Author Topic: MSI H67MA-E45 (MS-7678) FREEZES WITH 8GB AND WORKS WELL WITH 4GB OF MEMORY.  (Read 2567 times)
RixardiTopic starter
My computer freezes when using 8GB (4X KINGSTON KVR1333D3N9). The system has no default behavior.
It freezes well in windows startup, and after the system is working.
When the system is using 4GB (2X KINGSTON KVR1333D3N9), never freezes.
I permute the memories of all possible ways, and always confirmed this behavior.
Is there any solution to this problem?
MOTHERBORD: MSI H67MA-E45 (MS-7678)
PROCESSADOR: Intel Core i5-2500, 3400 MHz (34 x 100)
MEMORY: KINGSTON KVR1333D3N9
OS : WINDOWS 7 64
Bernhard
  • GENERAL
« Reply #1 on: 10-October-11, 17:34:38 »
Have you tried both kits independently to determine that both are working ? Have you tested the memory modules individually with memtest86 ?
If so, and all is OK,  you will probably need to increase your DRAM voltage to compensate for the additional load. Increase your DRAM voltage to ~1,575 and restest.
If that does not do it on its own, then you can try increasing your CPU I/O voltage one or two steps at a time until you get stability. Stay below 1,2V.
What PSU and GPU are you using?
What is your current BIOS version ? There have been numerous BIOS revisions with improved memory compatibility comments. If you do intend to flash your BIOS, use the forum flasher. It's failsafe. >>Use the MSI HQ Forum USB flasher<<
1.B350F Gaming; R5-1600; Crucial MX300 275GB, Ballistix Sport LT BLS16G4D240FSC 2X8gb; Sapphire RX580 Pulse 8gb; Seasonic750W; Win10-64; LG DVD
2.Z97 Extreme 4;i74790;Corsair 2X8Gb CMY16GX3M2B2133C11; CX430; Crucial CT240M500; Win7-64; ST1TB Data;WD300V-R Backup OS;SonyDVD;
"veni vedi doctus"
MSI 미친
