Author Topic: Bios Flash & Raid  (Read 1453 times)
BuD_Sp3NcERTopic starter
  • STAFF SERGEANT
    • French Connection
Bios Flash & Raid
« on: 11-September-09, 10:17:11 »
Will Flashing Bios Loose A raid array that is active?
 X-(( Silly Question , just want to be on the safe side as I've never flashed a machine with raid array  :rolleyes_anim:
Main: | MSI DKA790GX Platinum | AMD 7750+ BE + ZALMAN 8700LED | XFX 4870 1Gb - xxx | SUPER*TALENT 800Mhz  4x2Gb 4-4-4-10  2T (2.1V) | WDC320Gb | HITACHI 2x160Gb Raid0 | LG DVD-RW Sata | CREATIVE Audigy2 ZS | AEROCOOL Masstige-A Chassis | Zalman ZM-MFC1 Plus Fan Controller | ENERMAX Pro82+ 525W | SAMSUNG P2370 LCD | Zboard MERC Game Keys + Sidewinder Mouse | WIN 7
2nd: | MSI K9N Platinum | AMD 5000+ BE | MSI NX8800GT 512mb OC | 2 x 2Gb SUPER*TALENT | 2 x WD Green 500Gb | DVD | Technisat SkyStar 2 HD (Das Original) | ENERMAX Liberty 400W | SAMSUNG 931BW | WIN 7 + Various Linux
Jack
  • Ex Forum moderator
« Reply #1 on: 11-September-09, 10:22:53 »
After the Update and the recommended CMOS Clear that should be done after the BIOS Flash (PSU should be disconnected from A/C power for the CMOS Clear), all BIOS Settings will be lost and need to be reconfigured.  As "RAID" is usually not the default operating mode of the board's controller, it needs to be manually set to RAID Mode in BIOS after the update procedure.  After that, the Array usually functions normally again.
However, it is highly recommended to backup all important data before the BIOS Flash, just to be on the safe side.
In any case, don't update the BIOS unless it is absolutely necessary.
  • STAFF SERGEANT
    • French Connection
« Reply #2 on: 11-September-09, 10:30:55 »
Cheers
