Author Topic: msi 890gxm-g65 overclocking problem  (Read 4066 times)
greedyisgoodTopic starter
  • SERGEANT
« on: 17-July-10, 09:23:58 »
Before when overclocking fails it shows an error message in the POST but now it will not POST anymore wherein led1 is lighted and my graphics card fan is blowing at 100%. What I usually do is to turn off my pc for about 5 minutes then turn it on again where everything works fine again including the overclock settings set previously is saved. Any idea what seems to be the problem?
bios v1.6
phenom II x6 1055t
xfx 5870
corsair TW3X4G1600C9D 2x2gb ddr3-1600
wdc 640gb green
ocz stealthxstream 600w
w7 ultimate 32bit
intel core i7 2600k @stock
msi h61mu-e35-b3 (bios v10.5)
asus gtx 560ti directcuII @stock
geil single 2gb ddr3 1333 9-9-9-24 1.5v
wdc 640gb green 7200 rpm
corsair hx650w
noctua u9b se2
samsung 22x dvdrw
3x120mm fan, 2x92mm fan, 1x3.5 fan controller bay
Windows 7 Ultimate 32bit (updated)
Bernhard
  • GENERAL
« Reply #1 on: 17-July-10, 20:14:10 »
Unplug the power and do a CMOS reset.
1.B350F Gaming; R5-1600; Crucial MX300 275GB, Ballistix Sport LT BLS16G4D240FSC 2X8gb; Sapphire RX580 Pulse 8gb; Seasonic750W; Win10-64; LG DVD
2.FUJITSU LIFEBOOK S751 QM67;i5-2520M;2 X 4GB 1333Crucial CT256 MX100; Win10-64; Orico Dual Bay USB3 Dock
"veni vedi doctus"
MSI 미친
  • SERGEANT
« Reply #2 on: 18-July-10, 05:48:58 »
I did reset the cmos still the problem exist
corsair hx650w
noctua u9b se2
samsung 22x dvdrw
Bernhard
  • GENERAL
« Reply #3 on: 18-July-10, 20:13:28 »
Try with only one memory module. If you can then get into your BIOS, set your memory speed to 1066 for now.
Also read this post. https://forum-en.msi.com/index.php?topic=130042.0
"veni vedi doctus"
MSI 미친
  • SERGEANT
« Reply #4 on: 19-July-10, 13:51:02 »
My system works fine but what I want to know is the reason why my mobo does not show any error messages anymore when overclocking fails, switching OC profiles and hitting f10. Wherein it will not POST, displays black out screen and graphics card fan blowing 100% that I need to wait for another 5 to 10 minutes in order for my system to boot up properly.
corsair hx650w
noctua u9b se2
samsung 22x dvdrw
hitec16
« Reply #5 on: 02-February-11, 08:53:38 »
i have the same mobo and cpu aswell but bios version is 1.7
someone on internet told be that this mobo isnt good for OCing x6 cpu he has seen over 6 cases of blowing up :(   :confused2:
so i m not OCing anymore with this board the max i cud go was around 3780Ghz with all voltages at auto except cpu v at 1.4
The lastest bios is v1.8 lets see if it helps
hitec16
« Reply #6 on: 02-February-11, 08:55:49 »
the same thing happens with me when i take FSB to 280 while OCing the system wont boot for a while and i havnt checked the LED light and GPU fan when it happened  :bonk:
