Author Topic: MSI HDD Backup Utility  (Read 9053 times)
iopanTopic starter
« on: 18-March-12, 23:50:58 »
Hello there!
i ve got the same issue... so i would be interested if there is any solution???!?!??!!!
one day ago my ssd shutted down, after alot of rescue tries i managed to get the hdd backup tool by msi running and the ssd mounted (ahci mode), but after about a minute the ssd shutted itself in some kind of "playing dead mode" so i unplugged it and connected it again after one minute same procedure as before ..... at least i managed it to make backup this way  (unplugging and reconnecting the ssd for about 60 times) ...
so status quo is that the ssd is working again ( after firmware update and a total swipe) but i cant manage to get the backup placed on it .. it always ends as an erased unformatted drive ( after a few seconds)...#
so any help ideas suggestions??  would be very appreciated
ps:  i want to restore my boot and systemdrive
adios io
Henry
« Reply #1 on: 19-March-12, 00:36:23 »
 Topic split. In the future please start your own new topic instead of hijacking and resurrecting an old dead topic.
iopanTopic starter
« Reply #2 on: 19-March-12, 10:43:45 »
Hi Henry, ok !
no problem at all, but ( i thought as it is the same proble why not reply to it ;), seems quiet logicl for me) back to my question... do you have any idea what i can do to acces the backup image files and bring them back on my ssd?
maybe another program which can acces the files and copy them on the hd?
thx in advance ! iopan
NovJoe
« Reply #3 on: 19-March-12, 14:26:01 »
Where are your backup image files? In the same SSD?
Is the SSD now the boot drive or secondary drive?
MSI HQ Forum USB flasher
iopanTopic starter
« Reply #4 on: 19-March-12, 17:25:37 »
Hi nOVJOE! (unfortunatly henry splitted the post from the original topic, so now maybe its hard to get the point)
no they ar on another HDD (about 27x600mb images) and i also copied them on an external hdd ( just to be sure), i can acces them but always when i start the backup utility via msi winky the process takes about 3 seconds to abort into an error log and the ssd
 ( which is the target drive for recreating the backup drive)              ends erased in an unformatted status.
actually at the momen there is no boot drive  (i guess) but i would like to restore the ssd into the prior bootdrive.
greetz io
NovJoe
« Reply #5 on: 20-March-12, 15:11:27 »
The images which you are talking about are the recovery image files?
iopanTopic starter
« Reply #6 on: 20-March-12, 19:32:54 »
Yes . exactly.
yesterday i tried to restore them on an external hdd... and guess what... it did the job... then i deleted the hdd and wnated to redo the trick and ... guess what ...
i  haven t managed to get work again... now  iam really confused... i am always getting an error again.... so i think the image files are ok... but somehow they seem to copy just in 1 of hundred times... now i am working on this problem sinc saturday afternoon.. all my spartime is floating into this issue... ( sure meanhile  i would have re/ installed configured windows maybe 5 times.... but somehow i would like to solve this problem....)
adios
iopanTopic starter
« Reply #7 on: 20-March-12, 20:50:14 »
hi there !
i ve got one more question! i guess my old windows on ssd installation was in (shame oon me) ide mode, and now a tried just for fun, glory an dresearch, to restore an old windows backup image on the ssd (teh restore process was done in ahci mode) and now i just can boot windows in ide mode ?!?!??!! ( maybe because of the old backup?!??!!) as soon as i switch in bios to ahci i get a millisec. bluescreen in booting process ( when the points of the windows bootuplogo move towards) and the system reboots?!?!?! strange isn´t it? any suggestions whats going wrong here? is the ssd now :censored: up? are my bios settings wrong or what?
i´m totally clueless by now
greetz io
NovJoe
« Reply #8 on: 21-March-12, 13:40:44 »
I see. You have the installation done in IDE mode thus AHCI mode will not allow you to boot into Windows.
iopanTopic starter
« Reply #9 on: 21-March-12, 18:15:25 »
yep ... but i figured out how to theoreticly solve tis problem!
SO NOW IMPORTANT hopefully FINAL QUESTION:  i´ve got the backupfiles from msi hdd backup and i would like to know:
A) how can i check if the files are ok (somekind of discrepair prog. maybe?)
and
B) do you guys know any software which can acces this files except the hdd backup tool itself ( maybe some software i can run in windows or linux)
if you have some answers to these points i would be really glad!
greetz IO
NovJoe
« Reply #10 on: 26-March-12, 07:52:41 »
and
greetz IO
For the above, it is better to log a ticket with MSI Tech support for info.
