Author Topic: P35 Neo2-FR - driver detected a controller error on \Device\CdRom0  (Read 2789 times)
plevaTopic starter
  • CORPORAL
my computer was hanging for few seconds, I have checked event viewer and discovered that : driver detected a controller error on \Device\CdRom0. event ID 11 .
I have checked cables, DVD was on SATA 5, they were fine and someone told me that it is problem with DVD so I bought new one, but after month problem appeared again.
Then I have plugged DVD SATA cable to SATA 6 and HDD to SATA 5.
Month later problem but now I can see: driver detected a controller error on  \Device\Harddisk0\D ! Again changed cables DVD to SATA 5 and HDD to SATA 6.
Today it hangs again, I got event ID 11 and above it event ID 12: DVD disappeared from system.
What is the problem? Can someone help me please?
Thank you
specs
* CPU model and rated speed:Intel Core E2140
    * Motherboard :MSI Neo2-FR
    * Motherboard Bios :1.9
* Video card:ATI HD3870
    * Power supply:Seasonic SI2 430W
    * Operating System:XP SP3
    * CPU and System Cooling:BOX
    * Memory voltage:2,1V
    * Memory: OCZ DDR2 PC2-6400 Platinum Rev 2 Dual Channel 2x1GB
NovJoe
« Reply #1 on: 29-June-09, 14:19:02 »
Have you tried changing SATA cable instead of SATA ports?
MSI HQ Forum USB flasher
plevaTopic starter
  • CORPORAL
« Reply #2 on: 29-June-09, 16:11:30 »
Hey Joe, no I have not I do not have cable. I will buy it and try, but if cable was broken it shouldn't work with other SATA port??
Today I have changed DVD to other SATA port and DVD is back in system, let's see what will happen.
cheers
Wonkanoby
« Reply #3 on: 29-June-09, 16:33:46 »
Seasonic SI2 430W
another split rail with a meagre 14a on one and 15a the other
can you borrow a better one
P5Q Deluxe
Intel QX 6700
4GB OCZ
60 GB Vertex drive
ATI 5850
plevaTopic starter
  • CORPORAL
« Reply #4 on: 29-June-09, 20:03:25 »
hey wonkanoby
actually not, but what would you suggest to buy?
Henry
« Reply #5 on: 29-June-09, 20:19:36 »
Corsair VX450W (+12V~33A)
