Author Topic: Dragon Naturally Speaking crashes computer. Help!  (Read 5847 times)
krac
  • Neo
« on: 15-January-10, 18:09:41 »
I've done multiple searches, and is it possible I'm the only one with this problem? Dragon Naturally Speaking 9 Preferred installs to my MSI Wind U100 running XP, starts, allows test of mike, and then crashes the whole computer, causing a restart, when I trigger the mike on. I've tried bluetooth and external mikes with the same result.
Stu
  • Hawk
  • Birmingham, UK
    • StuOnline.co.uk
Re: Dragon Naturally Speaking crashes computer. Help!
« Reply #1 on: 15-January-10, 20:18:25 »
What 'crash'? BSOD? Error message? What does it say?
Hans
  • Official Q-Tec Alert Specialist // 正式Q技术机敏的专家
  • Xpower
  • If I fix it, it will never need fixing again!
« Reply #2 on: 15-January-10, 22:18:39 »
Are you sure that  the U100 meets the system requirements for this software? Do you have 1GB RAM in there?
(I suppose it does meet the requirements, since this software won't install if the system does not...)
You have a Q-Tec Power Supply? Change that first and come back later...
* MSI P55-GD85, bios 1.3
* Intel Core i7 860 (stock @ 2.8GHz)
* 2x 2048MB TakeMS @ 1333MHz (8-8-8-24, 1T)
* Club3D HD5770 1024MB
* OCZ Vertex 2 120GB (OS and apps)
* 5x Western Digital Caviar Green 500GB in RaID5 (storage)
* 2x DVD Rewriter (LG, Optiarc)
* PC Power & Cooling Silencer 750W
* Cooler Master Stacker CM101
* Dell Ultrasharp 2209AW 22\\\" (e-IPS) monitor
* Windows 7 Professional NL
MSI MediaLive: AMD Athlon X2 4800+, 2x1GB Crucial PC-4200, Seagate 160GB, Pioneer DVD-burner, Hauppauge PWR150 TV Tunercard, Windows 7 Home Premium NL.
MSI X-Slim X620 :like: :like:
Backup: Thecus N5200Pro NAS
Fredrik
  • Hawk
  • There's always a risk.
« Reply #3 on: 16-January-10, 02:51:39 »
From Googling I find the program has problems with some auto-starting programs.
Also if you have what they call "custom" words, your own, you have to do some work. But I guess you haven't got that far?
Here is another troubleshooter, but it is a lot of reading. Hope you can cope!
http://www.speechcomputing.com/node/940
NovJoe
  • Hawk
« Reply #4 on: 16-January-10, 04:48:44 »
This is probably Nuance driver problem. I used their other VR software, Powerscribe and so far no problems on XP systems.
Whenever I have an issue, I'll just call their International Support desk for help.
MSI HQ Forum USB flasher
Hans
  • Xpower
« Reply #5 on: 16-January-10, 10:46:51 »
That's probably the best thing to do here.
1. it's most probably a problem with the program itself or
2. the netbook isn't up to the task, which I doubt, as said before.
Did you contact their support already?
Ex Forum User 3
  • Hawk
« Reply #6 on: 18-January-10, 11:29:40 »
Systemrequirements tell you to use a P4 2.4GHz of higher and it will not work on less then 1GHz.
However, this is an Atom CPU and doesn't even match a P4 1.6GHz CPU.
Even if you get it to run, it will not work well, there CPU isn't powerful enough for such tasks.
krac
  • Neo
« Reply #7 on: 18-January-10, 15:37:26 »
Dragon Naturally Speaking recommends CPU speed 1GHz or greater.
1GB RAM (512 MB free minimum)
 My MSI Wind U100 netbook has the Atom N270 @ 1.60 GHz with 2 GB RAM installed.  The OS is Windows XP Home SP3.
Post-crash information was as follows:
BCCode : 1000008e     BCP1 : C0000090     BCP2 : A9292703     BCP3 : A7E0FB10
BCP4 : 00000000     OSVer : 5_1_2600     SP : 3_0     Product : 768_1
It doesn't crash until you put the microphone on.  Is it possible nobody else in the world has tried installing this on a netbook?
NovJoe
  • Hawk
« Reply #8 on: 18-January-10, 16:07:25 »
Nope. All my nuance VR software are installed in workstations for realtime reporting.
Have you tried contacting Nuance yet?
pixelKix
  • Neo
« Reply #9 on: 09-April-10, 00:17:59 »
Some people have reported that the RealTek software causes problems.  They say that you must turn off the RealTek microphone features like noise suppression, echo cancellation, and beam forming.  Here is the source of this information:
http://dreamlusion.wordpress.com/2008/05/24/using-dragon-naturallyspeaking-with-a-realtek-chipset/
I hope this helps you!
