Author Topic: Using Spinrite on a MSI P55-GD65 with a WD 2TB Green?  (Read 2951 times)
Xplorer4x4Topic starter
  • SECOND LIEUTENANT
I was going to run Spinrite in hopes of fixing my WD 2TB Caviar Green HDD that has had sectors reallocated. So, I booted up Spinrite but it said to make sure my BIOS was compatible or safe. I was just hopping to get some assurance on this. I wouldn't think there is any reason I can not use this as the BIOS sees the drive just fine, but better safe then sorry.
OS: Kubuntu 12.10/Windows 8 Pro x64
CPU: Intel Core i7 2600K
Motherboard: MSI P67A-G45
Memory: 2x4GB Crosair Dominator
Graphics Card: Saphire 4890 Vapor-X
Monitor: Dell 2208WFP
Mouse: Mionix NAOS 5000
PSU: Corsair 520HX
Case: Thermaltake Mozart TX
Cooling: Thermalright TRUE Black Ultra-120 eXtreme CPU Heatsink Rev C
Hard Drives: 1x180 GB Intel 330 SSD - 1xWD 1 TB Caviar Black - 1xWD 2 TB Caviar Green - 1xWD 3 TB Caviar Green
NovJoe
« Reply #1 on: 17-November-11, 03:34:06 »
As long as you did not flash to any third party bios or "unofficial" bios from elsewhere, the current bios should be fine. I have used sprinrite on my system before and have a lot of low level format to write drives to '0's without problems so far.
MSI HQ Forum USB flasher
  • SECOND LIEUTENANT
« Reply #2 on: 17-November-11, 19:49:55 »
MBR followed by EFI
Thats the error. i tried to just ignore it but spinrite refuses and just complains about bios. keep in mind this is a 2TB drive. my sig seems out of date now.
PSU: Corsair 520HX
NovJoe
« Reply #3 on: 18-November-11, 03:21:12 »
Then this should be Spinrite problem. So far, those which I have used spinrite with are drives <500GB.
