Author Topic: MOTHERBOARD DRIVERS DISC  (Read 2841 times)
PongoBongoTopic starter
  • CORPORAL
« on: 20-October-09, 16:31:13 »
Hi folks,
Does anybody use the motherboard driver disc that comes with your motherboard?
My board is a 770-C45. I normally just let the operating system find and install the updates, and use the MSI live to find the required files.
thanks.
Ex Forum User 3
Re: MOTHERBOARD DRIVERS DISC
« Reply #1 on: 20-October-09, 16:36:52 »
For Windows7? No.
For all others, yes, why not? Unless the latest drivers are a must.
  • T9246ED, Бивша комета
  • Administrator
« Reply #2 on: 20-October-09, 17:12:11 »
Well go to MSI driver page and get W7 drivers for your board:
http://eu.msi.com/index.php?func=downloaddetail&type=driver&maincat_no=1&prod_no=1812
Mike
  • aka Frankenputer
  • Virginia, USA
« Reply #3 on: 21-October-09, 10:23:28 »
I thought at first you were asking about W7 from reading posts 2 & 3, but it doesn't seem you specify what OS you are discussing.   If the OS has been out for a while, I use the CD for the chipset, lan, and audio.  But, what I really do is go to the website and download the drivers needed beforehand and put them on a USB drive.  I used live update for 2 weeks when I built my first MSI machine, see system 2, but dumped it after that.  We definitely do NOT advise using a Windows based flash utility, such as Live Update, to flash a BIOS.
#2:
MSI Wind U100
  • CORPORAL
« Reply #4 on: 21-October-09, 11:40:36 »
Yup thats what I do. Ive been preparing for my install of win 7 64 bit. The 32 bit version cant access all the ram.
Cheers!
Ex Forum User 3
« Reply #5 on: 21-October-09, 12:11:59 »
Nor can 64bit if your programs aren't 64bit either.
Mike
  • aka Frankenputer
  • Virginia, USA
« Reply #6 on: 21-October-09, 12:38:35 »
32bit programs won't be able to address all the ram as Bas states either.  Windows7 will bring most of what you need, but download the drivers anyway in case you need them.
#2:
MSI Wind U100
Hans
  • Official Q-Tec Alert Specialist // 正式Q技术机敏的专家
  • LIEUTENANT GENERAL
  • If I fix it, it will never need fixing again!
« Reply #7 on: 21-October-09, 13:58:40 »
Espacially the LAN-drivers.... having those will let you get the rest.
You have a Q-Tec Power Supply? Change that first and come back later...
* MSI P55-GD85, bios 1.3
* Intel Core i7 860 (stock @ 2.8GHz)
* 2x 2048MB TakeMS @ 1333MHz (8-8-8-24, 1T)
* Club3D HD5770 1024MB
* OCZ Vertex 2 120GB (OS and apps)
* 5x Western Digital Caviar Green 500GB in RaID5 (storage)
* 2x DVD Rewriter (LG, Optiarc)
* PC Power & Cooling Silencer 750W
* Cooler Master Stacker CM101
* Dell Ultrasharp 2209AW 22\\\" (e-IPS) monitor
* Windows 7 Professional NL
MSI MediaLive: AMD Athlon X2 4800+, 2x1GB Crucial PC-4200, Seagate 160GB, Pioneer DVD-burner, Hauppauge PWR150 TV Tunercard, Windows 7 Home Premium NL.
MSI X-Slim X620 :like: :like:
Backup: Thecus N5200Pro NAS
