Author Topic: K9AGM2 boot problem  (Read 3225 times)
ze_DufTopic starter
K9AGM2 boot problem
« on: 14-January-10, 02:51:47 »
Hi, all
I have a boot problem. No beep. No display. Power supply and CPU fan running.
I have disconnected everything (HDD, DVD). Same problem.
My mainboard is a K9AGM2, my proc is an AMD AThlon 64X2.
No extension card.
What does "no bip" means ? Is it a CPU, a mainboard or a memory problem ?
I tried without memory ( I have only one), no beep.
I tried with another power supply. Same problem.
Thank you for your help
Ex Forum User 3
Re: K9AGM2 boot problem
« Reply #1 on: 14-January-10, 03:32:25 »
ze_DufTopic starter
« Reply #2 on: 14-January-10, 04:09:43 »
More information :
#  CPU : Athlon64X2 4200+
# Motherboard model : K9AGM2 MS-7327 V1.1 ERP 03
# Memory : 1GB Corsair
# Video card brand : Onboard chipset
# Hard drive(s) brand, size, type, speed : Seagate SATA 500 MB + Seagate SATA 1 TB
# Peripheral cards and devices : None
# Operating system : Dual boot XP + Ubuntu 8.10 64bit
# Power Supply : FSP600-80GLN 600W 3.3V/36A 5V/30A 12V1/18A 12V2/18A 12V3/18A 12V4/18A -12V/0.8A 5Vsb/3A
Ex Forum User 3
« Reply #3 on: 14-January-10, 04:24:23 »
Without memory it will never beep.
Did you connect CPU power?
Did it ever work before?
Did you try with 1 memory stick in slot next to CPU?
Did you try with borrowed known to be good memory?
ze_DufTopic starter
« Reply #4 on: 14-January-10, 06:20:19 »
Thank you for your help.
The CPU 4pin power is connected.
The mainboard 20+4 power is connected.
The PC was working for 2 years.
The memory slot I use is the first one (green near the CPU).
I've been told that a faulty memory should issue a specific beep sequence not "no beep". Am I wrong ?
Does no beep means a mainboard error or a CPU error ?
Ex Forum User 3
« Reply #5 on: 14-January-10, 09:06:08 »
Not beep means the CPU can't start for some reason.
Could be anything from broken memory, bad BIOS flash/settings, broken board, missing 12V to bad CPU.
Start replacing parts until it boots, only way to find it.
How did this start anyway? What did you do before it stopped booting?
Fredrik
  • There's always a risk.
« Reply #6 on: 14-January-10, 09:19:44 »
Yes, sounds like a processor problem. What happened? Did you do something?
