Author Topic: Wireless Connection Problems! Need Help...  (Read 1604 times)
CRAFTYTopic starter
« on: 03-August-10, 18:53:51 »
Hi everyone, just to say I'm not a PC wizard of any kind so kinda need simple instructions :bonk:
I've just bought an MSI AE1900 & a Belkin 'N' Wireless Router but cannot get the PC to connect to the router even with the routers CD.
When I try to connect by clicking on the available wireless networks (The MAC Address from this PC has been added to my router) it Say's Windows was unable to find a certificate to log you onto the router.
And even if I try to connect using the set up assistant disk that came with the router it Say's The setup assistant is not able to connect to the router via any of the network adapters in this computer.
Anyone have any idea's or am I going to find out that I need to buy a new router as this PC's WLAN adapters aren't compatible with the Belkin 'N'?
