Author Topic: MSI K9N6PGM2-V2, needing a parallel printer port adapter,,,,,,,?  (Read 3889 times)
coadmanTopic starter
I have this motherboard....MSI K9N6PGM2-V2......, and I have an old Epson AP5000 printer that we use for a Rural Water District Software program.  My wife does the books.  I recently upgraded the old computer to this new one with the MSI K9N6PGM2-V2 motherboard.  Only problem, it does not have the old 25 pin connector for this printer.  Some friends suggested buying a cable, which I did, to plug into the motherboard, it is an "IDC 26/DB25 motherboard parallel port connector cable".  Looks like it would fit, but when I physically tried to install the cable, the end of the cable is "too" wide for the slot on the motherboard, which is (JLPT1).  I am at a loss, as other adapter cables look to be exactly what I purchased.  Any help would be greatly appreciated, as my wife is getting very "upset" with me, as she needs to do her water books by tomorrow!
thanks so much,
coadman
Grayone
  • LIEUTENANT GENERAL
« Reply #1 on: 28-April-10, 15:13:50 »
One of these PCI slot to parallel port cards might fit your needs and would be transferable to another system if needed.
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=2010010073%201187112435&name=PCI%20to%20Parallel%20Port%20Card
DKA790GX Platinum w/Phenom II 960T unlocked to 6 cores
4 gig GSkill DDR2 800 @5-5-5-15-2T
N460GTX & N450GTS
Corsair 650TX  12v-52 amps
Windows XP-SP3
G31-M7 w/Q9400 @3.28GHz @1.312v
2Gb DDR2 800 @5-6-6-15-2T
GTX460 Hawk video card
Seasonic 520 Watt S-12 12v-40amps
Windows XP-SP3 - Folding 24/7
Stu
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #2 on: 28-April-10, 18:56:46 »
Henry
« Reply #3 on: 29-April-10, 00:44:52 »
 What is the pitch of the header pins, 2.0mm or 2.54mm?
A similar question as yours is here, different MB though.
   https://forum-en.msi.com/index.php?topic=133421.msg1003275#msg1003275
