Author Topic: P55-GD80 odd behaviour lately?!?  (Read 2353 times)
.Griff.Topic starter
  • CORPORAL
« on: 29-December-10, 13:57:33 »
My main PC consists of the following components -
i5 750, MSI P55-GD80, Geil Ultra Series PC3-17000, Nvidia GTX 480, Crucial C300, Galaxy Enermax EGA850EWL
For about 14 months (September 2009 - late November 2010) everything was perfect. I used OC Genie which overclocked my i5 750 from 2.66 ghz to 3.67ghz and this how things were fine until one afternoon recently.
About 4 weeks ago I came home and switched on the PC as normal only to find POST took a really long time and there was no sign of my SSD. I checked in BIOS and there was no sign of it there either. I tested it in another PC and sure enough the SSD was dead and I've subsequently RMA'd it back to Crucial.
However this was just the start of my problem that began that afternoon. Ever since that day ANY manual overclock attempt has failed and resulted in an almost instant BSOD once Windows loads. If I use OC Genie then Windows runs for a few minutes before more BSOD's brings the party to and end. It all seems a coincidence that on the same day my SSD dies I get all this instability issues with the motherboard that behaved perfectly for the previous 14 months.
I've updated to the latest BIOS and it's made no difference.
I guess my question(s) is this. Could something have happened to the motherboard that effectively took out my SSD and left the board unstable ever since? Why would the board run a stable overclock, via OC Genie, for 14 months and then suddenly BSOD if the board was overclocked in the slightest?
Any help or advice would be appreciated.
claykin
  • SECOND LIEUTENANT
Re: P55-GD80 odd behaviour lately?!?
« Reply #1 on: 29-December-10, 23:43:17 »
Does the system run OK if not overclocked?
There could be some coincidental stuff going on.
Check your PSU voltages.
Consider trying some other RAM (like Crucial/Micron or Corsair).
Have you tried running DOS benchmarking to see if the system is unstable even without Windows?
It could be a failing component, most likely a capacitor, but more likely to be RAM or PSU.  Also keep in mind that a firmware/driver update (i.e. your Crucial C300) could also throw things off.
MSI P55-GD85 (no overclock) | i5-750 | Crucial 4x2GB DDR3-1333 CL9 | 2 x WDC 300GB Raptors in RAID1 (Intel PCH) | MSI Radeon 5750 1G PCIe | Plextor PX-880 DVD+/-RW | Liteon iHAS-424 DVD+/-RW (Sony version) | Corsair HX650 PSU | Antec P-183 Case
  • CORPORAL
« Reply #2 on: 30-December-10, 04:30:18 »
If I run it at stock clocks then it's absolutely fine but the slightest overclock fails each and every time.
As for the RAM I decided to run Memtest and here are the results -
It says there's no errors so can I literally take it that the RAM is in fine working order?
Secondly I bought the RAM as it was specified as PC3-17000 and I thought that would be beneficial when it came to overclocking but why does Memtest show it as PC3-10600?
Mike
  • aka Frankenputer
  • Virginia, USA
« Reply #3 on: 30-December-10, 10:05:51 »
Since it runs fine at stock and what you're trying to do is overclock, I moved it here.
#2:
MSI Wind U100
neoroy
  • FIRST LIEUTENANT
« Reply #4 on: 15-January-11, 05:49:05 »
Hai Griff, maybe OC genie is not stable after long period, have u tried oc manual? here try my setting since we have same procie and mobo :
-Vcore : 1.275v
-vtt : 1.22v
-vdimm : depends on ur ram
-PCH 1.8 : auto (1.8v) -----> is it cpu pll?
-PCH 1.050v : auto (1.064v)
-bclk : 200
-Cpu ratio : 20 so 200x20=4ghz :)
-QPI ratio try to find lowest for maximum stability
-Memory frequency/ratio try to find abit lower or abit higher from ur default speed ram
Btw when overclocking disable all cpu features including EIST and C1E also Intel turbo boos for maximum stability when doing stressing stability program, also Load line calibration set to disabled to improve vdroop so when doing stressing stability program ur vcore dont drop to far :) this is reverse from gigabyte mobo, i used to have P45 UD3P and i have to enabled LLC to improve vdroop.
Uploaded with ImageShack.us
Intel Xeon E5-2623 V3 @3.3GHz
MSI X99A SLI Krait Edition
GALAX GTX980Ti GOC LN2 @1500MHz stock volt
Gskill Ripjaws V 4x4G 2400MHz DDR4
Pioneer SSD APS-SL3N 240GB
Seagate HDD 1TB 7200rpm SATA3
Seagate HDD 500GB 7200rpm SATA3
DELL U2713HMT
CoolerMaster SilentPro M2 1000W Silver
Cooler Master Hyper 212X Turbo
Razer Mamba TE Chroma
Razer Goliathus Extended
SAMSUNG Bluray Combo SH-B123L
Windows 10 Pro 64bit
