Author Topic: MSI H61M-P31 Wake on LAN  (Read 3141 times)
MagicBoyTopic starter
« on: 09-August-12, 20:58:10 »
Any idea's how to get WOL working on this board?
As soon as it goes to sleep or shuts down (S5) the NIC is dropping the connection and doesn't respond to the magic packet.
Tried various BIOS settings including disabling EUP2013, enabling Wake on PCI/PCIE, both BIOS and OS control for the power management. Also tried the latest MSI and the latest Realtek drivers on Win 7 64-bit.
xmad
  • Salisbury MD
« Reply #1 on: 09-August-12, 21:01:46 »
Right click on the device in device manager> power management (settings are there)
Mainboard: X79A-GD65 (8D)
CPU: I7-3930K
Setting: 2400 CL:10
SSD: Corsair GS 256GB
Corsair Link
Cooling: Corsair H100I
  • 微星科技
« Reply #2 on: 09-August-12, 21:11:35 »
Make sure "Wake on Magic Packet" is activated in your lan adapters' properties (windows)
MSI Radeon RX Vega 64 WAVE 8G
Seasonic G-750 • +12V: 62A • +3.3V: 20A • +5V: 20A
Windows 10 Pro
Cooler Master Masterbox 5 MSI Gaming Edition
« Reply #3 on: 09-August-12, 23:28:20 »
I'll double check.
Thanks.
catfinch
« Reply #4 on: 21-February-13, 10:10:39 »
I'm also having problems getting the NIC on this board to remain active when shutdown.
I've enabled "Allow this device to wake the computer" in the BIOS.
Tried enabling and disabling the Advanced setting 'Shutdown Wake-On-Lan'
Updated the BIOS to the latest version (2.7) as it mentioned updated NIC drivers, no change.
Has anyone managed to get WOL working with this MSI mainboard - H61M-P31???
Cheers
The CPU Whisperer
  • I must be menthol
  • FIRST LIEUTENANT
  • Burn baby burn
« Reply #5 on: 21-February-13, 10:56:52 »
Look here: https://forum-en.msi.com/faq/article/wake-on-lan
If unsuccessful, start a new thread instead of resurrection an old one:
>>Please read and comply with the Forum Rules.<<
catfinch
« Reply #6 on: 21-February-13, 11:29:34 »
Thanks for that link, explains exactly how i'd expect to have to enable WOL with this board. Unfortunately it still didn't work. I officially give up!
Thanks again
