Author Topic: Dual BIOS Control LED  (Read 31519 times)
kuziuTopic starter
  • SERGEANT
« on: 23-January-11, 15:40:14 »
If the LED blinks every 1 second, it is everything okay? I read the motherboard manual that is led from the BIOS, I saw that in some cases where the LED light does not blink, she was always constant blue light
still blinks every second
Intel Core i7 3770k
MSI Z77 MPower
Corsair H100i
G.Skill 8GB Sniper 2133MHz CL9
OCZ Vertex 4 128GB
Samsung F3 1TB HD103SJ
Creative SB Z
XFX PRO750W Core Edition
  • T9246ED
  • Administrator
Re: Dual BIOS Control LED
« Reply #1 on: 23-January-11, 15:46:21 »
From your manual:
Off: Normal.
Blink (1 cycle/second): The primary BIOS is failed.
Fast Blink (10 cycles/second): The second BIOS is failed.
Solid: Both of primary and second BIOS are failed.
Froggy Gremlin
  • Master Air OC'er
« Reply #2 on: 23-January-11, 17:21:10 »
Did this condition exist right out of the box & on initial startup?
IXOYE
kuziuTopic starter
  • SERGEANT
« Reply #3 on: 23-January-11, 17:21:43 »
that is, the council can not fix it so as not to blink? in my case, what does it mean that blinks every 1 second?
Intel Core i7 3770k
MSI Z77 MPower
Corsair H100i
OCZ Vertex 4 128GB
Creative SB Z
  • T9246ED
  • Administrator
« Reply #4 on: 23-January-11, 17:24:07 »
From your manual:
Off: Normal.
Jack
  • Ex Forum moderator
« Reply #5 on: 23-January-11, 17:26:26 »
Read this (the PDF will tell you how to fix this):
Froggy Gremlin
  • Master Air OC'er
« Reply #6 on: 23-January-11, 17:28:28 »
Wow! Nice to have that backup BIOS feature on this board! :yes:
Added: Thanks much for providing that pdf Jack! :hat tip:
IXOYE
kuziuTopic starter
  • SERGEANT
« Reply #7 on: 23-January-11, 18:35:45 »
Many thanks, everything is in place.
I have a question, I currently have bios 1.8b6 + ME and overclocking the processor did this operation LED Dual BIOS, if these settings are inscribed on the second BIOS?
as I updated the bios to another version, or I would have to perform this operation with Dual BIOS LED? and now as a second bios was updated to 1.8b6, the first and second with the new update will be the same version?
sorry for my english
Intel Core i7 3770k
MSI Z77 MPower
Corsair H100i
OCZ Vertex 4 128GB
Creative SB Z
Muhammad
  • STAFF SERGEANT
« Reply #8 on: 18-April-11, 15:11:55 »
hi everone ,
just got the big bang marshall  - well i have 2600k with it- i wanted to over clock so i swtiched over to xmp profile - i have 4 sticks of muskin 7-9-7-24 rams - but bios reads out the xmp profile wrongly - anyway ..
i saved and rebooted but sytem would just hang at a3  - then after many attemps shuting on and off i clicked on the dual bios button and well it booted - now ever since then the light keeps on blinking which i am assuming is the primiary bios fail - how can i fix this brothers ..
need help please
the bios is lastest ver 1.0 one ..pls help
The Dukes Of Hazzard
Muhammad
  • STAFF SERGEANT
« Reply #9 on: 18-April-11, 15:17:00 »
also i wanted to know what happens if i press the dual bios button - after pressing it i turn on the system  - will i get options to flash etc -- what if i get no options here --
pls help ...
confused
i just want the damn light to stop blinking
Froggy Gremlin
  • Master Air OC'er
« Reply #10 on: 18-April-11, 15:19:14 »
Did you miss Jack's Reply #5 in this thread?
IXOYE
sjay
  • SECOND LIEUTENANT
« Reply #11 on: 18-April-11, 15:24:10 »
pls help ...
confused
Theres the post that was being referred to, read that PDF mo.
In the bios there should be an option to turn the LED off, well there is in mine anyway.
:party:
Froggy Gremlin
  • Master Air OC'er
« Reply #12 on: 18-April-11, 15:27:25 »
A blinking LED in this case means the primary BIOS has failed. Turning off the LED control is a bad idea.
IXOYE
sjay
  • SECOND LIEUTENANT
« Reply #13 on: 18-April-11, 15:29:32 »
I know, but I did also link the PDF. So I helped and also commented, thats all. The LED on my board is on all the time but I don't think its related to the intel boards. Just commenting about my situation with the blue led. I actually like it, I didn't have to buy any LED fans or anything, Free led! Looks nice through the side panel window.
:party:
Muhammad
  • STAFF SERGEANT
« Reply #14 on: 19-April-11, 00:24:42 »
well i select the dual bios boot option as mentioned in the pdf file -- and i save and rebooted - but i did not see any flashing of the bios ..
i mean if the led blinks than it means primary bios fail -- then shouldnt it be re flashed when i follow the pdf -- coz the mobo did not give any message as mentioned in the picture of flashing etc
and how do i know if i am on the dual bios or some thing ---
Froggy Gremlin
  • Master Air OC'er
« Reply #15 on: 19-April-11, 01:39:52 »
It is possible the procedure in the pdf has changed for this new generation of B3 multi BIOS boards. It would be best to open a ticket with MSI Tech Support & ask them if a revised pdf is available for your board. It may have changed for the P67A-GD65(B3) like I have as well. The last time I had a primary BIOS failure, it didn't show a screen of it flashing from the backup to the primary either, but did with the B2 board.
IXOYE
Muhammad
  • STAFF SERGEANT
« Reply #16 on: 19-April-11, 02:11:18 »
well if the primary led lights blinks every 1 sec it means primary bios fail -- hence secondary bios is loaded -- but my question is when i select the bios auto update function to enabled - i dont see any sort of flashing screen as shown above ..could be it does it with out notification or it does not flash it .
anyway when the dual bios button is pressed system boot - but which bios does it load -- from the documentation it shows teriatory bios  --- but i still dont see any flashing screen .
how should i know if the primary bios is recovered -- even though the option for bios update has been selcted
Froggy Gremlin
  • Master Air OC'er
« Reply #17 on: 19-April-11, 02:17:13 »
If you no longer get the flashing LED.
That's the way I read it too.
IXOYE
Muhammad
  • STAFF SERGEANT
« Reply #18 on: 19-April-11, 04:54:23 »
have ti confirm this today - coz i do not see any bios flashing going on --- even though i have enabled the dual boot option -
also i guess i am on the 2nd bios coz last i checked the led was still blinking -
but shouldnt the secondary bios update the primary bios
Muhammad
  • STAFF SERGEANT
« Reply #19 on: 19-April-11, 07:04:19 »
any one else having same issue .,
Froggy Gremlin
  • Master Air OC'er
« Reply #20 on: 19-April-11, 13:37:57 »
Yes, if the BIOS Auto Update is set to 'Enabled'.
IXOYE
Muhammad
  • STAFF SERGEANT
« Reply #21 on: 20-April-11, 02:41:59 »
well if the secondary bios updates the primary bios -- then i think some message should show up saying bios flashing or some thing or it does not show it and does it it self .
even if the auto update bios option is turned on ...there is no message which appears .
also i think it only flashes when both primari and secondary bios are not working -
Bernhard
  • GENERAL
« Reply #22 on: 20-April-11, 03:42:33 »
We cannot change your BIOS or the logic of it here. But do open a ticket with MSI to discuss your idea. >>How to contact MSI.<<
1.B350F Gaming; Ryzen5-1600; Crucial MX300 275GB, Ballistix Sport LT BLS16G4D240FSC 2X8gb; Sapphire RX580 Pulse 8gb; Seasonic750W; Win10-64; LG DVD
2.MSI B450I Gaming Plus AC 7A40vAA;Ryzen5-2400G; Corsair LPX 2X8GB @3200;  Corsair CX500; Crucial 240GB M500Win10-64;
Diverge
« Reply #23 on: 03-June-11, 02:23:08 »
Interesting thread. Would have come in handy for me a few hours ago.
My bios LED was blinking, and instead of researching the correct way to fix it, I flashed bios 2 thinking it would fix bios 1 heh.. now they both have latest bios. I was able to fix bios 1 by just removing cmos battery and using jbat1 clear jumper. Bios 1 got screwed up on me when I was testing boot bios off flash drive function.
Nelly.
  • STAFF SERGEANT
« Reply #24 on: 10-November-11, 14:33:31 »
For the MSI Z68A-GD65 (G3) this is all it says in the Manual, so if primary and secondary have failed is it RMA time, not that it's happend to me, I'm just curious.
i5 2500k@ 4.9 GHz|MSI Z77 MPOWER|G.Skill Trident 8GB 2400C10|MSI GTX 970 4GB Gaming Edition @ 1542/7516 |Corsair HX 750 PSU|Samsung 256GB SSD 830|Creative ZxR|Thermalright Silver Arrow|NEC 24WMGX3 24" TFT|Cooler Master HAF X
Froggy Gremlin
  • Master Air OC'er
« Reply #25 on: 12-November-11, 02:36:59 »
In case your manual doesn't have this information in it, download the more comprehensive pdf manual available from the Global Website for your specific mainboard.
Solid BIOS LED indicates complete failure of both chips. Recovery attempts, & battery removed clearing of CMOS can be tried prior to RMA.
IXOYE
amdscooter
  • SECOND LIEUTENANT
« Reply #26 on: 27-October-13, 18:55:15 »
Heh.. revive a old thread just to say that it saved my bacon. Info on refreshing the primary BIOS on my trusty P67A-GD65 B3 was very useful.  :agrees:
Hardware: CM HAF932 | OCZ ZX 1250W PSU | i7-2600k@4.4Ghz | MSI P67A-GD65 B3 | 16GB (2 x 8GB) Gskill F3-1866C10D-16GAB 1866 | Diamond 7970 1200~1800 | ASUS 25.5" VW266H LCD | 2x 120GB Sandisk Extreme SSD RAID 0 boot | 2x 2TB WD Green RAID 1 | Killer 2100 NIC | X-Fi Titanium Pro | Klipsch 5.1 | G15 KB | MX1100 mouse
Cooling: XSPC Raystorm CPU block | EK 7970 GPU block | Swiftech MCP655 Pump | Swiftech micro reservoir | HW Labs Black Ice GTX 240 Radiator 4 GT AP-15 fans push/pull
