Author Topic: Wifi doesn't work in Windows 7 but does in Ubuntu  (Read 1408 times)
GregTr11
  • Winki
« on: 27-November-11, 17:11:13 »
(I did make a thread about this a long time ago but it is too old to reply to)
When I added more RAM into my MSI-Wind U130, the WiFi no longer works in Windows 7.  It doesn't pick up any networks and tells me that the adapter is disconnect or something like that.  I also installed Ubuntu on my Wind and it picks up wireless networks and connects to them without any problem.  I assume this is an issue with the Netbook more than it is an issue with Windows 7.  Does anyone know why it isn't working?
Mike
  • aka Frankenputer
  • Power Edition
  • Virginia, USA
Re: Wifi doesn't work in Windows 7 but does in Ubuntu
« Reply #1 on: 27-November-11, 17:13:25 »
No, if it works with Ubuntu, you have eliminated any hardware issue.  It must be W7.
#2:
MSI Wind U100
ufosnowcat
  • Neo
« Reply #2 on: 28-November-11, 21:05:17 »
possible diver issue: remove reinstall
possible "hardware" switch issue
try booting ubuntu turn switch off
turn laptop off
boot win 7
turn switch on
had that issue (in reverse) on a hp laptop
catilley1092
  • Neo
« Reply #3 on: 01-December-11, 23:07:23 »
When I recently swapped my RAM, my wireless reset itself to the default "off" position. You should have a hotkey, mine is F8, I had to press Fn & F8 together to turn on wireless networking.
Hopefully, this will work for you, too. Apparently changing RAM reverts MSI notebooks back to default settings. Try it out & see.
Best of Luck,
Cat
"Making marijuana legal would not only save our scarce prison beds for those who deserves them the most, but also reduce our massive debt in a responsible manner."
