Author Topic: Led error codes z77a-gd65  (Read 3985 times)
HarrowTopic starter
« on: 28-April-12, 23:16:49 »
hey guys
just got my z77a-gd65 and whenever i turn it on i have it flash a bunch of numbers on the led indicator at the bottom of the board, after a few seconds it ends up on dE and nothing happens
also the motherboard will not connnect ot the monitor, i have the DVI cable plugged in to my GPU (have also tried HDMI)
system specs are:
MSI Z77a-gd65 motherboard
Intel i5-2550k cpu (no igp so i have the hdmi/dvi cable plugged into gpu)
Saphire radeon 7950 11196-00-40G GPU
Asus Dvd burner DRW-24B1st
Seagate Barracuda 500gb 7200rpm hdd
Crucial M4 64GB SSD
2x4gb Mushkin enchanced blackline Memory (have tried 1 stick/2sticks in the different slots, 1+3, 1, 2, 2+4)
Rosewill Hive 650W PSU
Rosewill Blackhawk case
ASUS VH236H Black 23" 2ms Full HD Widescreen LCD Monitor
Havent even installed W7 yet, cant get a connection to the monitor anyway
all fans spin when i start it up
PSU is installed in case already but all others are not
thanks in advance for the help :)
Noway77
  • SECOND LIEUTENANT
« Reply #1 on: 28-April-12, 23:32:37 »
Hi
Did you already try to clear cmos, and an usual fix is also change to gpu to another slot, in your case the middle one.
HarrowTopic starter
« Reply #2 on: 29-April-12, 00:42:42 »
Hi
just tried that didnt work :(
Froggy Gremlin
  • Master Air OC'er
« Reply #3 on: 29-April-12, 07:44:21 »
Recommend to test with a quality PSU such as a Corsair, Thermaltake, or PC & Power Cooling +12V single rail.
Here is a link to codes;
http://www.ami.com/support/doc/AMI_Aptio_4.x_Status_Codes_PUB.pdf
IXOYE
