Author Topic: MSI MS-7522 (X58 PLatinum) Motherboard and PS/2 Keyboard?  (Read 11146 times)
pwjone1Topic starter
New system with MSI MS-7522 (X58 Platinum) Motherboard, and an IBM PS/2 keyboard, what I am seeing is that on booting, the BIOS or something has difficulty with the keyboard.  Everything comes up, but the keyboard is dead.  This was working fine on the previous system, and works most of the time with the MS-7522, and once it boots OK, it stays fine, even going through sleep modes.  But some of the time, say 30%, the keyboard is dead.  I have to take the system then through a full shut-down to recover it.  So I think I'm getting some sort of timing error, or other problem with the BIOS (1.1).  Two questions then really:
  • Has anyone else run into this sort of thing?
  • Any suggestions?
I suppose someone is going to suggest, try another keyboard, which I've done, and am typing this in on now.  This one seems to work better, haven't been through enough boot cycles to say it's 100%, but this is a "newer" variant, PS/2 Lexmark, and doesn't have quite the feel that the IBM (yes, actual IBM) keyboards had.  They're almost collector items, but they are among the best touch type feel I've used.  Hate to be forced upwards, if it's just a timing problem in the BIOS.
Paul Jones
MSI MS-7522 Motherboard (X58 Platinum)
Mike
  • aka Frankenputer
  • Virginia, USA
« Reply #1 on: 04-January-09, 05:59:54 »
I think you have found the issue, your old keyboard.
If you are looking for IBM type keyboards with that IBM touch, go here: http://pckeyboards.stores.yahoo.net/keyboards.html
I ordered one for a friend as a gift since he loathed other keyboards and loved his IBM.  His IBM was starting to fail and I found this place and got him one.
#2:
MSI Wind U100
Hans
  • Official Q-Tec Alert Specialist // 正式Q技术机敏的专家
  • LIEUTENANT GENERAL
  • If I fix it, it will never need fixing again!
« Reply #2 on: 04-January-09, 14:58:08 »
Why was this under Vista-problems? Moved it to Intel...
You have a Q-Tec Power Supply? Change that first and come back later...
* MSI P55-GD85, bios 1.3
* Intel Core i7 860 (stock @ 2.8GHz)
* 2x 2048MB TakeMS @ 1333MHz (8-8-8-24, 1T)
* Club3D HD5770 1024MB
* OCZ Vertex 2 120GB (OS and apps)
* 5x Western Digital Caviar Green 500GB in RaID5 (storage)
* 2x DVD Rewriter (LG, Optiarc)
* PC Power & Cooling Silencer 750W
* Cooler Master Stacker CM101
* Dell Ultrasharp 2209AW 22\\\" (e-IPS) monitor
* Windows 7 Professional NL
MSI MediaLive: AMD Athlon X2 4800+, 2x1GB Crucial PC-4200, Seagate 160GB, Pioneer DVD-burner, Hauppauge PWR150 TV Tunercard, Windows 7 Home Premium NL.
MSI X-Slim X620 :like: :like:
Backup: Thecus N5200Pro NAS
