sure if it changed in device manager but when i put the x2 processor in, windows did reconise it and it was running ok but not 2 full potental as i had the error message(UNKNOWN PROCESSOR REVISION UPDATED BIOS) and my comp wouldnt boot properly and i was told 2 re-install xp with my old processor in and to flash bios.
i read some of the link u sent me for flashing with usb mem, do i need a program to make the files bootable?? and do i need 2 change them files to iso???
sorry.
these are the files i have:
A7252NMS.360
A7252NMS.370
Afud408.exe
thanks chris
  • Administrator
« Reply #11 on: 24-November-08, 14:17:15 »
"cheers 4 the help"
Use normal language, MSN and such are not allowed.
"i read some of the link u sent me for flashing with usb mem, do i need a program to make the files bootable?? and do i need 2 change them files to iso???"
No read the link, there is a guide how to use it.
clarkey250
  • Winki
« Reply #12 on: 24-November-08, 15:24:54 »
ok thanks,
which file shall i use both or??
 A7252NMS.360
does this mean A7252NMS.370= version 3.7??
Afud408.exe
Thanks
  • Administrator
« Reply #13 on: 24-November-08, 15:26:18 »
ok thanks,
 A7252NMS.360
Afud408.exe
Thanks
Just point to 7252v37.rar which is uploaded above, here is link to it again:
http://forum-en.msi.com/index.php?action=dlattach;topic=121508.0;attach=5058
"does this mean A7252NMS.370= version 3.7??"
Yes
clarkey250
  • Winki
« Reply #14 on: 24-November-08, 23:37:54 »
ok i ran the program MSIHQ USB Bootable Tool, i picked the folder as zip and ran the program and it succesfully copied to my flash drive, i then booted from this and it flashed bios ok  :biggthumbsup: but
when i checked the bios it said version 3.6???
i dont get the [unknown processor revision] sign but when i check in the device manager & computer it still says uniprocessor?
i tryed "LOADING BIOS OPTIMIZED DEFAULT", followed by "SAVE AND EXIT". but still no good
how do i manually update HAL??? to "ACPI Multiprocessor PC"
should i have picked out the file A7252NMS.370 from the download you gave me manualy and flashed only that one???
thanks again
chris
  • Administrator
« Reply #15 on: 24-November-08, 23:43:16 »
thanks again
chris
"ok i ran the program MSIHQ USB Bootable Tool, i picked the folder as zip and ran the program and it succesfully copied to my flash drive, i then booted from this and it flashed bios ok  :biggthumbsup: but
should i have picked out the file A7252NMS.370 from the download you gave me manualy and flashed only that one???"
Yes, that's why i upload it and linked to it twice. Just point to 7252v37.rar in my upload.
{Not to 7252v37.rar from the FTP, which archive contain both 3.6 and 3.7 in same time probably due error and you have flashed 3.6{Bugged} instead 3.7}
"how do i manually update HAL??? to "ACPI Multiprocessor PC""
What CPU you use?
Right click over it and select "Update" then pickup "ACPI Multiprocessor PC" from the list.
But flash the BIOS 1st.
clarkey250
  • Winki
« Reply #16 on: 24-November-08, 23:50:40 »
 :hat tip:
thanks i have a amd 5600 x2 2.9ghz
  • Administrator
« Reply #17 on: 24-November-08, 23:54:30 »
Well go ahead and post your result
clarkey250
  • Winki
« Reply #18 on: 25-November-08, 00:19:43 »
:: :hat tip:
Thanks very much for being patiant with me and for all you help BOSS your the man all works fine. :worship: :worship:
just one more question is there any programs i can run to increase the performance of my machine?
my system spec is:
xp pro 32bit
amd 5600 2.9ghz
4gb corsair xms ddr2 800MHz
Thanks again
chris :smile:
  • Administrator
« Reply #19 on: 25-November-08, 00:27:59 »
You have done well :hat tip:
shikigamics
  • Neo
« Reply #20 on: 07-April-09, 17:57:56 »
sorry, i can't get the upload data for version 3.7 and i can't download it from live monitor msi cause  it's always shows connected and connecting repeatly without any file download while other is fine for me.
Mainboard Information:
Mainboard Manufacturer MSI
Mainboard Model Name MS-7252
Mainboard BIOS Vendor AMIBIOS
Mainboard BIOS Version 3.00
detail in dxdiag
Machine name: SHIKI
   Operating System: Windows XP Professional
           Language: English (Regional Setting: English)
System Manufacturer: MSI
       System Model: MS-7252
               BIOS: Default System BIOS
          Processor: AMD Athlon(tm) 64 X2 Dual Core Processor 5200+,  MMX,  3DNow (2 CPUs), ~2.7GHz
             Memory: 3072MB RAM
          Page File: 464MB used, 3957MB available
        Windows Dir: C:\WINDOWS
    DirectX Version: DirectX 9.0c (4.09.0000.0904)
DX Setup Parameters: Not found
     DxDiag Version: 5.03.2600.2180 32bit Unicode
thx.
  • Administrator
