Author Topic: 990FXA-GD65 AMD raid driver  (Read 1613 times)
XaphanTopic starter
« on: 26-October-12, 16:16:40 »
Hi I'm considering upgrading to windows 8 from windows 7,  my concern is that I will loose my raid in the process, I'm currently running two 60gb Ocz Agility 3 raid 0 on  with raid driver version 3.3.1540.22
does anyone know if it is compatible with windows 8 or will I have to wait for the peeps at MSI to write one?
any info is much appreciated
also sorry if I've posted this in the wrong place
Thanks
Xaphan
xmad
  • Salisbury MD
« Reply #1 on: 26-October-12, 16:19:15 »
I THINK win 8 has the drivers already. Perhaps you can download the trial if it won't detect the raid array cancel the install.
Mainboard: X79A-GD65 (8D)
CPU: I7-3930K
Setting: 2400 CL:10
SSD: Corsair GS 256GB
Corsair Link
Cooling: Corsair H100I
XaphanTopic starter
« Reply #2 on: 26-October-12, 17:15:37 »
OK well I think I will just bite the bullet and try, thanks for the reply
Panther57
  • CAPTAIN
« Reply #3 on: 27-October-12, 18:03:55 »
With the same board I tried the Win8 Beta on my Raid. I reformatted back to Win7 64bit Professional, with no problems.
MSI: 990FXA-GD80 v13.4
AMD: FX-8150
Kingston HyperX 1866 2X4GB
Sapphire 6870 Crossfire, EyeFinity 3 Screens
2-OCZ Vertex 3 120GB SSD's / Raid0
Western Digital Cavier Black 500Gb HDD
OCZ Vertex 2 120GB SSD
Zalman: 9900NT
Windows 7 64bit Professional
CoolMax: CUG950B 950w
Antec P280 Case
MSI 990FXA-GD65
AMD Phenom II X6 1090T
Zalman 9700NT
Coolmax 900 PSU
MSI R7770
Kingston HyperX 4X4GB 1600
2-OCZ Vertex 2 120Gb/SSD's / Raid0
Samsung 500GB HDD
Windows 7 64Bit Professional
Antec P180b Case
SiliconDust: HDHomeRun Prime Digital Cable Card, 3 Tuners HDTV LAN. 2 PCs, 1 HDTV
Ex Forum User 3
« Reply #4 on: 30-October-12, 20:22:22 »
Backup your data and use software-raid after.
The speed is the same but all Windows versions can use it.
MSI won't make a driver, it's the chipset manufacturer that does that.
