Author Topic: P67A-C43 vt-x  (Read 4720 times)
danstructionTopic starter
P67A-C43 vt-x
« on: 23-June-11, 09:11:06 »
I have a P67A-C43 Board, with an i5 2500K. In the uEFI under overclock, it says virtualization is supported, and there is no option to enable it or disable it. However when I try to use virtualization with VMware, it says it is not enabled, and to change it in BIOS settings. Is there some place to enable vt-x that I am unaware of? How do I get it to work?
I am running uEFI version 1.9
Thanks in advance.
Jack
  • Ex Forum moderator
Re: P67A-C43 vt-x
« Reply #1 on: 23-June-11, 09:38:50 »
https://forum-en.msi.com/index.php?topic=148677.msg1104946#msg1104946
take a look in 'Overclocking' section, 'CPU Feature', & you should see VT.
Re: P67A-C43 vt-x
« Reply #2 on: 23-June-11, 16:58:46 »
I can see it, but I can't enable or disable it. All it says is that vt-x is supported.
Froggy Gremlin
  • Master Air OC'er
Re: P67A-C43 vt-x
« Reply #3 on: 23-June-11, 17:17:33 »
Excerpt from P67A-C43(B3) manual;
I believe with a 'k' series CPU, VT-x is supported, but not VT-d.
IXOYE
