Author Topic: Device driver not found : 'MSCD001'  (Read 3202 times)
Zaxgod
  • Winki
« on: 07-October-11, 16:47:35 »
I've just got my laptop back from RMA and I'm having issues booting it. When I boot I get a message saying:
PXE-E61 : Media test failure, check cable
PXE-M0F : Exiting PXE ROM.
Starting Windows 98...
This driver is provided by Oak Technology, Inc..
OTI-91X ATAPI CD_ROM device driver , Rev D91XV352
Device Name : MSCD001
No Drives found, aborting installation
Device driver not found: MSCD001
No valid CDROM device drivers selected
Press any key top continue...
Doing so produces this:
***** HDD Clean Program V1.1 2001/10/10 *****
HDD Not Ready!!
Pressing enter on that screen says something about having 4 partitions and then:
Image Download OK
Please reboot the system for test
I'm pretty tech savvy but never dabbled in BIOS stuff so I'm pretty lost with all this, there is a disc that was left in the laptop that says JFT00 Diag Image, I assume it's trying to boot from this right? Can anyone help?
  • T9246ED, Бивша комета
  • Administrator
    • MSI BIOS/EC-FW Mods
Re: Device driver not found : 'MSCD001'
« Reply #1 on: 07-October-11, 16:57:18 »
Yes 1st is trying to boot from LAN, then it boots from CD/DVD.
Can anyone help?
go to bios setup and adjust your boot priority properly,
make 1st boot device your HDD
Zaxgod
  • Winki
« Reply #2 on: 07-October-11, 17:30:33 »
Thanks for the quick reply
My boot priorities are
Boot Option #1 Intel Volume0
Boot Option #2 Realtek Boot Agent
Boot Option #3 PO: SlimtypeDVD A DS8A5S
I can't see an option for HDD :S
  • Administrator
« Reply #3 on: 07-October-11, 17:33:38 »
looks like you need to install OS then
Zaxgod
  • Winki
« Reply #4 on: 07-October-11, 17:47:44 »
Ah... That's an issue... I never got an installation disc with my laptop, It came preinstalled. What can I do about that?
  • Administrator
« Reply #5 on: 07-October-11, 17:50:19 »
what notebook you have?
Zaxgod
  • Winki
« Reply #6 on: 07-October-11, 17:52:51 »
GX660R
  • Administrator
« Reply #7 on: 07-October-11, 17:57:33 »
You can try notebook OS recovery:
Zaxgod
  • Winki
« Reply #8 on: 07-October-11, 18:24:14 »
Hmmmm did that and getting the same result :/
Zaxgod
  • Winki
« Reply #9 on: 07-October-11, 19:16:21 »
I'm also getting the following message which looks wrong
Partition    Status    Type       Volume Label    MBytes    System    Usage
1                A       PRIMARY                        14652.0   UNKNOWN   2%
2                         PRIMARY                           100.0   UNKNOWN   1%
3                         PRIMARY                      563469.0   NTFS/HPFS  59%
4                         PRIMARY                      375652.0   NTFS/HPFS   39%
Zaxgod
  • Winki
« Reply #10 on: 11-October-11, 13:53:17 »
Did the recovery a second time and it seemed to fix it this time!
Thanks for the help Svet :)
  • Administrator
« Reply #11 on: 11-October-11, 14:53:41 »
well done :)
