Author Topic: Z77A-G45 PC Beep  (Read 5272 times)
Z77AG45Topic starter
Z77A-G45 PC Beep
« on: 01-June-12, 11:41:27 »
Hello everyone. I have a Z77A-G45 motherboard. I've updated UEFI/BIOS to the latest version and everything works except PC Beep (PC speaker). Can someone help?
masterten
  • SERGEANT
« Reply #1 on: 01-June-12, 15:59:58 »
Latest = 2.4?
I have 2.3 now, but i didn't noticed if it beeps or not :-)) I'll check when i get home.
i5-3550
Z77A-G45
2x4GB (KHX1600C9D3P1K2/8G)
GeForce GTS 450 (GV-N450OC2-1GI)
WD 1TB Green
Corsair GS600 PSU
marcoslei09
  • STAFF SERGEANT
« Reply #2 on: 01-June-12, 18:08:09 »
I never notice but I think mine only beeped on UEFI/BIOS 2.1, I have 2.4 now and no sound.
MSI Z77A-GD65
Intel Core i5 2500k@stock w/ Corsair H70
MSI GeForce GTX760 2GB GDDR5 OC
GeIL Evo Corsa DDR3 8GB (2x4GB) 1866MHZ CL9-10-9-28
Be Quiet! Dark Power Pro P9 850W 80PLUS Gold
Corsair Force Series 3 120GB SATA3
Asus Xonar DGX 5.1
Windows 8.1 Pro 64bits
« Reply #3 on: 02-June-12, 14:02:43 »
My BIOS version is 2.4 (05/09/2012). Can MSI do something about it?
  • T9246ED, Бивша комета
  • Administrator
« Reply #4 on: 02-June-12, 14:49:13 »
beep how and where?
is it permanently or just when booting?
also read >>Posting Guide<<
« Reply #5 on: 02-June-12, 15:17:46 »
One short beep from "PC speaker" while computer starts is missing. PC speaker doesn't work in Windows either. I've checked.
Stu
  • Birmingham, UK
    • StuOnline.co.uk
« Reply #6 on: 02-June-12, 16:25:56 »
Is the speaker connected to the correct pin header? Tried another speaker?
« Reply #7 on: 02-June-12, 17:52:52 »
It is connected correctly. I tried another speaker and still no luck.
Froggy Gremlin
  • Master Air OC'er
« Reply #8 on: 02-June-12, 19:46:21 »
In the past, some like the beeps, some hated the beeps, some BIOS revisions have the beeps and others don't. Most of the time anymore, I just rely on strictly visuals like the DeBug LED, codes at POST, etc. Maybe someone at MSI Technical can explain the changes between revisions. If they are contacted, please post their response. :-))
>> How To Contact MSI <<
IXOYE
Henry
« Reply #9 on: 02-June-12, 20:32:19 »
 "I never notice but I think mine only beeped on UEFI/BIOS 2.1, I have 2.4 now and no sound."
 Same with my P67, when I had BIOS 1.9 it beeped, with 1.C no beeps. I don't worry about it, I don't need beeps to figure out if or what problems are if any crop up.
marcoslei09
  • STAFF SERGEANT
« Reply #10 on: 02-June-12, 21:23:58 »
Me nether. The computer works fine without it.
MSI Z77A-GD65
Asus Xonar DGX 5.1
turbo111
« Reply #11 on: 05-June-12, 07:50:47 »
I have the same problem with my Z77A-G45; motherboard speaker (accessory) has never worked. I have tried 2 different speakers with the same results. I also re-wired one of the speakers to use the 2 center pins to see if it would work as a "buzzer" - no luck.
Reported problem to MSI Tech Support on 5/24 and their reply was "if the speaker headers on the mb does not work then this indicates problem with the header when your wiring and speaker confirmed in working order".
My concern is that if this is not a BIOS issue or a minor design flaw, it could be an indicator of a more serious problem. And if you simply rely on "visuals", just wait until you power up and have no video.
Intel i7 3770K : MSI Z77A-G45 UEFI BIOS v2.4 : Kingston KHX1600C9D3K2_8G (x2 = 16GB total ram) : Corsair SATA #CSSD-F120GBGT-BK : Raidmax RX-530SS 530W PSU : EVGA GeForce 8800GS (384MB PCI-E) : ASUS 12x BW-12B1ST Blu-Ray Writer : Win 7 HP SP1 x64 : Nothing Overclocked (DRAM Freq adj  to 1600MHz)
Froggy Gremlin
  • Master Air OC'er
« Reply #12 on: 05-June-12, 08:17:50 »
It's been reported that UEFI/BIOS v2.1 had a beep. To confirm if the header is in fact operational, you might try v2.1 for testing purposes.
Added: Usually, to get some for sure beeps on most boards, attempting a startup with no RAM installed might do it. The only possible problem with the v2.1 test in your situation, is the 3770k CPU was not fully supported until UEFI/BIOS v2.3.
A beep is needed to be able to tell the graphics isn't working? :think:
« Last Edit: 05-June-12, 15:30:46 by Ex Forum User 2 »
IXOYE
turbo111
« Reply #13 on: 05-June-12, 10:17:35 »
HU16E,
Wasn't really aiming that comment at you; my point was that a series of beeps could help troubleshoot a no video problem.
And I like your other suggestions. I'll pass on v2.1 since my system might have been shipped with that and I installed the speaker during the build. I might try pulling memory next time I power off. I did notify MSI Support about this thread and they seem to be very good.
Aside from this the only other glitch I have is I can't find how to toggle Bios Protection in v2.4.  Support says
advanced bios feature should contain the bios protection setting
, but I sure can't find it! I know I had to change it to do my first flash.
Will update this thread when support replies.
jerrywall
  • STAFF SERGEANT
« Reply #14 on: 09-July-12, 00:11:58 »
I too noticed that the short beep went away as I flashed the 2.4 bios. If it's just the ok-beep that's gone it's in order but since no documentation on the subject seems to exist it could just as well be that the beep codes doesn't work at all. No word on the subject?
MB: MSI Z77A-S01
CPU: i7 3770K, COOLER: Noctua C12P SE14
VGA: Asus HD7950 DCU2 3 GB, COOLER: Arctic Accelero Xtreme 7970
PSU: Corsair TX750 V2
HDD1: Samsung SSD 840 Pro 256 Gb
HDD2: WDC 2 TB WD20EARS
MEM: Corsair Vegeance LP 16 GB (CML16GX3M2A1600C10R) 8 GB X 2
OS: Windows 7 Home Premium 64
Patone
  • SERGEANT
« Reply #15 on: 17-June-13, 16:18:33 »
Same problem here. Doesn't beep and the speaker is working with other boards. Bios Version 2.A
« Last Edit: 17-June-13, 23:22:34 by Patone »
  • 微星科技
« Reply #16 on: 17-June-13, 18:23:30 »
Don't resurrect or hijacl old topics. >>Please read and comply with the Forum Rules.<<
For your own issue open an own topic if you have any (Just no beeping when board works fine is no issue).
-- TOPIC LOCKED --
MSI Radeon RX Vega 64 WAVE 8G
Seasonic G-750 • +12V: 62A • +3.3V: 20A • +5V: 20A
Windows 10 Pro
Cooler Master Masterbox 5 MSI Gaming Edition
