Author Topic: MSI K9AGM3-F and AMD Phenom II Processors  (Read 4861 times)
Glenski3Topic starter
« on: 01-August-10, 13:07:59 »
Hello
Can someone tell me if i am able to run/use any of the following AMD Phenom II Processors on my MSI K9AGM3-F Motherboard ?
1, AMD Phenom II X4 955 Black Edition Socket AM3 3.2 GHz 8MB L3 Cache (Wattage   125 W)
2, AMD Phenom II X4 945 3.0GHz Socket AM3 6MB L3 Cache (Wattage - 95 W)
3, AMD Phenom II X4 925 2.8GHz Socket AM3 8MB Cache
My current setup is listed in my signature below
Thank you
Glenn
MSI K9AGM3-F Motherboard (MS 7367) BIOS 3.70
AMD Athlon II X4 630 (Propus - 2.8 GHz) Processor
4GB - 2x 2GB DDR2 PC2-5300 (333 Mhz) Team Group Inc. Memory
NVIDIA GeForce GT 220 (1024MBytes) Graphics Card
1TB HDD Storage (Hitachi 500GB SATA 7200 rpm/Western Digital Caviar Blue 500GB SATA 7200 rpm)
Creative Sound Blaster Audigy 2 EX 24-bit Sound Card
Plextor PX-W5224A PlexWriter CD-RW / LG HL-DT-ST DVD-RAM GH22LS30 DVD-RW Lightscribe
Microsoft Windows 7 Home Premium x64 OS
CiT 600W PSU Dual 12V Rails
Virgin Media 50Mb Cable Broadband.
Jack
  • Ex Forum moderator
« Reply #2 on: 01-August-10, 13:13:09 »
http://eu.msi.com/index.php?func=prodcpu2&prod_no=1346&maincat_no=1&orderby=cpu_name%20ASC#menu
Thank you for that link - and i have already taken a look at the list, however my current processor setup 'AMD Athlon II X4 630 (Propus - 2.8 Ghz) Processor' is not listed on there, but is what i am using on my system now.
So you see my dilema !! will the listed processors above work on my board ?
Thank you
Glenn
Mike
  • aka Frankenputer
  • Virginia, USA
« Reply #3 on: 01-August-10, 13:44:56 »
You should contact MSI's official help.  I'm not sure if they have tested the CPUs in question on your machine, but it won't hurt to ask.  MSI will know better than we--we're users here just like you.
>>How to contact MSI.<<
#2:
MSI Wind U100
« Reply #4 on: 01-August-10, 13:50:01 »
Okay, it looks as if that is my only route...
Thanks for the reply
Glenn
The_Qbas1
« Reply #5 on: 11-November-11, 16:35:46 »
Phenom II x4 955 (HDZ955FBGMBOX) is working, but it's running only 800 MHz (x4 multiplier)
Henry
« Reply #6 on: 12-November-11, 05:00:07 »
 The_Qbas1, if you have a problem please start your own new topic instead of hijacking and resurrecting an old dead one.
