Author Topic: X79A-GD45 (8D)  (Read 3905 times)
mateotizikaTopic starter
  • CORPORAL
X79A-GD45 (8D)
« on: 07-May-12, 17:55:39 »
Hello please help me out, when i disable EIST i get 3600MHZ stable.
But i loose a setting that boost my cpu at 3800MHZ.
How i can fix this?? I don't want Eco settings etc but i need that boost. X-((
Enchanced Turbo is also Enabled if that matters.
Thanks.
Froggy Gremlin
  • Master Air OC'er
« Reply #1 on: 07-May-12, 21:32:11 »
Might try increasing the power limit settings.
IXOYE
  • CORPORAL
« Reply #2 on: 07-May-12, 21:47:37 »
you can become more specific please am newbie i don't wanna mess with wrong things. :confused2:
Froggy Gremlin
  • Master Air OC'er
« Reply #3 on: 07-May-12, 21:56:19 »
Have a look in UEFI/BIOS OC Section, sub menu CPU Features, what are all the settings in there set to? Any settings show '0'? Try setting all the power limits to 200-250.
IXOYE
  • CORPORAL
« Reply #4 on: 07-May-12, 22:05:16 »
The only field got number is Cpu Override Voltage 0 (min.0 max 255).
Froggy Gremlin
  • Master Air OC'er
« Reply #5 on: 07-May-12, 22:30:32 »
When EIST is enabled, the other settings will show up in the sub menu. Disable EuP 2013 (in the Eco Section), disable Overspeed Protection, set Package C-State to No Limit.
IXOYE
  • CORPORAL
« Reply #6 on: 07-May-12, 22:50:45 »
Thanks u try to help me but with your settings nothing change. When i set off EIST also Intel Turbo Boost is set disabled.
Any other way??
Froggy Gremlin
  • Master Air OC'er
« Reply #7 on: 07-May-12, 23:04:40 »
Right, EIST needs to be enabled for Turbo to work. You can experiment with the Phase Control settings. Try disabled, SVID or APS. CPU V. on Auto?
IXOYE
  • CORPORAL
« Reply #8 on: 07-May-12, 23:19:23 »
Yes i think CPU V. is Auto i can't find SVID neither APS am sorry.
I get more settings preview if i log in bios instead of running Clickbios?.
Froggy Gremlin
  • Master Air OC'er
« Reply #9 on: 07-May-12, 23:28:22 »
I like to do all any changes and related things in the actual UEFI/BIOS itself, not in a Windows environment. Not all mainboards have it named the same or offer the exact choices I had mentioned, but you will find the Phase Control items in the Eco Section of the UEFI/BIOS.
IXOYE
  • CORPORAL
« Reply #10 on: 07-May-12, 23:47:53 »
Well on Eco Section all things are auto.
Eup 2013 (Disabled)
CPU Phase Control (auto)
CPU I/O Phase Control (auto)
DDR CH_A/B Phase Control (auto)
DDR CH_C/D Phase Control (auto)
C1E Support (disabled)
Intel C-State (enabled)
Package C State limit (no limit)
Enhanched Turbo (enable)
  • CORPORAL
« Reply #11 on: 08-May-12, 23:01:24 »
Hello i managed to do some changes but nothing gonna change. This motherboard sets Intel turbo boost2 off when u have disabled Eist.
I wonder if this is happening with the x79A gd65 for example or with a non Msi board  :grin:
Froggy Gremlin
  • Master Air OC'er
« Reply #12 on: 09-May-12, 00:54:34 »
To the best of my knowledge, once EIST is disabled, Turbo is gone regardless of the mainboard make or model.
IXOYE
  • CORPORAL
« Reply #13 on: 09-May-12, 18:55:20 »
Then i must use EIST but this can harm my computer over the time?. Because i think the cpu don't get stable voltages with EIST on or not?
When i listen music and i open Clickonbios or controlcenter the sound freezes for 1-2sec is this normal also ?
Froggy Gremlin
  • Master Air OC'er
« Reply #14 on: 09-May-12, 21:46:59 »
EIST enabled will not harm your pc. You could remove ClickBIOS and test, if no sound freeze, then the application that causes it has been found. If still have the freeze, reinstall ClickBIOS and remove CC and test again. Process of elimination.
IXOYE
  • CORPORAL
« Reply #15 on: 12-May-12, 01:17:43 »
I completed process of elimination when installed only control center there is a improvement but with installed click on bios the freeze still there is.
