Author Topic: "MSI Fast Boot" and "Fast Boot"  (Read 162201 times)
~D4rk-S4v4nt~Topic starter
« on: 29-October-12, 21:51:33 »
Hi there,
I have an MSI Z77A-GD65 and have just installed Windows 8 Pro and configured it to boot using the UEFI Windows Boot Manager.
I'm trying to get an optimal fast boot as shown in some of the Microsoft videos and have a question about some of the firmware settings -
  • MSI Fast Boot
  • Fast Boot
Does anyone know what the difference between these two settings is? - enabling the "MSI Fast Boot" hides and removes the other "Fast Boot" option but does not appear to have any discernible difference in reality.
Also I have tried enabling the "Windows 8 Feature" but receive a pop-up message telling me that my discrete video card (PowerColor PCS+ 7950) is not Windows 8 Logo and does not support GOP. It then disables the "Windows 8 Feature".
Does anyone have the "Windows 8 Feature" working with a discrete graphics card I am thinking that it may only work with the Intel HD graphics integrated on the CPU.
Many thanks
D
MSI Z77A-GD65 - BIOS: 10.7 / 20121022
Powercolor PCS+ 7950 - Corsair TX850 v2 +12v: 70A
i5-2300 @ 3.5GHz / Samsung 8GB (2x4GB) 1600MHz 30nm @ 9-9-9-24
Intel 520 Series 240GB SSD + Seagate Barracuda 7200.12 500GB SATA 6Gb/s RAID 0
Windows 8 Pro x64
  • 微星科技
« Reply #1 on: 29-October-12, 21:57:20 »
For full win8 compatibility the vbios of a vga requires support for the Graphics Output Protocol (GOP) which is a UEFI Feature (http://msdn.microsoft.com/en-us/library/windows/hardware/hh997769.aspx). Only newer vgas support GOP. As vga and board need to support GOP the system won't post with a vga using a GOP compatible hybrid vbios when the board has no GOP compatible bios. That is what keeps some vga manufacturers from offering cards with such a vbios and that is what caused no post problems with recent MSI GTX660(ti) cards (which came with hybrid vbios out of the box).
MSI Radeon RX Vega 64 WAVE 8G
Seasonic G-750 • +12V: 62A • +3.3V: 20A • +5V: 20A
Windows 10 Pro
Cooler Master Masterbox 5 MSI Gaming Edition
« Reply #2 on: 29-October-12, 22:44:24 »
Thanks flobelix
Any idea on the difference between "MSI Fast Boot" and "Fast Boot"?
I'm not holding out much hope for a UEFI GOP VBIOS for the Radeon card :( - I would enable the Lucid Virtu support but I'm running eyefinity which I believe isn't compatible with Virtu.
Windows 8 Pro x64
thenewoc
  • STAFF SERGEANT
« Reply #3 on: 31-October-12, 16:40:10 »
Hi ~D4rk-S4v4nt~
I have same board as you and also just updated to W8 Pro, installed on SSD but only have HD4000 at the moment.  I'm using the latest beta bios A71 and thought I'd take a look into this as part of getting my install nicely configured.
The MSI Fast Boot also has a utility app to switch this on and off within Windows from the system tray, i.e. load stay resident app.  This app doesn't appear to be available from MSI UK website, I had to download it from the US site, on motherboard product page.
With MSI Fast Boot switched on with the app (also enabled in BIOS), I'm assuming this is with the switch covering the word 'Off' and the word 'On' showing, this toggles the MSI Fast Boot option in the BIOS to enabled when the word 'On' is showing in the app.  The app is also useful as a neater way of getting back into the BIOS rather than repeatedly hitting the Delete key during boot up.
I think you also need hibernation enabled as some people with an SSD may be used to disabling it, if it's not enabled you won't have the 'Turn on fast start-up' option in the 'Power Options' > 'Choose what the power buttons do' > 'Shutdown settings' section.
This is not as fast as some of the W8 demos I've seen either so I thought I'd enable the W8 Feature in the BIOS which has caused me some grief as it then failed to boot and dropped me into the EFI Shell as shown below.  What's more I couldn't get back to the Click BIOS for a while as resetting the CMOS resulted in the reset BIOS screen where you need to press F1 or F2 but it had lost my wireless USB keyboard / mouse connection.  Eventually after moving the Logitech Unifying receiver to another USB port and resetting the BIOS again it regained connection with the keyboard/mouse so I could choose F1/F2 but still ended up in EFI shell where I had to enter 'exit' to escape into Click BIOS.
Conclusion:
Whether I have MSI Fast Boot enabled or not seems to make no difference, either way I achieve around 20 seconds from a cold boot.
Even though I'm using an Ivy processor with Z77 chipset I can't get the Windows 8 Feature in the BIOS to give me W8 Fast Boot.  Unsure whether this is due to not having a discreet graphics card or a fault with the BIOS? It seems odd that if the BIOS doesn't detect suitable hardware that it wouldn't make the feature unavailable.
« Last Edit: 01-November-12, 00:08:51 by thenewoc »
MB: MSI Z77A-GD65 (BIOS-E7751IMS V10.12B3 / E7751IMS.AC3 (LATEST BETA BIOS) + ME 8.1.50.1456)
VGA: Sapphire HD7970 Dual-X (299-1E210-001SA) / Latest GOP VBIOS 015.027.000.000.000000 and Driver Version 15.200.1062.1004 WHQL / Win 10 64 (as reported by GPU-Z) + CCC
PSU: Corsair AX850
CPU: Intel Core i5-3570K Ivy Bridge
MEM: Samsung Green 2x4GB (MV-3V4G3D/US)
SSD: OCZ Vertex 4 256GB (VTX4-25SAT3-256G / 1.5 FW)
HDD: Western Digital Caviar Green 2TB (WD20EZRX)
ODD: LG Blu-Ray Combo (CH10LS20 / 1.01 FW)
COOLER: Phanteks PH-TC14PE
OC: 3.4/4.5GHz TURBO
xmad
  • Salisbury MD
« Reply #4 on: 31-October-12, 18:18:44 »
MSI Fast Boot has to do with memory checking and remapping I believe.
I'll find out exactly and get back to you.
Mainboard: X79A-GD65 (8D)
CPU: I7-3930K
Setting: 2400 CL:10
SSD: Corsair GS 256GB
Corsair Link
Cooling: Corsair H100I
xmad
  • Salisbury MD
« Reply #5 on: 02-November-12, 02:02:16 »
I was wrong, they are related to win8, which I am downloading now to play with.
Fast Boot is intended for Windows 8.
“Enables or disables boot with initialization of a minimal set of devices required to launch active boot option.”
Note: It has no effect on BBS boot options.
Fast Boot option may typically contains the following sub-options in the BIOS.
1.       VGA Support – EFI Driver
2.       USB Support – Full Initial / Partial Initial / Disabled
3.       PS2 Devices Support – Enabled / Disabled
4.       Network Stack Driver Support – Enabled / Disabled
PS: Sorry for the delay, have been clearing trees for people.
CPU: I7-3930K
Setting: 2400 CL:10
Corsair Link
SEAL-KillerXXL
« Reply #6 on: 23-March-13, 13:13:02 »
So,what`s bettter to use? :think:
MSI Big Bang Xpower II
xmad
  • Salisbury MD
« Reply #7 on: 23-March-13, 14:47:18 »
I use MSI Fast boot, it works with the fast boot utility.
CPU: I7-3930K
Setting: 2400 CL:10
Corsair Link
robbymoody
  • SERGEANT
« Reply #8 on: 23-March-13, 15:03:54 »
But in my case enabling or disabling MSI fast-boot doesn't seem to make any difference...
Board: MSI X79A-GD65(8d)
Bios: Version 4.4
VGA: MSI N770 TF 2GD5/OC
PSU: Corsair AX750
Intel: Core i7-3930K Sandy Bridge-E
MEM: Corsair Vengeance CMZ16GX3M4A1600C9B
HDD: Samsung 830 SSD
Cooler: Coolermaster 412s
OC: Stock
OS: Windows 8.1 Pro 64bit
xmad
  • Salisbury MD
« Reply #9 on: 23-March-13, 15:07:05 »
The only difference between fast boot and MSI fast boot is the the msi utility will work with MSI fast boot.
http://www.msi.com/service/download/utility-19319.html
You can definatly see a difference between Fast Boot completly disabled vs enabled.
CPU: I7-3930K
Setting: 2400 CL:10
Corsair Link
robbymoody
  • SERGEANT
« Reply #10 on: 24-March-13, 10:21:17 »
With fastboot enabled I still see the post messages and I am still able to enter the bios. Same as when disabled.
Bios: Version 4.4
PSU: Corsair AX750
OC: Stock
xmad
  • Salisbury MD
« Reply #11 on: 24-March-13, 17:19:19 »
https://forum-en.msi.com/index.php?topic=163918.msg1226049#msg1226049
Have you tried reflashing the bios? Are you already at the one I linked?
CPU: I7-3930K
Setting: 2400 CL:10
Corsair Link
robbymoody
  • SERGEANT
« Reply #12 on: 24-March-13, 17:59:01 »
Yes, I'm on 4.1.
Bios: Version 4.4
PSU: Corsair AX750
OC: Stock
xmad
  • Salisbury MD
« Reply #13 on: 25-March-13, 16:17:33 »
Try re-flashing with the method and archive from the link.
Perhaps post a you tube video of your boot.
What boot messages are you seeing? On either of my board when Fast Boot is enabled, I no longer get the splash screen, just and MSI with a spinning win 8 wheel for about 3-5 seconds then I see metro.
Do you have / and are you using the aux Sata Controller? (Sata 7&8)
CPU: I7-3930K
Setting: 2400 CL:10
Corsair Link
SEAL-KillerXXL
« Reply #14 on: 26-March-13, 17:17:45 »
Lol,I`ve tried it.Not even a 1% of difference.Or there should be "Windows 8 Feature" enabled to get any boost? :confused2:
Same for Fast Boot.
xmad
  • Salisbury MD
« Reply #15 on: 26-March-13, 17:27:18 »
Ah, that is probably it, do you have UEFI installation and Win 8 options enabled?
CPU: I7-3930K
Setting: 2400 CL:10
Corsair Link
SEAL-KillerXXL
« Reply #16 on: 26-March-13, 21:54:23 »
Yeah,Win 8 UEFI.
I can`t enable Windows 8 Feature because of no GOP support on my GTX 670. :nooo:
xmad
  • Salisbury MD
« Reply #17 on: 26-March-13, 22:19:31 »
Who makes the card? If it is MSI, what is the s/n?
CPU: I7-3930K
Setting: 2400 CL:10
Corsair Link
SEAL-KillerXXL
« Reply #18 on: 27-March-13, 00:23:23 »
Nope,it`s not MSI.It`s Gigabyte.
Aw,there is a bios update with UEFI support.Looks like it`s time to update BIOS for videocard. :grin:
Ok,after update and enabling "Windows 8 Feature" Fast Boot is working.But not too much "boost",yeah.To be honest there are no boost.Looks like another marketing technology. :rolleyes:
I`ve tried every option.MSI Fast Boot,Fast Boot.Maybe there are 1-2 seconds of improvement,but not something that I can notice.Ah,and there are problems to go to the BIOS of course.So,it`s USELESS.And yes,I have an SSD.
Too bad that MSI didn`t give the correct instructions.I think they must make a big note that to use Fast Boot you need UEFI-compatible videocard and W8 Feature Enabled.And another note,that sometimes you won`t get any boost,excluding cool MSI logo on startup. :cheesy:
« Last Edit: 27-March-13, 08:08:04 by SEAL-KillerXXL »
badboy2k
  • Online Online
« Reply #19 on: 27-March-13, 00:32:49 »
contact them and ask them for a GOP VBIOS for your card model http://www.gigabyte.com/about-gigabyte/contact-us.aspx
good luck if they give you one someone here will be able to walk you through the process!
Cooler: corsair H100 cooler
gmiwoj
« Reply #20 on: 23-March-16, 22:31:42 »
MSI Fast Boot popping up every time i start a windows annoys the hell out of me and uninstalling it doesn't seem to make any difference in boot time. Good riddance.
Nichrome
« Reply #21 on: 23-March-16, 22:47:25 »
If you know how to make use of it, you get 5 sec quicker boots :)
>>Please read and comply with the Forum Rules.<<
:nichlock:
