Author Topic: MSI P67A-GD65 JCOM1 header question  (Read 2085 times)
DarkkfearTopic starter
« on: 13-December-11, 21:37:05 »
Hello all, Recently my powersupply had died on me, I replaced it with exactly the same one, only now my Power&reset buttons no-longer work. Headers have been left alone, my power and activity LED lights are still on but the power switch itself no longer works. Is it possible that these pins may have gotten damaged or fried from my fault PSU? I'd like to be able to close my case up and not have to re-open it when I want to turn on my pc!
Henry
« Reply #1 on: 14-December-11, 00:02:41 »
 What does JCOM1 (Serial port) header have to do with PSU & power/re-set switches? Is that what you have the front panel switches plugged into? If so then plug them them into JFP1 & JFP2 which is where FP switches, LED's and case speaker plug into.
« Reply #2 on: 14-December-11, 20:23:24 »
Haha.. geez, I don't know. Thats where I had it previously and it was fine. Sorry for the noobness!
