Author Topic: K9A2 CF and Windows 7 64bit  (Read 1449 times)
jsavage
  • Neo
« on: 30-September-09, 16:03:19 »
I am having problems installing 7 64bit, I installed 7 32bit to get the system up and running. In hardware profile it is telling me that this is a ACPI x86-based PC and wont allow me to change it.
I installed the lates bios for this board and the specs for the board say that it is 64bit capable. what do I do?
Stu
  • Hawk
  • Birmingham, UK
    • StuOnline.co.uk
Re: K9A2 CF and Windows 7 64bit
« Reply #1 on: 30-September-09, 20:24:50 »
What problems do you get installing Windows 7 64bit? :think:
Yes thats normal as you installed the 32bit version. What did you expect to be able to change it to?
You need to boot and install from a Windows 7 x64 DVD.
Fredrik
  • Hawk
  • There's always a risk.
« Reply #2 on: 30-September-09, 23:49:20 »
Do you have a spare, newly formatted hard disk to try, again? As little in the system as possible.
Don't be unhappy if you are not successful.
Ex Forum Mod
  • Hawk
« Reply #3 on: 01-October-09, 00:22:45 »
 Will you be running applications/programs that require 64 bit OS? If not why are you trying to install it?
evilgummybear
  • Neo
« Reply #4 on: 24-October-09, 07:22:49 »
hey JS what bios did u update it to?
i couldnt get win7 32bit or 64bit running on mine machine i get a BSOD.
my bios i sitll 1.0 i downloaded the 1.a bios and tried to flash it, it flashed buy my bios hasnt changed its still 1.0
all the flash did was reset my bios configurations, it didnt update.
