Author Topic: Can`t set 9.5 multiplier with p35 neo2 fr  (Read 5818 times)
francis511Topic starter
« on: 30-December-08, 19:28:18 »
I bought an e8500 (eo stepping) and the 9.5 multiplier option is unavailable in the bios of my board. I am running bios 1.9 and neither it nor 1.1a solved this problem. When I tried  bios 1.8 , the board refused to boot until I swapped back to another chip.
  • T9246ED, Бивша комета
  • Administrator
« Reply #1 on: 30-December-08, 19:30:08 »
Latest BIOS 1.10 should fix that
« Reply #2 on: 30-December-08, 19:35:35 »
If you mean the latest bios on the download page it didn`t help !
  • Administrator
« Reply #3 on: 30-December-08, 19:37:14 »
Are you 100% sure?
« Reply #4 on: 30-December-08, 19:43:34 »
I`ll try it again but I think so
  • Administrator
« Reply #5 on: 30-December-08, 19:45:29 »
Yes, please verify that again. 1.10 fix that problem for certain CPU's.
Make sure that you really have flashed to 1.10. {For your board, make sure that BIOS Boot Sector Protected is Disable before flash the BIOS}
« Reply #6 on: 30-December-08, 19:55:09 »
Yeah I checked again and it definitely doesn`t change it
  • Administrator
« Reply #7 on: 30-December-08, 19:56:33 »
Well in such case, seems your CPU is exception.
Explain the issue to MSI Tech here: http://ocss.msi.com.tw/ , they will send you A7345IMS.1B1 which can fix the problem.
« Reply #8 on: 30-December-08, 20:13:09 »
O.K. I`ll try that.
  • Administrator
« Reply #9 on: 30-December-08, 20:46:44 »
Don't forgot to login to check for response, MSI don't send mails
nightmare99
  • CAPTAIN
« Reply #10 on: 31-December-08, 08:37:12 »
/OT Really?  On the few occasions I have used the OCSS evrytime they have issued a responce I have recieved an email notification. (although its always worth checking manually incase the notification is marked as junk etc)
P35 Platinum v1.1 BIOS v1.9
Core 2 Quad Q6600 G0 Step @ 3.0Ghz
4x 1GB Elixir PC-5300 DDR2 667Mhz
Gigabyte 8800GT 512MB PCI Express
Maxtor 320GB SATA 300 AHCI
Maxtor 200GB SATA 300 AHCI
LiteOn 16x DVDRW SATA
Silverstone TJ-06 Case
X-Pro 500W PSU
Vista Ultimate x64 SP1 (Running well!)
  • Administrator
« Reply #11 on: 31-December-08, 08:44:33 »
As far that we known, they don't. But seems its changed since you told opposite. :)
Jack
  • Ex Forum moderator
« Reply #12 on: 31-December-08, 11:12:52 »
Have you cleared CMOS with main A/C power cable removed from PSU after installing the E8500? If not, please try that as well.  Disable Spread Spectrum in the Cell Menu and do not change any clock settings.  Keep EIST enabled and do not change the CPU ratio in BIOS.
« Reply #13 on: 01-January-09, 08:00:52 »
I got a temporary fix by enabling eist. That correctly sets the ratio to 9.5 , but I don`t want eist enabled tho` :biggthumbsdown:
Aaron
  • GENERAL
  • BOOST!
« Reply #14 on: 01-January-09, 08:02:52 »
Why not?  It saves power.  Save the planet ya' know. :lol_anim:
More seriously, I have never disabled it.  Haven't found it to ever make any of my overclocks unstable
Refrain from having to solve most of your problems by not creating them in the first place.
DDR3 Memory Standards: Blurry Lines
Integrated Memory Controllers (IMC)
Intel EIST and Processor C-states
Overclock Database 2.0
Mike
  • aka Frankenputer
  • Virginia, USA
« Reply #15 on: 01-January-09, 14:32:33 »
Why not have EIST on? Not only does it reduce the electric bill, it prolongs the CPU life and you will get the full power of the CPU when needed. You don't need the full CPU power to run the computer at idle or compose a document. Running it full tilt when not needed is just a waste.
#2:
MSI Wind U100
Jack
« Reply #16 on: 01-January-09, 17:26:19 »
 :biggthumbsup: That is what I thought.
EIST is a feature that you can enable/disable within the operating system.  Simply select "Always-On" or "High Performance" as your energy profile and EIST is turned off (even though it is enabled in BIOS).  The BIOS Option just enables/disables the support for SpeedStepping, not the function itself.  Switching EIST on and off is done in Windows.  Read this as well:
__Enhanced Intel SpeedStep® Technology How To Document__
   4. Finally Enhanced Intel SpeedStep technology must be turned on in the OS. Currently, for Windows* XP SP2 operating systems Enhanced Intel SpeedStep technology by default is off. To turn it on do the following:
    * Under Control Panel – open Power Options
          o Under the Power Schemes pull down menu
                + To turn Enhanced Intel SpeedStep technology ON select, “Minimal Power Management,” power scheme.
                + To turn Enhanced Intel SpeedStep technology OFF select, “Always On,” power scheme.
Looks like you do not have a real problem here.  However, I fail to understand the point of turning off efficient power saving features that do a great job without sacrificing system performance.  You paid for those features.  They are an essential part of the Processor Architecture.
