Author Topic: Short Glimpse of MSI GTX260 Lightning Black Edition  (Read 8736 times)
gzhilTopic starter
  • Hardware Reviewer
  • SECOND LIEUTENANT
Just got this MSI GTX260 Lightning Black Edition and I can say MSI did a good job on this one starting from the box until to the unit itself  :biggthumbsup:
Let’s get started shall we and open up the box…
There it is the GTX260 Lightning with AirForce Panel and underneath it is some kind of a drawer. Once you pull it out you will find the accessories, driver software cd, manual, DVI & HDMI adapter and cables for connecting the AirForce Panel to your mobo.
As you can see it is using a dual fan heatpipe cooling solution called Twin Frozr and makes the video card cool down very well even at high overclock speeds. On the rear side of the video card there are the HDMI, VGA & DVI Ports.
More on the AirForce Panel, here is an overview on what it can do.
Below are the values you can do with the AirForce
GPU Core
1.0700V
1.0825V
1.0950V
1.1075V
1.1200V
Mem Core
1.8500V
1.8600V
1.8700V
1.8800V
1.9000V
Core
655
660
665
670
673
676
680
Memory
1000
1010
1020
1030
1040
1050
Shader
1404
1440
1458
Panel in working mode and by the way  it is touch sensitive. Selecting Lightning on the panel will bring you up the MSI windows software showing all the specs from the settings you have made. I hope MSI also included fan controls on the panel
Let us now test this baby for benchies.
Test Up System:
Intel i7 920 2.66 OC’ed to 4.0ghz
3x1 Team Xtreem Dark 1600mhz
MSI Eclipse SLI bios version 1.6b1
Coolermaster V8
MSI GTX260 1792mb DDR3 Lightning Black Edition
MSI 9800GTX+ MOA 512mb DDR3 Edition SLI
Sapphire 4850x2 1GB DDR3
Test Software:
3dmark06 (the only test that I can do as of now)
Using the Game Mode of the AirForce Panel. System OC’ed at 4.0ghz and all stock VC
MSI 9800gtx+ MOA Edition SLI  Core 760/ Memory 1150/ Shader 1890
MSI GTX260 Lightning Edition Core 655/ Memory 999/ Shader 1404
Next:
Max out the Core Voltage and Mem voltage on the AirForce Panel. System OC’ed at 4.0ghz and overclocked VC
MSI 9800gtx+ MOA Edition SLI  Core 810/ Memory 1175/ Shader 2010
Sapphire 4850x2  Core 690/ Memory 1100
MSI GTX260 Lightning Edition Core 730/ Memory 1130/ Shader1500
That’s it. I will try to update this post once I got time playing with this video card again  :rolleyes: :rolleyes:
MSI XPower
Intel Xeon
MSI N580GTX Lightning
OCZ Solid 3 60GB SSD 6GB/s
Seagate 500GB 3GB/s
A4Tech X7 G700 Keyboard
A4Tech X5-70MD
Creative 5.1 Speakers
Hanns-G HG281 28" LCD Monitor
Froggy Gremlin
  • Master Air OC'er
Re: Short Glimpse of MSI GTX260 Lightning Black Edition
« Reply #1 on: 05-May-09, 02:43:42 »
 :biggthumbsup: Sweeeeet! Looking forward to the update!
IXOYE
gzhilTopic starter
  • Hardware Reviewer
  • SECOND LIEUTENANT
« Reply #2 on: 06-May-09, 22:23:34 »
Some updates
•System overclocked to 4.2ghz
•MSI N260GTX Lightning @ core 765/ shader 1530/ memory 1125
Picture of my system for this VC test
MSI XPower
Intel Xeon
Seagate 500GB 3GB/s
A4Tech X5-70MD
  • T9246ED
  • Administrator
« Reply #3 on: 06-May-09, 23:11:08 »
Memory voltage used on the latest results?
P.S: No doubt its brilliant MSI product :agrees: :worship:
gzhilTopic starter
  • Hardware Reviewer
  • SECOND LIEUTENANT
« Reply #4 on: 07-May-09, 00:09:02 »
 ;D thanks man.
For the GPU voltage was 1.225v
For the system
My 920 is already at 1.54v hehehehe
QPI: +0.23
PLL: +1.84
IOH: +1.16
ICH: +1.52
If i have time again. Will try to do some OS tweaking and see if my 3dmark06 would increase
MSI XPower
Intel Xeon
Seagate 500GB 3GB/s
A4Tech X5-70MD
Fr3aKsTyLeR
« Reply #5 on: 02-January-10, 02:26:59 »
I'm dieing to wait the radeon hd 5870 lightning!!! It would be dream come true! Do u know when it might be bublished? And have to say that that gtx260 is awesome too!
gzhilTopic starter
  • Hardware Reviewer
  • SECOND LIEUTENANT
« Reply #6 on: 02-January-10, 08:36:19 »
Hi there dude. Some say it will be out around february i think :) It would be sweet to have a 5870 Lightning hehehe
MSI XPower
Intel Xeon
Seagate 500GB 3GB/s
A4Tech X5-70MD
r44t_pl
« Reply #7 on: 10-November-12, 23:55:16 »
hi I'm looking for the bios to the card Msi GTX260 Lightning. Or can someone help me?? Pleas.
Froggy Gremlin
  • Master Air OC'er
« Reply #8 on: 11-November-12, 04:39:40 »
This is easily missed among all the review text;
Resurrecting a thread that was started over 3 years ago of a product review is not the right place to request assistance. Recommend to open a new thread in the VGA Section of the forum.
https://forum-en.msi.com/index.php?board=9.0
IXOYE
  • 微星科技
« Reply #9 on: 11-November-12, 05:16:39 »
Thanks Froggy for already pointing out. I removed all the useless quoting from the hijacking post.
r44t_pl,
hijacking and resurrecting other topics is not allowed never do this again. >>Please read and comply with the Forum Rules.<<
With your own issue open an own topic. This is quite obviously a two year old review and not an "ask anything related to this vga" thread. To prevent further hijacking posts in this thread:
TOPIC LOCKED
AMD Ryzen 9 3900X
Windows 10 Pro
