Author Topic: Needed BIOS 8.3 for MSI 785GTM-E45  (Read 13365 times)
bhokuto
  • Easy OC
« on: 28-February-10, 09:51:14 »
Hello, Greetings,
I went to this page: --Met with Live Up Date Icons, no files to Download
 http://www.msi.com/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=1883
What's up with this picture?
I have second MSI 785GM-E65, Downloaded the New BIOS 2.4 right to my Hardrive, right from my Browser.
No problem with this picture.
Please straighten this out.
I need the dam file.
Bobo
MSI 785GM-E65
AMD Phenom 2 X4 955 C3 BE
4Gb 1333MHz DDR3 Corsair 1.5v
MSI R5670 HD Radeon 1Gb DDR5
Windows Vista x32 SP2
MSI 785GTM-E45
AMD Phenom X3 8400
  • T9246ED, Бивша комета
  • Administrator
    • MSI BIOS/EC-FW Mods
Re: Needed BIOS 8.3 for MSI 785GTM-E45
« Reply #1 on: 28-February-10, 11:32:59 »
here it is
bhokuto
  • Easy OC
« Reply #2 on: 01-March-10, 05:25:42 »
Thank you kindly,
much appreciated :biggthumbsup:
MSI 785GM-E65
MSI 785GTM-E45
AMD Phenom X3 8400
  • Administrator
« Reply #3 on: 01-March-10, 05:31:39 »
 :hat tip:
panca sj
  • Neo
« Reply #4 on: 16-March-10, 06:05:10 »
sir,
do you have a lates BIOS for this mobo
need an official one, not a beta
my version, doesn't come with core unlocker feature (still the old BIOS)
  • Administrator
« Reply #5 on: 16-March-10, 12:07:27 »
sir,
Here it is
Pointlisse
  • Cyclone
« Reply #6 on: 28-April-10, 05:25:31 »
Does anyone have the 8.5? I think this is the one that is supposed to support the 6-core CPU line.
I have 2 MSI boards and I have never gotten the live update to work properly  :nooo:
Jack
  • Ex Forum moderator
  • Power Edition
« Reply #7 on: 28-April-10, 07:41:43 »
Such a version does not exist (yet).  The latest version of the A7549AMS.8xx-series is v8.40 (release date: 02/25/2010).  There is no newer version.
Pointlisse
  • Cyclone
« Reply #8 on: 28-April-10, 13:25:09 »
This website:http://event.msi.com/mb/amd/6core/ lists this BIOS version:A7549AMS.850
with a link to the update page. However since live update does not work, I can't see if it's there or not.
Any idea where I can download it (or 8.4 for that matter). Also, is there any release notes anywhere for these versions?
Thanks!
Mike
  • aka Frankenputer
  • Power Edition
  • Virginia, USA
« Reply #9 on: 28-April-10, 18:16:12 »
Use the forum flash tool.  Choose Surehands.
>>Use the MSI HQ Forum USB flasher<<
#2:
MSI Wind U100
jebo_4jc
  • Neo
« Reply #10 on: 30-April-10, 02:50:37 »
I tried surehands and it reports this mobo is not a live update compatible mobo
  • Administrator
« Reply #11 on: 30-April-10, 12:52:58 »
Thanks!
Your board is not supported yet by Tool's Live Update, [will be added with next version]
Use Mode 1[Point to MSI BIOS archive] instead and point to the archive attached below.
Pointlisse
  • Cyclone
« Reply #12 on: 30-April-10, 13:24:01 »
Thanks for attaching. Are there any release notes anywhere? I have BIOS 8.2 for my 785GTM-E45 already -- but other than the x6 support, I have no idea what changes there are or if it's worth upgrading (I don't yet have the X6 CPU).
  • Administrator
« Reply #13 on: 30-April-10, 13:27:34 »
Changes in ver. 8.3:
-  Support SATA HDD up to 2 TB.
-  Add Energy Star LOGO.
Changes in ver. 8.4:
-  Update CPU AGESA code.
Changes in ver. 8.5:
-  Support AMD 6 core CPU.
-  Fixed system report incorrect HDD size after disable LBA mode.
jebo_4jc
  • Neo
« Reply #14 on: 30-April-10, 15:46:01 »
Thanks for the help Svet.
I also noticed that 8.50 is appearing now in MSI's live update download tool (not the web version, the download version).
So, looks I won't have to force stock speeds via AMD Overdrive anymore :)
Thanks again
Pointlisse
  • Cyclone
« Reply #15 on: 30-April-10, 17:11:10 »
+1
Thanks Svet!
  • Administrator
« Reply #16 on: 30-April-10, 22:09:48 »
 :hat tip:
razor_amd
  • Neo
« Reply #17 on: 06-July-10, 16:53:58 »
Thanks for the bios Svet (World)  8-)) ;D
raada4
  • Winki
« Reply #18 on: 03-August-10, 22:52:08 »
Forgive me if this isn't proper place. I have a MSI 785GTM-E45 and an AMD 1055T that I would like to try in that mobo. I believe that may be possible with latest BIOS. My problem is that mobo is not in an on-line computer. It is not prepped for that feature. Is there a way to get the latest BIOS and flash tool without using that computer? I have been flashing mobo's for years and using floppy, USB drive or CD in a DOS boot does not bother me. If BIOS files were listed for download for this model, I wouldn't be asking.
  • Administrator
« Reply #19 on: 04-August-10, 01:37:42 »
what's current bios version installed?
raada4
  • Winki
« Reply #20 on: 04-August-10, 10:49:40 »
8.0
  • Administrator
« Reply #21 on: 04-August-10, 13:24:28 »
8.0
Changes in ver. 8.6:
 This BIOS fixes the following problem of the previous version:
8.6, 05/13/2010
If you gonna flash it, ==> >>Use the MSI HQ Forum USB flasher<<
Whatever you do: DO NOT USE M-Flash to update the BIOS!
raada4
  • Winki
« Reply #22 on: 04-August-10, 21:01:22 »
Many thanks, but I thought "surehands" indicated a web based flash?
Stu
  • Hawk
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #23 on: 04-August-10, 21:25:53 »
No, the BIOS file is attached to Svet's reply above. Point the MSI tool at that RAR file.
raada4
  • Winki
« Reply #24 on: 06-August-11, 16:35:18 »
I hear there is a version 8.8 for the msi 785gtm-e45 bios. Any chance I can download it directly? That computer is not on the net.
Jack
  • Power Edition
raada4
  • Winki
« Reply #26 on: 06-August-11, 17:31:58 »
 :biggthumbsup: Thanks!
