Author Topic: G41M-P33 EZ OC Switch  (Read 5746 times)
MilpitasTopic starter
« on: 12-December-10, 01:49:19 »
I have a new G41M-P33, latest bios 7A, running Intel Q9300 Yorkfield (Stepping 7, Revision M1) with 4GB DDR3-1333. When I try to increase the FSB from 333 (default) to 400 using the EZ OC switch (all down, OFF position as per manual), nothing changes: Prime95 running, Core Speed @ original 2499.9 MHz, Bus Speed @ original 333.3 Mhz. Is there something else that needs to be done, besides setting the EZ OC and disabling Spread Spectrum, to change the FSB speed? Is the motherboard defective?
TIA
Jack
  • Ex Forum moderator
Re: G41M-P33 EZ OC Switch
« Reply #1 on: 12-December-10, 02:42:31 »
Did you >>Clear CMOS<< after changing the switch positions?
« Reply #2 on: 12-December-10, 03:11:29 »
I did not manually use the jumper to clear the CMOS, but I did try different versions of available BIOS with optimized defaults loaded each time; I assume the process of updating the BIOS from DOS cleared the CMOS. The manual didn't mention clearing the CMOS each time, only that the power be off.
Jack
« Reply #3 on: 12-December-10, 03:17:28 »
Well, do it then:  Unplug your PSU from A/C power and >>Clear CMOS<< after switching to 400 MHz FSB Clock Speed.
« Reply #4 on: 12-December-10, 03:41:29 »
Still no difference.
Jack
« Reply #5 on: 12-December-10, 03:52:34 »
If you are absolutely sure that the Switches are in the proper position for 400 MHZ FSB Clock speed and there is absolutely no effect, then it is probably safe to assume that the switches are not working.  This means a defect regarding this particular board feature which calls for an RMA and/or a replacement board.
« Reply #6 on: 12-December-10, 03:58:21 »
I'll exchange the board at the store tomorrow.
-Thanks
jmysaputra
  • STAFF SERGEANT
  • Im Just A Game Soldier
« Reply #7 on: 11-February-11, 05:02:59 »
dont do the OC Switch with G31,G41,P41,P43 or P45 chipset. its dosnt work, The OC Was Fail.....(the BIOS says that) :hat tip:
Home PC (System Updated):
MSI P41-C33 AMI BIOSv10.9,MSI N450GTS Cyclone 1GD5,Intel E5700@3.0GHz OC 3.720Ghz,Mltp 12x,FSB 310 @ 1.392V,AVEXIR 4GB KIT 1333/8-8-8-20 2T,WD320 BLUE,SAMSUNG DVD-RAM 22X,AOC LED 1943w,XIGMATEK NRP400W,COOLER MASTER Elite335,COOLER MASTER HyperTX3,ALIEN G9
Office PC :
MSI P35 Neo2 FR.BIOSv1.9,Intel E7400 @ 3.6ghz,Gigabyte 8800GT,2x1gb VenomRX 800 5-5-5-15,Samsung 22x,Acer163W,Extreme 400w,DeepCool IceEgde300,Seagate160gb,VenomRX KeelBack14.
http://valid.canardpc.com/show_oc.php?id=1829720
http://www.techpowerup.com/gpuz/d4w7n/
jan.zobec8899
« Reply #8 on: 17-March-20, 00:44:12 »
Dude how did you oc the mobo and cpu to work with ddr3 1333mhz. I have an e6420 and same mobo bought the ddr3 1333 ram and three beeps(doesent detect it), please help.
  • 微星科技
« Reply #9 on: 17-March-20, 10:45:37 »
This thread is 9(!) years old... Don't resurrect old threads.
>>Please read and comply with the Forum Rules.<<
:floblock:
AMD Ryzen 9 3900X
Windows 10 Pro
