Author Topic: P55 GD85 bios ver 1.4  (Read 5033 times)
fashricTopic starter
« on: 08-February-11, 06:02:52 »
Hi i'm having a problem with my board when changing the frequency of my cpu in the bios. Everytime I change it either up or down and do an f10 in bios it will fail to boot. It will go through the 3 failed boots cycle and then reset the bios settings to default. Now i know this is a feature of the board but it really shouldnt be happening if I put the cpu to  clocks and voltages I know to be safe (even happens if i put the cpu back to default) from a higher setting. Only way I can get it to boot after changing the clock speed is by turning of the psu and leaving it off for 30 seconds and then powering back on and then the new frequency sticks without a problem and the board boots fine. Please understand this is only when changing processor frequency and not when changing voltage. When changing voltage (as long as its enough) the board boots fine. I will give a quick example
Settings at the moment
CPU Ratio 20x
CPU Base Frequency 190MHz
Cpu frequency 3800MHz
Cpu voltage 1.20v
DRAM voltage 1.65v
Now all these settings are tested and I know they are completely stable through various stress tests I have done. Now the problem comes If i were to leave all settings the same but then just change the cpu freq. to 3700MHz by changing the base freq to 185MHz and then saving and rebooting this is when it goes into a loop and the board will reset to default. Like i said i can stop this by turning off the psu before the board goes through the 3 failed boot process and then power on again and it will boot with the freq at 3700MHz. Anybody know why the board is exhibiting this behaviour?
Specs
i5 750
2x2gb gskill ripjaws 1600MHz 7-8-7-21
HD5850
P55-GD85 (bios version 1.4)
claykin
  • SECOND LIEUTENANT
Re: P55 GD85 bios ver 1.4
« Reply #1 on: 08-February-11, 07:12:24 »
What PSU do you have?
I would try different RAM.  Consider JEDEC std RAM such as Crucial.  Search forums for problems with GSkill Ripjaws.  You'll find plenty.
MSI P55-GD85 (no overclock) | i5-750 | Crucial 4x2GB DDR3-1333 CL9 | 2 x WDC 300GB Raptors in RAID1 (Intel PCH) | MSI Radeon 5750 1G PCIe | Plextor PX-880 DVD+/-RW | Liteon iHAS-424 DVD+/-RW (Sony version) | Corsair HX650 PSU | Antec P-183 Case
MagnusB
  • CORPORAL
« Reply #2 on: 08-February-11, 12:04:37 »
Load the new 1.5 BIOS.
« Reply #3 on: 08-February-11, 15:04:12 »
If it was the psu (XFX 650XXX) or ram I dont think the problem would only manifest itself when I change the cpu frequency. You have to remember the only time i ever have this problem is when I change that setting at all other times the system is fine. Thanks for the reply.
@MagnusB
Afaik 1.4 is the latest bios http://eu.msi.com/index.php?func=downloaddetail&type=bios&maincat_no=1&prod_no=1977
Mike
  • aka Frankenputer
  • Virginia, USA
« Reply #4 on: 08-February-11, 15:06:29 »
#2:
MSI Wind U100
« Reply #5 on: 08-February-11, 15:10:58 »
Thanks for that. They really should keep the sites synced. Also it doesn't show up in LiveUpdate 4.
Mike
  • aka Frankenputer
  • Virginia, USA
« Reply #6 on: 08-February-11, 15:49:50 »
DO NOT USE LIVE UPDATE!!!
Use the forum's flasher!  Also, if you flash, use stock settings--remove any overclock of CPU or RAM.
>>Use the MSI HQ Forum USB flasher<<
I'm also moving this to the overclockers and modding section as you are not using stock settings.  Wait and get some more input before flashing.
#2:
MSI Wind U100
« Reply #7 on: 10-February-11, 08:05:31 »
Thankyou the bios update fixed my problem  :biggthumbsup:
Mike
  • aka Frankenputer
  • Virginia, USA
« Reply #8 on: 10-February-11, 11:12:39 »
  :biggthumbsup:
Glad it fixed it.
#2:
MSI Wind U100
