Author Topic: Z77A GD 65- Control Center + Click BiosII updates now not working.  (Read 3866 times)
nine4vTopic starter
  • CORPORAL
Hi, I have the Z77A GD 65 mainboard. Just switched on and there was an update for Live 5 so I installed that, I was then prompted to update Control Center and Click BiosII so I did so. When I try to run Click BiosII I get an error msg telling me that it as been removed and I cant run Control Center has it dosent seem to be present on my pc at all.
nine4vTopic starter
  • CORPORAL
« Reply #1 on: 03-July-12, 10:03:33 »
Ive re scanned with Live Update 5 and it's telling me that I don't have Control Center installed and that Click Bios II needs up dating, so Ive re downloaded and still the same prob. Ive tried to remove Click Bios via the control panel and I get a msg telling me that the setup files are corrupted. As for Control Center it still dosen't seem to be installed.
Froggy Gremlin
  • Master Air OC'er
« Reply #2 on: 03-July-12, 10:08:38 »
Not many here at the forum are very keen on using any of those utilities. Especially Live Update. Recommend to do all driver downloads, UEFI/BIOS updates and such manually. UEFI/BIOS updates using the forum's USB flash method.
If you want them, here is the link to download and install drivers and utilities manually.
>> Z77A-GD65 Link <<
Added: Programs and Features in Control Panel should show what is installed.
>> Forum Flash Method <<
IXOYE
nine4vTopic starter
  • CORPORAL
« Reply #3 on: 03-July-12, 10:12:21 »
Ok, so Ive downloaded both Control Center and Click Bios II from the Z77A-GD65 ( msi website) link above and the same thing is happening. They have both installed but neither of them will run.
nine4vTopic starter
  • CORPORAL
« Reply #4 on: 03-July-12, 10:35:58 »
Ive updated to Control Center 2.2.091 and Click Bios II 1.0.072 and neither of them work, just getting runtime error message.
nine4vTopic starter
  • CORPORAL
« Reply #5 on: 03-July-12, 12:18:11 »
Ok Ive googled Ive uninstalled and reinstalled and still the same neither utility works now.
nine4vTopic starter
  • CORPORAL
« Reply #6 on: 03-July-12, 13:13:33 »
Just updated these two utilities and now neither of them will work.
Bernhard
  • GENERAL
« Reply #7 on: 03-July-12, 13:15:26 »
Time to roll back to your prvious versions from the installation disc and inform MSI technical of your findings. >>How to contact MSI.<<
1.B350F Gaming; R5-1600; Crucial MX300 275GB, Ballistix Sport LT BLS16G4D240FSC 2X8gb; Sapphire RX580 Pulse 8gb; Seasonic750W; Win10-64; LG DVD
2.FUJITSU LIFEBOOK S751 QM67;i5-2520M;2 X 4GB 1333Crucial CT256 MX100; Win10-64; Orico Dual Bay USB3 Dock
"veni vedi doctus"
MSI 미친
nine4vTopic starter
  • CORPORAL
« Reply #8 on: 03-July-12, 13:21:00 »
Cheers. Already contacted MSI Support, awaiting reply.
Henry
« Reply #9 on: 03-July-12, 22:43:07 »
 Topics merged as they were essentially the same topic but double posted.
nine4vTopic starter
  • CORPORAL
« Reply #10 on: 25-July-12, 12:37:46 »
Still cant get it to work. It just stays on the splash screen and nothing seems to want to load. I am thinking that my orig bios update was no good, should I try the second bios?
xmad
  • Salisbury MD
« Reply #11 on: 25-July-12, 12:48:25 »
Switch to your back up bios and see if all is well. If it is, uninstall live update and check the website periodically for updates.
If a bios update is nessesary: >>Use the MSI HQ Forum USB flasher<<
You may also switch to the other bios once the flash tool has loaded to re-flash the corrupted bios. In other words, boot using good bios into flash tool, when the screen comes up asking for input, reach in and switch to the bad bios. Proceed with flash.
Not a bad idea to run memtest first which is on the tool.
Mainboard: X79A-GD65 (8D)
CPU: I7-3930K
Setting: 2400 CL:10
SSD: Corsair GS 256GB
Corsair Link
Cooling: Corsair H100I
nine4vTopic starter
  • CORPORAL
« Reply #12 on: 25-July-12, 13:33:21 »
Clicked the bios switch and when I boot I just get a blank screen.
The bottom line is, my bios is the latest version but Click Bios II will not load, I am at a loss as what to do.
xmad
  • Salisbury MD
« Reply #13 on: 25-July-12, 15:14:32 »
Perhaps I am not understanding the result when you try to boot. The computer loads to windows but you can't enter Bios? -try unplugging any extra usb and see if it improves
It could be the bios version that is the problem or an improper flash.
CPU: I7-3930K
Setting: 2400 CL:10
Corsair Link
neoroy
  • FIRST LIEUTENANT
« Reply #14 on: 30-July-12, 05:23:01 »
Tips : Use Revo Uninstaller to uninstall softwares completed that usually hard to uninstall (corrupted sofware) with windows uninstaller tool.
I have used this board with BIOS V10.3 or latest V10.5 and no problem with control center latest version and live update although I didnt use live update to flash BIOS, just want to see if it works and check my drivers. I always trust to MSI HQ USB FD flashing tool when comes to flashing BIOS :)
Btw did you install first "Intel Management Engine Driver"? (Intel7s ime mobo) It needs to be installed to have control center up & running.
Intel Xeon E5-2623 V3 @3.3GHz
MSI X99A SLI Krait Edition
Inno3D GTX980Ti Black Hybrid
Gskill Ripjaws V 4x4G 2400MHz DDR4
Seagate HDD 1TB 7200rpm SATA3
DELL U2713HMT
CoolerMaster SilentPro M2 1000W Silver
Cooler Master Hyper 212X Turbo
Thermaltake Poseidon Z
Razer Death Adder Blue 3.5G + Goliathus Extended
SAMSUNG Bluray Combo SH-B123L
Windows 10 Pro 64bit
