Author Topic: K9N6SGM-V HELP  (Read 1862 times)
SwivelTopic starter
  • Computer Tech and AFX Slotcar Nut
    • TC Computers
K9N6SGM-V HELP
« on: 17-November-12, 05:12:49 »
Hello All
I have a MSI Motherboard (MS 7309 ver 1.0) (K9N6SGM-V)
Now was Bois ver 1.8 and got giver a Phenom x3 8450 (95w) which wasn't on the list of tested cpus (better than my 5600).
Well downloaded the MSI update program and it showed my Bois had an update 1c, So I let it do it's thing.
No boot now,
BUT
took the battery out so bios would lose all settings and it booted showing Boi checksum error F1 for setup or F2 to default and boot.
F1 sucked as you could set the info but on reboot it wouldn't boot (out comes the battery  LOL)
So F2 got me back up and going. Downloaded Bios 1.0 and created a usb bood drive.
Yeah you guessed it,  It's back.
Being a male, i then upgraded to bois 1.1
Yeah, i'm on a roll here.
Went to update to 1.2 and said it was done, but back to the no boot
AAAAHHHHHHHHHHH
Bloody males, should have stopped at 1.1.
Thats my Story so far.
Now need help to make it a happy ending   PLEASE
Tomo
badboy2k
  • Online Online
« Reply #1 on: 17-November-12, 06:06:12 »
>>Use the MSI HQ Forum USB flasher<< use that to flash bios versions its alot more stable!
also what else is in your system? >>Posting Guide<<
just to add i doubt the 95W cpu will work properly as the max of any of the cpu's tested is 89W and nothing higher so it looks like the VRM's and power delivery chokes arn't made for 95W cpu's!
Cooler: corsair H100 cooler
SwivelTopic starter
    • TC Computers
« Reply #2 on: 17-November-12, 07:36:54 »
Well the rest is just a 320gig hd, 2gigs ram, xp home.
just would love to kick the bios up again to 1.0, then atleast it's going.
Yeah the 95w I didn't think would work, but with bios updates, you never know,  But i learnt the hard way
Tomo
badboy2k
  • Online Online
« Reply #3 on: 17-November-12, 08:11:28 »
can you get into the board at all? if yes the reflash to 1.0 using the forum flasher as its much more stable!
SwivelTopic starter
    • TC Computers
« Reply #4 on: 17-November-12, 08:55:53 »
Hello. No go at the mo, leaving it over night unplugged (psu and battery) and hope I get a change,  V1.0 is on the pen drive and waiting  LOL.
Thanks for your time
Tomo
SwivelTopic starter
    • TC Computers
« Reply #5 on: 17-November-12, 22:39:58 »
Well just gave it a go.
I'd say the MB is DOA now, Took the ram out and it doesn't beep when trying to start it.
What a bummer.
Tomo
