Author Topic: I5 2400 / TeamXtreem 2x2gb 1600 /MSI P67-GD65 problems ....  (Read 10371 times)
BulletTopic starter
  • CORPORAL
Ive just bought  an new kit:
-Coolermaster 212Plus
-Core I5 2400
-MSI P67A-GD65
-TeamXtreem PC3 12800 DDR3 LV 1600 MHz CL7 (2*2GB)     http://www.teamgroup.com.tw/teamgroup/en/productDetail.php?pd_id=533&pl1_id=1&pl2_id=59
and my old components Psu Corsair 650W ,Evga GTX 295 , 2x 1 tb Seagate , and my "antique" Audigy 2 ZS PCI
Ive maid last bios update 1.7  on motherboard  .
From time to time i experience sistem hang on first power of the sistem  - usually leds are all  blue  but nothing apear on the screen , sistem dont initialize  ; other times i get first 3 leds  blue  and sistem dont initialize ; after 4-5-6-7 resets  finnaly sistem boot and i can use him at full potential .
1. Ive tested my Vga with furmark,3dmark,MSI Kombustor  - its ok
2. my monitor its ok
3. Psu its ok
ive read  on internet about a "Cold power" issue on many 1155 motherboards  - i mean u power sistem  , sistem hangs for a time and after many resets it starts and if u restart  it its working ok .
 i suspect thare is a bios problem around CPU-MB-MEMORY-And the rest of devices VGA/Sound PCI maibye cant be detected ....
thank u in advance.
I5 2400 * CoolerMaster 212 Plus * MSI P67A-GD65 * TeamXtreem 2x2gb 1600 (7.9.7.24) * EVGA GTX 295 * 2 x 1 TB Seagate * Creative Audigy 2 ZS * DVD-RW ASUS 22X * Case TT Shark Silver * PSU Corsair 650w *  Monitor Sony 19'' * Mouse Logitech G9 / Keyboard Logitech G 15 Rev. 2
BulletTopic starter
  • CORPORAL
Re: I5 2400 / TeamXtreem 2x2gb 1600 /MSI P67-GD65 problems ....
« Reply #1 on: 21-January-11, 02:18:50 »
For the moment memory in on slot 2/4   but i tried them in 1/3 same problem .
This manifests only on first startup of the sistem ,   i need some advices or  hints  on 1155 soket - if i cant find a sollution i am obligated to change  mainboard brand ...
I disable from bios "serial" controler ... after i come from work i will check if problem persists.
This wekend i have more time to test sistem.
Froggy Gremlin
  • Master Air OC'er
« Reply #2 on: 21-January-11, 04:05:29 »
Try with just one stick RAM in the primary dimm slot (blue closest to the CPU). Try both sticks individually in that slot. Disable Spread Spectrum & EUP 2013. System is not like 775 socket, going to slots 2 & 4 don't work. In the OC & Modders Section of the forum, in brattak's thread is a beta 1.8b6 BIOS along with necessary information of using the forum USB Flasher utility along with it. Give that a try. What OS are you using?
IXOYE
BulletTopic starter
  • CORPORAL
« Reply #3 on: 21-January-11, 07:11:23 »
 i use windows 7 ultimate 64 bits .
i will try what u say about the new bios/settings , i hope it works  , dono its a bad feeling spending an amount of money on something  that does not works....
BulletTopic starter
  • CORPORAL
« Reply #4 on: 21-January-11, 13:01:55 »
Now besides boot problem -  windows is freezing (all usb devices die Kb-mouse) after 10 min  & random even after 1 h only browsing on internet - or watching a movie ....
Cant express exactly what i feeling  :sad:  ......   if  this platform  was not tested 100% by intel  why they release it on market  ??
Froggy Gremlin
  • Master Air OC'er
« Reply #5 on: 21-January-11, 14:32:20 »
It may be RAM related. Recommend to set RAM manually to 1333, CR 1, 9 9 9 24, tRFC 88 - 107 range, DRAM V. on Auto & see if it will be stable. BIOS flash successful?
IXOYE
BulletTopic starter
  • CORPORAL
« Reply #6 on: 23-January-11, 03:23:35 »
 I did not flash bios with Beta yet , i prefer a oficial release;
 I tested ram and all that settings as u said (1333) ,but  after few min (Random: 10 -> max 1h) sistem freeze and all usb devices unpowered (kb,mouse dead)  so i suspect is something related to usb.
I must mention that kb and mouse are  in usb 2.0 port's from mb   ( i also tested them on usb 3.0 ports same  problem)
Froggy Gremlin
  • Master Air OC'er
« Reply #7 on: 23-January-11, 04:22:00 »
With everything stock/auto/default regarding RAM, what is SPD setting? Could you post screenshots of CPUID's CPU-Z Memory & SPD Tabs for comparison? As in my sig., using beta BIOS 1.8b6. I read you would rather not try a beta, but at some certain point, there is nothing to lose.
Newest USB controller drivers loaded? Power related setting regarding USB in either Windows Power Option or BIOS Power Management?
IXOYE
BulletTopic starter
  • CORPORAL
« Reply #8 on: 23-January-11, 07:31:03 »
About beta bios - ive tested in the past and i have somme bad experience with them .
Uploaded with ImageShack.us
Here u have a print - sistem is stable even for 40 min ( in this pic is 20min )  but after a time  sistem is freezing - my G15 kb is unpowered /also mouse and i must reset .
My last kit was Q9550/muskin 4g 1066/ GB EP 45DS4    and it was stable the only componentes i changed are just CPU 2400  + MB MSI + Team Xtrem RAM .
Froggy Gremlin
  • Master Air OC'er
« Reply #9 on: 23-January-11, 16:24:35 »
RAM speed & timings look to be in order. What does BIOS H/W Monitor show for CPU & System temp, as well as CPUID's H/W Monitor?
IXOYE
BulletTopic starter
  • CORPORAL
« Reply #10 on: 24-January-11, 02:08:50 »
temp around 30-33 degrees celsius
Froggy Gremlin
  • Master Air OC'er
« Reply #11 on: 24-January-11, 02:29:52 »
Temp is fine.
If you still have your V1.7 BIOS file, could you explore it & see if the ME update is shown as part of the package? Should read like I got blocked in red.
Added: A suggestion. These boards have a backup BIOS, even if you brick the primary, you should still be able to boot off the reserve. Why not give the 1.8b6 a try?
IXOYE
BulletTopic starter
  • CORPORAL
« Reply #12 on: 24-January-11, 03:00:18 »
yes all files are there , bios was downloaded from msi site  -  i copied al files on my usb stick (bootable)
- i check from bios primary boot device: Usb stick
restart
imput comand         7681v17   (as in bios manual)  enter
it also update firmware .
I respect the exact procedure ; its not the first bios update i make (on EFI was first...      :undecided:)
Froggy Gremlin
  • Master Air OC'er
« Reply #13 on: 24-January-11, 03:10:08 »
its not the first bios update i make .
No. Don't misunderstand, I'm not trying to say you did it wrong, just trying to make sure the ME firmware & update was included in the files that flashed.
IXOYE
BulletTopic starter
  • CORPORAL
« Reply #14 on: 24-January-11, 03:22:25 »
I apologize ,  i have bad days cause of this new "sandy"  config .
Also my gramatical english is not the best , as u may noticed .
Any advice / rec is welcome.
Froggy Gremlin
  • Master Air OC'er
« Reply #15 on: 24-January-11, 04:12:08 »
Jack posted a pdf of the Dual BIOS. Here is the link, look for Reply #5 in this thread; https://forum-en.msi.com/index.php?topic=145084.0 If you have a failsafe in place to revert to a saved BIOS in the backup chip, I really recommend to give 1.8b6 a try. The forum USB flasher utility information & the 1.8b6 + ME can be found in brattak's OC & Mod Section thread. Svet has everything posted & linked in that thread also involving the beta & flashing it.
There is an update to the ME at the Intel Website. It is an Interface Host to Firmware update (Version 7.0.3.1184) & no flashing involved. It is worth a try.
Added: Also the info of the 1.8b6 + ME1164 is in this thread; https://forum-en.msi.com/index.php?topic=145081.0 (Svet Reply #1 & #3).
IXOYE
BulletTopic starter
  • CORPORAL
« Reply #16 on: 24-January-11, 14:01:04 »
Dono what exactly  is fixing this bios 1.8 b6 (Beta) but has solved my problem ftm with freezing . I hope these  updates will be included in  next  bios release .
ps. I wait  to get imports  in my country of I5 2500K  to change this I5 2400 , hoping for no problems .
Ty HU16E  :agrees:  u rock .
Later Edit :  It works around  ~ 2h  and 30 min and then still freeze , however i was able to see a movie from 0 min to + 2 h , its an improvement  :-X
Froggy Gremlin
  • Master Air OC'er
« Reply #17 on: 24-January-11, 16:29:33 »
If running the RAM at default, check in BIOS if DRAM voltage is reading 1.472. If it is, recommend setting it one step above auto which I believe is 1.507V's. If your running XMP or the like, this would call for a different strategy, but I do believe the symptoms are RAM related.
IXOYE
giako
« Reply #18 on: 24-January-11, 17:43:28 »
same error  with the same conf. CPU ram motherboard and psu
try to disable the c-state under oc profile-> processor menu
now my PC run for 7 hour with no freeze
PS sorry fr my bad English
BulletTopic starter
  • CORPORAL
« Reply #19 on: 25-January-11, 00:45:10 »
ty for recomendation , i  will try after work when i comme home.  :biggthumbsup:
BulletTopic starter
  • CORPORAL
« Reply #20 on: 25-January-11, 14:55:40 »
Ty man ,  4h and no freezing . Thx alot .
egohw
  • CORPORAL
« Reply #21 on: 25-January-11, 17:46:30 »
ok
now the question is: if there is a c-state problem or just a non fully compatible ram prob?
sry x bad eng, i m a bad italian  ;-))
Froggy Gremlin
  • Master Air OC'er
« Reply #22 on: 25-January-11, 18:00:01 »
ok now the question is: if there is a c-state problem or just a non fully compatible ram prob?
Yup! That's going to be the 'big' question.
IXOYE
BulletTopic starter
  • CORPORAL
« Reply #23 on: 26-January-11, 01:37:02 »
i search on internet about C-state references  and  its related in our case CPU & MB (bios to be more exactly.... i think) :
http://www.hardwaresecrets.com/article/611
http://software.intel.com/en-us/blogs/2008/03/12/c-states-and-p-states-are-very-different/
Froggy Gremlin
  • Master Air OC'er
« Reply #24 on: 26-January-11, 04:55:15 »
C-State & actually all the available settings are disabled in CPU Features, Pwr Tech., along with Spread Spectrum also being disabled. The board is working so well right now, I don't really want to mess around too much, but enabling one at a time of those Pwr Tech. settings, may reveal something. C-State & Management Engine are all Intel tech. :undecided:
IXOYE
