Author Topic: Monitor Screen gets no Signal AFTER cmos reset  (Read 1366 times)
Alvinlow92
  • Neo
« on: 13-February-12, 00:33:37 »
Hi there, im using Msi NEO2 p35 FR, i know its really kinda old mother board.. i didnt did the jumper, but instead. i removed the battery , and for my case, i have a RESET cmos button on my motherboard. so i hold it for like 5seconds reset it and poof. doesnt get any signal on my monitor screen. any suggestions?
i read on the other threads but cant find similar topic , im sorry for any inconvience causes
Oh btw i read on this forum that says "Unfortunately when you took the CMOS Battery out you reset the CMOS to defaults which is going to reset the Video to IGP. and with the IGP Bad, you are kind of stuck." is it true that im stuck ? :( there should be a way out right?
Wonkanoby
  • Lightning
Re: Monitor Screen gets no Signal AFTER cmos reset
« Reply #1 on: 13-February-12, 00:41:09 »
that board has no onboard vga
and if it had and you had a vga card in it would still boot of that
remove all bar dimm nearest cpu
list full hardware
P5Q Deluxe
Intel QX 6700
4GB OCZ
60 GB Vertex drive
ATI 5850
Alvinlow92
  • Neo
« Reply #2 on: 13-February-12, 00:54:43 »
thanks for the great info, i reseated my rams and stuffs . and start getting signal already, all i need is bios setting now. this website is awesome. fast and good respond.
Fredrik
  • Hawk
  • There's always a risk.
« Reply #3 on: 13-February-12, 01:45:41 »
Have a look at Wonkanoby's complete list of suggestions, please. I would add having a look at the dust situation, and consider a new CMOS battery.
Ex Forum Mod
  • Hawk
« Reply #4 on: 14-February-12, 02:42:32 »
 If you have any more questions/problems please read >> Posting Guide <<
 See my signature below for an example of information to provide.
