Author Topic: tv anywhere master can not work on my pc now  (Read 1911 times)
mohawk7507Topic starter
« on: 09-November-12, 00:06:26 »
I have a problem with the tv anywhere master.
a few years ago when it was new everything is functioning normally. no problem.
because it had long been unused tv tuner so I save.
when there is a need to use the tv tuner on my computer then put it back.
the problem now:
at the turn msipvs always error. can not sign in to the application
what are the new drivers or software for tv anywhere master?
My computer spec:
Pentium D 805
Gigabyte P965 S3
ATI 4650 DDR3
os
windows xp sp3 32 bit
windows 7 32 bit
please help to all the moderators or the technical support of the members of the forum tv tuner to solve this problem.
Thank you for your attention
HenryW
« Reply #1 on: 09-November-12, 00:46:18 »
 There are no new drivers for that old card only drivers from MSI for it are here:
http://www.msi.com/product/mm/TV-nywhere-Master.html#/?div=Driver&os=XP%2032
 Keep in mind that even if you can get it working it will only work connected to a cable system, it will not work for over air digital TV broadcasts.
 What country are you in?
Z77A-GD65/BIOS 10.5, i7 2700K
W 7 Home Premium x64/SP1
Corsair TX650W
Lite-On CD/DVD combo burner
MSI 560 HAWK, Drv. 368.82
