Author Topic: New Nf980-g65 board refuses to post please help  (Read 4793 times)
ZhanyTopic starter
Hi everyone I just purchased a nf980-g65 board and installed the cpu a phenom II 945 and connected everything and the board will not post no beeps fans spin up and one power phase light comes on. If I removed the ram however the board will make 3 long beeps without the ram installed I did a bench test no change with ram installed the ram is patriot pdc32g1333elk is the ram causing an issue or what could be wrong?
Henry
Re: New Nf980-g65 board refuses to post please help
« Reply #1 on: 10-July-10, 00:15:38 »
 Please, more info on your system.  >> Posting Guide <<
ZhanyTopic starter
« Reply #2 on: 10-July-10, 00:31:16 »
Cpu is a phenom II x4 945
Power supply Seasonic S12d 750w +12v1 40amps +12v2 40 amps +3.3 24 amps +5v 30 amps
Ram: patriot pdc32g1333elk 2x 1gb 1333mhz ddr 3
Hard Drives: 2x 640gb sata 2 drives Western Digital 7200rpm
Motherboard Model Name: NF980-g65
Bios Version: Unknown
Sound Card: soundblaster extreme gamer
Video Card: EVGA GTX470 Superclocked edition 1280mb
Operating System: Windows Vista 64bit
Henry
« Reply #3 on: 10-July-10, 00:50:03 »
 Are all power plugs in for CPU (4/8 pin), VGA card? Reseat your parts and ensure all of your power plugs are in.
ZhanyTopic starter
« Reply #4 on: 10-July-10, 01:07:58 »
everything is plugged in and all cables are secure and attached according to the manual at least correctly
  • T9246ED
  • Administrator
  • Online Online
« Reply #5 on: 10-July-10, 06:31:07 »
Is this a new build?
Does it worked before?
Have you tried to boot with barabone setup and mainboard of PC case?
Do >>Clear CMOS Guide<< with power cord removed,
leave 1 memory stick in 1st DIMM close to CPU socket. Then try to boot.
This is Intel's tested memory.. ==> http://static.compusa.com/pdf/Patriot-PDC32G1333ELK-datasheet.pdf
• Tested and compatible with Intel
 P35, X38 and X48 chipsets
ZhanyTopic starter
« Reply #6 on: 10-July-10, 09:16:53 »
The build is new and has not worked before I tried the barebones way both inside and outside of the case no boot. I did a cmos clear by removing the battery and setting the jumper and leaving it for a few minutes then it started something called bios recovery mode and I found the bios for the board and loaded it to a usb flash driver formatted as fat32 as the system requested it could find the flashdrive but would not read the bios file no matter what version is on it.
Saddletramp
  • SECOND LIEUTENANT
« Reply #7 on: 10-July-10, 17:10:28 »
Did you try flashing the BIOS with the MSI USB Flash Tool?? Found here:  https://forum-en.msi.com/index.php?topic=108079.0
Also, try and get some memory that has tested compatible with this board.  Found here:  http://www.msi.com/uploads/test_report/TR10_1885.pdf
Case: Cooler Master MidTower NV-690C-KWN2-GP nVidia Edition w/7 Fans
PSU: CORSAIR TX950W +5V/25A  +3.3V/25A  +12V/78A
MB: MSI NF980-G65 SLI MB w/AMD Phenom II X3 720 Black Edition
CPU Cooer: Artic Cooling Freezer 7 Pro Rev.2  CPU Fluid Dynamic Fan Cooler
MEM: G. Skill Ripjaws 4x2GB DDR3 1600
TV Tuner: Hauppage WinTV 2250 PCIe
Video: MSI GeForce N250GTS Twin Frozr 1G OC
HDD's (All Sata): WD 320GB/WD 500GB/Seagate 1TB/WD 1TB
HP Multimedia KB/Logitech Marble Mouse Trackball
DVD Writer: ASUS DRW-2014S1
Monitor/TV: 27" LG M2762D Widescreen LCD
OS: Windows 7 Home Premium
Ex Forum User 3
« Reply #8 on: 10-July-10, 17:14:23 »
Use AMD memory, not Intel memory, then you know for sure.
ZhanyTopic starter
« Reply #9 on: 10-July-10, 17:52:59 »
Switching the memory worked perfectly thank you for all your help :D
